sub frame connectors..... - Vintage Mustang Forums
 10Likes
post #1 of 25 (permalink) Old 07-17-2019, 10:37 AM Thread Starter
fordguy's Avatar
i'm going to add a pair to my car, weld in. are any actually better or just higher priced because of the company name? had good or bad fitment with one brand over another?
66 mustang coupe, 302 / T5-Z / 3.80 trac-lok
fordguy is offline
post #2 of 25 (permalink) Old 07-17-2019, 10:52 AM
Grabber70Mach's Avatar
I have a set of spin-techs that I'll probably be selling soon. Let me know if you are interested.
https://spintechmufflers.com/mustang...me-connectors/
Grabber70Mach is offline
post #3 of 25 (permalink) Old 07-17-2019, 10:58 AM
blueovalfan68's Avatar
Street or Track, or Mike Maier Inc. Both have more than one welding point at each end. You can also add the an X brace with MMIís subframe connectors.
-Chris
'68 Mustang
347ci that has a lot of neat stuff in it
T5 manual trans, alum driveshaft, 9" w/3.70 gears
Suspension parts from SoT, Global West, Maier Racing, and a few others. Works for me!
TCP manual rack (love it)
EPAS (Love this the most)
VWW V45 wheels (like these too)
SoT 13" brakes (stopping is good)
And I finally got a paint job!
blueovalfan68 is offline
post #4 of 25 (permalink) Old 07-17-2019, 11:44 AM
I welded in a set of bolt in SMR connectors, fit and price was good
2nd 66 is offline
post #5 of 25 (permalink) Old 07-18-2019, 01:59 AM
Quite a few great choices, be sure to look at tinman's also ...
msh-r likes this.
Matter is offline
post #6 of 25 (permalink) Old 07-18-2019, 08:32 AM
65RedStang's Avatar
Another vote for Tinman subframe connectors.
Tin Man Fabrication ? Builder of Quality Rods, Customs, Classics & Motor Mounts
msh-r likes this.
65RedStang is offline
post #7 of 25 (permalink) Old 07-18-2019, 09:19 AM
j persons's Avatar
Originally Posted by 65RedStang View Post
I have the Tinman SFC's but added an extra weld point at the seat pan area.
F-150 SCab daily driver
j persons is offline
post #8 of 25 (permalink) Old 07-18-2019, 10:01 AM
Huntingky's Avatar
This what I used and would use again.
Coyote build in 65 GT Fastback in body work https://forums.vintage-mustang.com/b...e-powered.html and on Facebook @65gtmustang
F150 SCREW Ecoboost as my daily
66 Emberglow Coupe first car,71 Torino GT, 82 Fastback slooooow 6 banger, 71 Boss 351, 85 GT all long gone
Huntingky is offline
post #9 of 25 (permalink) Old 07-18-2019, 10:14 AM
CP66's Avatar
Couldn't get the spintech link to work but google imaged it and those are some good looking sfc's! Wish they had been around when we did mine!
So Many Cones, So Little Time!
CP66 is offline
post #10 of 25 (permalink) Old 07-18-2019, 01:03 PM
cobra94svt's Avatar
Iíve used both the Tinman and the spintech ones. I had side exit exhaust and the spintech cleared their exhaust perfectly.
Current stable
65 fastback
65 coupe
66 coupe
94 Cobra, on a rotisserie right now
cobra94svt is offline
post #11 of 25 (permalink) Old 07-18-2019, 01:18 PM
Used Global West's, fit perfectly, quite sturdy. Got them from OpenTracker (spread the wealth).
Not worth much, but on that much criticized recent Fast-N-Loud episode building the Bullitt they used GWs.
CJM68GT390 is offline
post #12 of 25 (permalink) Old 07-18-2019, 02:15 PM
wicked93gs's Avatar
I have a set of both Global West...and a set of USCT contoured connectors( 65-66 Mustang CNC Cut Floor Contoured Frame Connectors ). I have not yet installed either...but my plan is to install the global west connectors first...then cut up the USCT contoured connectors and weld them to the sides of the GW connectors and the full length of the floor...essentially taking advantage of the twist resistance of the DOM tubing as well as the extra strength of being tied into the unibody the entire way...not a SFC idea for the faint of heart since it costs twice as much and requires a lot of extra work.
wicked93gs is offline
post #13 of 25 (permalink) Old 07-18-2019, 03:39 PM
Redneckgearhead's Avatar
Another vote for tinman. Not sure how deep you're going with the car but I'm adding convertible inner rockers as well and plan on running some tubing from them to my sub Fran connectors.
Scott
Never let the truth get in the way of a good story
Redneckgearhead is offline
post #14 of 25 (permalink) Old 07-18-2019, 04:00 PM
Just installed a set of GW in the 66 vert. They fit perfectly.
baseballcrazy likes this.
1966 Convertible restomod in progress
cruising68 is online now
post #15 of 25 (permalink) Old 07-18-2019, 05:19 PM
Garth66's Avatar
I have the TCP subframe connector kit with cross member and driveshaft hoop.
https://www.cjponyparts.com/total-co...yABEgInL_D_BwE
________________________
66 Mustang GT Fastback
70 Mustang Mach 1
72 DeTomaso Pantera
69 Cutlass Convertible
Garth66 is offline
