Front Brake Cooling Ducts - Vintage Mustang Forums
 8Likes
post #1 of 19 (permalink) Old 07-10-2019, 09:35 AM Thread Starter
daveoxide's Avatar
I’m going to be doing my first track day in August and have been gathering parts to freshen up my 67. On that list of items was brake cooling ducts. I figured it is a cheap bit of insurance to help keep my brake temps under control. Anyway, my question is... does anyone have pics or ideas they could share of how they connected the duct to the backing plate? Do you just point it at the existing inlet on the backing plate or did you add a piece of tube to the BP to then clamp the duct to? I have Granada discs on the front and I can weld, so I don’t mind cutting things up to get the best cooling effect.
Thanks for your input!
Huntingky and rpm like this.
daveoxide is offline
post #2 of 19 (permalink) Old 07-10-2019, 10:12 AM
I used the cobra automotive kit since I have the big Lincoln brakes. I installed a scoop on each side where the front turn signals lights go in my 69. I cut up a square abs plastic brake duct to fit that is similar to Bud Moore’s trans am car.
1969 coupe
372 Cleveland, 4 speed, 9" T.50 Trac Lock axle, Toploader, Global west suspension, Big Lincoln Trans Am Brakes front, Eldorado caliper/ MK VII disk rear.
Jsams is online now
post #3 of 19 (permalink) Old 07-10-2019, 10:37 AM
65coupei6_2's Avatar
You can rivet these to the opening on the backing plate. Just trim to fit. Use a hose clamp to secure the ducting to the flange.
https://www.aircraftspruce.com/catal...uctflanges.php
1ofAMillion+ likes this.
...Marco
'65 Mustang Inline 200. CI Aliminum Head, Holley 350,
Schneider 264/274 cam, Headers, Recurved DSII, MSD 6A, and a whole lotta other stuff!
65coupei6_2 is offline
post #4 of 19 (permalink) Old 07-10-2019, 11:12 AM
awhtx's Avatar
The Granada disc brake sheet metal splash shields have a plastic air scoop attached to them. At least mine do.
awhtx is offline
post #5 of 19 (permalink) Old 07-10-2019, 11:37 AM
wicked93gs's Avatar
Seems like you would be better off with steel than aluminum...they cant weigh anything worth mentioning and you could tack weld(or seam weld if you chose) steel versions in place unless there is some need to make them able to be removed from the dust shields independently...for that matter...would be easy to fab some out of some exhaust pipe and sheet metal...or just exhaust pipe.
wicked93gs is online now
post #6 of 19 (permalink) Old 07-10-2019, 11:50 AM
Great find with the aircraft source. Looks like 1/2 of race shop prices.
65coupei6_2 likes this.
Verbose Vocabularian
1ofAMillion+ is online now
post #7 of 19 (permalink) Old 07-10-2019, 04:20 PM
To each his own. I rather pay $20 for a pair that is already made. Drill a few holes and throw on some rivets. No fabbing or welding. But, like they say. It's your car, do what you want.
...Marco
post #8 of 19 (permalink) Old 07-10-2019, 05:48 PM
wicked93gs's Avatar
If you are drilling holes, you are fabricating anyway. Go down to Autozone(or wherever) buy a 6 inch section of exhaust tubing for $5, cut it into 2 2-inch sections...and after cutting whatever size hole it is out of the brake shield you simply tack weld it directly to the brake shield...same amount of time, no waiting for shipping and $15 cheaper...though not as shiny. I estimate 10 minutes per side or so...most of that spent drilling the hole in the brake dust shield...and no hardware to worry about. Your method is prettier though.
post #9 of 19 (permalink) Old 07-10-2019, 06:37 PM
pics ? mine only have a vent(louver) stamped in the metal shield
2nd 66 is online now
post #10 of 19 (permalink) Old 07-10-2019, 07:54 PM
Here is a scoop on a Granada backing plate. They were only used on 80 and maybe 79 Granadas. They feed air into the center of the rotor.
Huntingky and 2nd 66 like this.
cougar70 is online now
post #11 of 19 (permalink) Old 07-10-2019, 09:37 PM
I used the CA duct kit which replaces the OEM K-H splash shields with a plate and duct attachment tube that directs air to the center of the rotor. I modified a separate front valence to attach Allstar brake duct flanges.
2nd 66 likes this.
patrickstapler is online now
post #12 of 19 (permalink) Old 07-10-2019, 10:24 PM Thread Starter
daveoxide's Avatar
My backing plates look like they would accept that plastic baffle thing, but unfortunately I never got them with it. That’s a bad sign that the factory added that giant air intake to such a mild mannered car, makes me think the brakes were a bit undersized for that car!
post #13 of 19 (permalink) Old 07-10-2019, 10:34 PM
Originally Posted by daveoxide View Post
My backing plates look like they would accept that plastic baffle thing, but unfortunately I never got them with it. Thatís a bad sign that the factory added that giant air intake to such a mild mannered car, makes me think the brakes were a bit undersized for that car!
That's what mine look like ,wonder if any of those plastic scoop things are available out there somewhere
post #14 of 19 (permalink) Old 07-10-2019, 10:37 PM Thread Starter
daveoxide's Avatar
Is there a specific reason why you ran the duct behind the axle?
post #15 of 19 (permalink) Old 07-10-2019, 10:39 PM
Itís how the plates are made. Opposite side of the calipers.
