V8 suspension / brake advice needed - Vintage Mustang Forums
 3Likes
  • 1 Post By NEFaurora
  • 2 Post By patrickstapler
post #1 of 8 (permalink) Old 07-21-2019, 08:40 PM Thread Starter
thegreyghost's Avatar
I'm starting the conversion of my 1966 coupe I6 car to V8 and at the same time I'd like to address the worn out suspension, manual drum brakes and maybe the original power steering. The more I look at conversion kits, suspension kits and brake kits, the more confused I'm getting. Seems like the options are endless.
I guess the two main questions I have are if I'm going to do the power steering upgrade, and the upgrades necessary for the V8 will I address the suspension components with these two or is there additional components needed?
I'm trying to avoid buying "kits" if I'm not going to use all the components because of another upgrade.
Second question is about v8 spindles. Is there a multiple aftermarket sources for these or is Scott Drake it? They seems to be the only ones I've been able to find so far.
Any recommendations appreciated.
thegreyghost is offline
post #2 of 8 (permalink) Old 07-21-2019, 09:00 PM
NEFaurora's Avatar
I would not upgrade the the car with Power Steering until you have changed everything over to V8 engine and components in the car...
I recommend the "Borgeson" Power Steering upgrade since they are really popular, work well and are all the rage in Classic Mustangs today.
You can buy V8 Spindles from a bunch of different companies...but there are people her on the VMF selling good used one all the time..
Tony K.
2nd 66 likes this.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is online now
post #3 of 8 (permalink) Old 07-21-2019, 09:46 PM
Call John at Opentracker Racing Products. Donít let the name scare you. He will only sell you what you need.
https://opentrackerracing.com
Opentracker and 2nd 66 like this.
patrickstapler is offline
post #4 of 8 (permalink) Old 07-21-2019, 10:39 PM
I'm rockin' manual steering but if I was to go power I'd seriously consider EPAS .Borgeson is pretty popular but if I can avoid a power steering leak in any way shape or form that would be my go to
take a look also at
Street or Track LLC
Classic Mustang Disc Brake Conversions and Power Steering
Classic Services Restoration Parts
2nd 66 is offline
post #5 of 8 (permalink) Old 07-22-2019, 08:36 AM Thread Starter
Gentleman, thank you very much for the suggestions. When I get a chance later this evening I will check them out.
Much appreciated!
post #6 of 8 (permalink) Old 08-11-2019, 10:01 PM
I did my 66 Fairlane about 10yrs ago. I bought brackets from NPD I think (same as 65-66 Mustang swap). Then I bought most of the parts from local parts store. Now you can use RockAuto.
Same bracket as these...
https://www.cjponyparts.com/auto-pro...-1967/p/DBCBL/
1969 Mustang Sportsroof
408W
4 speed
CA rust free car
50dan is offline
post #7 of 8 (permalink) Old Yesterday, 10:51 PM
mrbreez's Avatar
You need to decide how your going to use the car good driver ,restomod,before buying unnecssary parts .Safety should always be on the top of the list you can never go with updated brakes.
mrbreez is offline
post #8 of 8 (permalink) Old Yesterday, 11:58 PM
bmcgc's Avatar
Do it in stages to avoid having the car down for long periods.
You will need wheels, so get those first, either the wheels/tires you want or just rollers for now.
I would do the rear end first and along the way start searching CL, ebay and for sale ads on Mustang boards to search for parts.
Guys pull their V8 stuff all the time for upgrades and sell their takeoffs.
I converted my 67 from 4 lug drum to 5 lug drum for under $500. That was new rear axle bearings and everything on all four brakes new except the backing plates.
1965 Mustang Coupe 289/C4
1967 Mustang Coupe 200/C4
2017 Mustang EB Premium
bmcgc is online now
