Well...it won't start - Page 2 - Vintage Mustang Forums
post #16 of 24 (permalink) Old 01-07-2005, 08:23 PM
Verndog's Avatar
I can understand the bad ground...but how can you have a starter solenoid AFTER the starter? Positive cable from battery OR switch has to go to solenoid BEFORE starter...unless I'm missing something...and Strokie posted that as well? ::
Danno....how does it sound?? I bet your are getting psyched :winkgrin:
My psycho second side :: :chainsaw:
-Kevin- 69 Mach 1 - 351W - FMX - mostly original. My 69 Pics--Sold 4-25-17
Verndog is offline
post #17 of 24 (permalink) Old 01-07-2005, 08:28 PM
MarkMach1's Avatar
Thanks for the help Strokie!!
Good call Strokie, I knew one of us would save Danno.
Mark Prokop
69 Mach 1 13.51 in the 1/4, so far...65 fastback major project, hell, it can't even drive out of the garage much less do the 1/4, yet.
MarkMach1 is offline
post #18 of 24 (permalink) Old 01-07-2005, 09:35 PM
It started right up after I switch it.
Does this mean it runs? I think after 2 years and how many thousands of dollars spent would this not need a post all to itself?...................Congrats on letting the stang loose?
fixerman is offline
post #19 of 24 (permalink) Old 01-07-2005, 11:48 PM
Stroked66's Avatar
Verndog,
These High Torque Mini Starters have built in solenoids, so the original stock solenoid just serves as a switch, which allows you to continue to use your original ignition wiring.
Flow goes something like this; Ignition key activates stock solenoid, current is sent through solenoid to the Mini Starters’activator lead (12 gage wire attached to back large post in my pick), which runs to the mini starter solenoid and activates starter. When the key is released, the starter deactivates but since the “I” & “S” terminals are left alone, everything runs as normal.
Configured this way, it doesn't matter if the starter itself is first in line to the battery or last. What’s important is that it’s connected directly to the positive side of the battery and that a switch activated “Hot” lead is attached to the Mini Starters’ Solenoid.
Stroked66 is offline
post #20 of 24 (permalink) Old 01-08-2005, 12:08 AM
bbenthin's Avatar
Send a message via AIM to bbenthin
Wow, and here we thought you were just another pretty face. :rolleyes: :winkgrin:
Nice work Strokie! :highfive:
Brian
bbenthin is offline
post #21 of 24 (permalink) Old 01-08-2005, 01:08 AM
One other way of wiring in the mini starter is leave the stock solonoid wires as per factory and simply make up a short jumper wire to connect from the supply stud / battery cable stud to the "S" terminal on the mini starter solonoid.
Dave
kdrop is offline
post #22 of 24 (permalink) Old 01-08-2005, 02:34 AM
Verndog's Avatar
Well...I stand corrected! Good work in helping Danno get the Pony on cryponite running!! This whole double solenoid thing is throwing my brain into "loop mode"...and now that I've come full circle....I'll think on that one again tomarrow. :shocked2:
Wait...now I see. The starter has power to it full time and the stock solenoid sends ignition signal only to new solenoid and kicks the starter in...think I've got it.
Whats the main advantage to the mini starter...I understand they crank faster...do they outlast the OEM's as well?...Prob. doesn't "sound" like a Ford cranking anymore huh?
Verndog is offline
post #23 of 24 (permalink) Old 01-09-2005, 10:41 AM
ken_schall's Avatar
Send a message via AIM to ken_schall Send a message via Yahoo to ken_schall
Check your ground wire....
Hmmmm.... only the second reply....but hey...don't mind me. :pissed:.... :winkgrin:
Ken
01' Jeep wrangler
13' ford Escape
12' ford F-150 fx4 Supercrew
68 GT/CS/Shelby-like....heck its a Modified Convert
68 GT/CS...Project underway!
ken_schall is offline
post #24 of 24 (permalink) Old 01-09-2005, 01:53 PM Thread Starter
copasspupil's Avatar
Sorry Ken, I didn't see it until you mentioned it. I was on the phone to Strokie and mentioned that I had power at the shut off switch but not at the end of the wire when it connects to the mini starter. I rechecked the ground and noticed the problem.
copasspupil is offline
