3G Alternator Upgrade no S (White Wire) Terminal / Connection - Vintage Mustang Forums
post #1 of 8 (permalink) Old 07-07-2019, 11:28 PM Thread Starter
I spent about 4 hours today getting my butt kicked by what should have been a very simple alternator swap, and no amount of internet searching on this forum and many other sites every yielded an answer, so I thought I would help the next poor sap out by logging what I found.
My 1-wire power master alternator really struggles at low RPMs, probably due to lack of an exciter wire, so I decided to swap it out for a 3G unit. I ordered the unit in April from Amazon, and as usual it set on the shelf for a while before I got around to doing the work. Since the case was the same as my 1-wire, all I had to do was clock the alternator, and modify the wiring a tiny bit to accommodate the ASI wires. The problem came when I got ready to hook up the Stator Wire (white wire) which should route from the S terminal on the 3-pronged plug back to the alternator on a terminal between the ASI plug and the battery stud. The problem, in every search phrase I looked for was:
3G alternator with no terminal for S wire to plug into
3G alternator missing stator terminal
3G alternator missing white wire connection
etc.
You get the idea.
It turns out, that even though the box said I had a part number for a 3G alternator, I had been given a 6G alternator designed to be used with an ECM to regulate the voltage.
Just in case this happens to anyone else.
ajzride is offline
post #2 of 8 (permalink) Old 07-08-2019, 05:40 AM
j persons's Avatar
Will Amazon exchange it? After all it's not your fault they sent you the wrong alternator.
F-150 SCab daily driver
j persons is online now
post #3 of 8 (permalink) Old 07-08-2019, 08:45 AM Thread Starter
Pretty sure not, exspecially after I did a little grinding to make the V-Belt pulley work before I realized the wiring was off.
ajzride is offline
post #4 of 8 (permalink) Old 07-08-2019, 10:18 AM
Just some guy
GypsyR's Avatar
A general FYI, the 4G alternators are technically ECM controlled too but they will wire up work the same as a 3G in our cars. I'm not the only one here who is using one. Small nitpicky differences between 3 and 4G's, just a tidbit of info.
GypsyR is online now
post #5 of 8 (permalink) Old 07-08-2019, 10:24 AM
68Hildago's Avatar
GyspyR is correct (as usual). I am using a 4G from a 2000 Taurus/Sable. But in 2001 the pigtail wiring changed to enable the ECM control, so I just stayed away from those ones when grabbing from the wrecker.
68Hildago is offline
post #6 of 8 (permalink) Old 07-08-2019, 03:01 PM
jdub's Avatar
Bummer. I've now been burned a number of times by setting stuff on the shelf without looking closely at it first. Annoying.
1965 Mustang
jdub is offline
post #7 of 8 (permalink) Old 07-08-2019, 03:13 PM
wicked93gs's Avatar
etc.
You get the idea.
Not that you want to do this modification...but any alternator meant to be regulated by an ECM can be regulated by an external regulator as well...my choice of regulator when I do this is from an 80s Dodge Omni(probably because I have a few sitting around and the wiring is so simple, I am sure other external regulators will work just fine though)
wicked93gs is online now
post #8 of 8 (permalink) Old 07-08-2019, 09:51 PM Thread Starter
Iíve gone through great lengths to clean up my wiring. Definitely not interested in adding back a regulator. Thanks for the advice though.
ajzride is offline
