Electric parking brake - Vintage Mustang Forums
 16Likes
post #1 of 36 (permalink) Old 06-21-2019, 12:21 AM Thread Starter
krynn44@yahoo.com's Avatar
I went to the junkyard last week and found some electric calipers on a 08 passat. They where in good shape so I picked them up. I did a bunch of research on them and found that they would require the parking brake control module, parking switch, abs control module, stop switch, and at least one speed sensor. So that's what I got.
myfirstcar66 likes this.
post #2 of 36 (permalink) Old 06-21-2019, 12:27 AM Thread Starter
Now that I had all of the components i needed to make them fit my 1965 mustang. Now for most of you you might have to figure out some of this on your own because i have a 1998 explorer rear end. First i had to figure out how to mount the bracket on the baking plate. I thought a 2000 mustang plate looked promising but the center hole is too small and the bolt pattern is wrong. So let's start fabrication. First in paper to get a starting pattern. Next in cardboard. Now the silver line represented the biggest rotor I could use.
post #3 of 36 (permalink) Old 06-21-2019, 02:09 AM Thread Starter
I now have it made out of wood so I could have something to bolt the caliper brackets to. The rotor that I used was off of a 2002 Ford explorer. But the drum extended past the back of the rotor so I had to pr it on a lathe and cut off the excess. The spacing for it is perfect. I trimmed the splash shield because it interfered with the caliper bracket.
post #4 of 36 (permalink) Old 06-21-2019, 10:57 AM Thread Starter
Here is the tolerances that I got when I finished. The pads set on the rotor just enough, the is a few mm on the bottom to the pad top the hat of the rotor, and the clearance between the rotor a and the brake caliper is 3.5mm and 3.2mm. The bolts from the Passat where a little long so I had to shorten them, a little side note a 3/8 ratchet will fit in the bolt without a socket. Here is the finished brake install. Now on to the electric install.
Huntingky and myfirstcar66 like this.
post #5 of 36 (permalink) Old 06-21-2019, 12:07 PM
wicked93gs's Avatar
You trust your battery with your life? It may be unlikely that your battery will fail when you need an E-Brake....but it is FAR more likely it will fail with the car parked and the brake is in use as a parking brake...would be bad in some circumstances. No, an electric(or hydraulic) E-brake is one modification that is just plain dangerous. They are mechanical for very good reason.
wicked93gs is online now
post #6 of 36 (permalink) Old 06-21-2019, 12:49 PM
myfirstcar66's Avatar
Our new Expedition has an electric parking brake and I HATE it. It auto-engages on level ground most of the time, does NOT auto-engage when on a slope (DUH) that would both make sense AND would take tension off the drivetrain when shifting to and from Park. Also, what happens if there is a hydraulic brake failure and it needs to be used gradually to safely slow and stop the car? I like being able to feel the tension and KNOW when my E/park brake is working. Don't get me started on that danged auto engine-stop BS...
Garth66, Huntingky and copracr like this.
My 1st car...
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
Older son's 1st car...
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto
•Dealer A/C • Console
•Dual Exhaust • Power Steering
Younger son's 1st car...
'66 Nightmist / Blue & white deluxe coupe
•Factory A/C •Console
WAITING FOR RESTORATION
myfirstcar66 is online now
post #7 of 36 (permalink) Old 06-21-2019, 02:52 PM Thread Starter
The electric parking brake is used for just that...parking, technically there is no emergency brake in a car. If you don't believe me go read your manual. You have a dual master cylinder with two reservoirs so if one goes our you have the other. And my current parking with the old school pull handle would not hold my car let alone stop it in an emergency. Now this is a mod page for modding our cars and I am just trying to show how I did it. If we all keep saying what we don't like we might as well keep our cars stock.
DonP likes this.
post #8 of 36 (permalink) Old 06-21-2019, 03:03 PM
Well, I said I hated the one on the Expedition. I LIKE that you're modding and improving your ride and showing others how you are doing it. My e-brake / p-brake SAVED my butt once in town when the single bowl master cylinder went out. That, with down-shifting, got me stopped safely and I limped home where I could pull it apart and put another master cylinder on. I won't be able to do that so easily in some modern vehicles. I'm researching how to reprogram the Expedition.
Electric parking brake : very cool
No emergency brake : not cool
My 1st car...
post #9 of 36 (permalink) Old 06-21-2019, 03:18 PM
alex1965's Avatar
Wow, your dedication to modifying a 50+ year old car is admirable. Keep grinding!
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
And not nearly enough time
alex1965 is offline
post #10 of 36 (permalink) Old 06-21-2019, 03:23 PM
I second this. I like hiding modern stuff in plain sight, too. Given the limited space in a Mustang's body, this is also cool as we age and may not have the oomph we used to for stomping p-brake pedals or twisting and pulling handles but I hope I am able to use the old-school backups a long time.
My 1st car...
post #11 of 36 (permalink) Old 06-21-2019, 03:23 PM Thread Starter
Here is the information on how an electric parking brake works.
File Type: jpg Screenshot_20190619-233003_File Viewer_1561144793823.jpg (263.0 KB, 52 views)
File Type: jpg Screenshot_20190619-235853_File Viewer_1561144855390.jpg (373.3 KB, 47 views)
File Type: jpg Screenshot_20190620-000052_File Viewer_1561144882713.jpg (291.3 KB, 39 views)
File Type: jpg Screenshot_20190619-235955_File Viewer_1561144904093.jpg (305.5 KB, 37 views)
File Type: jpg Screenshot_20190620-000355_File Viewer_1561144915699.jpg (409.5 KB, 38 views)
File Type: jpg Screenshot_20190620-000148_File Viewer_1561144932946.jpg (296.4 KB, 33 views)
File Type: jpg Screenshot_20190620-000652_File Viewer_1561144946991.jpg (272.9 KB, 36 views)
File Type: jpg Screenshot_20190620-000500_File Viewer_1561144961668.jpg (299.6 KB, 27 views)
File Type: jpg Screenshot_20190620-000745_File Viewer_1561144972716.jpg (293.4 KB, 24 views)
File Type: jpg Screenshot_20190620-000741_File Viewer_1561144983137.jpg (305.0 KB, 22 views)
post #12 of 36 (permalink) Old 06-21-2019, 04:55 PM
Cooooool....
How my current parking brake works fits in an area about the size of my cell phone screen.. with pictures ! Haha! ! I'm glad you have the patience and wherewithal for it. Hey, I did do an LED head, park/turn, and tail light conversion, electronic ignition, LED instrument bulbs and I'm thinking about hiding a quiet late-model thermostatically-controlled electric cooling fan for this 105-degree weather. Do you have suggestions for the quietest / best pusher fan I can put in with an off-auto-on configuration? At one time I heard people raved about some Ford Taurus 3.8 fan or something. I've also heard of Spal etc.
post #13 of 36 (permalink) Old 06-21-2019, 10:42 PM Thread Starter
So this is what I did today. I went through a few hundred pages of wiring diagrams to get to this point but the stop switch interfaces with yet another control module. Im going to look into how to bypass it. Any ecm masters?
post #14 of 36 (permalink) Old 06-22-2019, 09:13 AM
wicked93gs's Avatar
I wasnt criticizing the work by any means...but to say a conventional "parking" brake wont help you stop the car in an emergency is just silly. Of course it does....that's why it's a gradual pull and not just an electrical solenoid that shoots a pin into a rotor or something. Electric brakes(and pneumatic for that matter) work either one of two ways...either the default is engaged, or disengaged. In the case of engaged, your vehicle isnt going anywhere in case of power failure(not so bad on the road unless your alternator fails at the same time...then its catastrophic) but if its parked...that means you are unable to even tow the vehicle without dragging it up onto a flatbed, killing tires. In the case of default disengaged...there is no catastrophic failure on the road unless your hydraulic brakes fail at the same time....but parked...disengaged can roll you down a hill, destroying your vehicle and possibly hurting or killing other people if you live some place with crazy hills like San Francisco.
post #15 of 36 (permalink) Old 06-22-2019, 11:07 AM
^^^ I can't say I've ever heard of that unless it was a manual trans somebody left out of gear and didn't set a brake. I suppose if the default was engaged and a disabled vehicle lost power, a jump box or cables from a tow rig would at least be able to remedy that temporarily. OP has their hands full with this electrical project, and as cool as modern stuff can be, this is EXACTLY why I drive an old car and an old(ish) truck. I need a break from the complexity of life and I can work on those if I need to. Good luck krynn44!!
