What grade and brand oil are you running? - Vintage Mustang Forums
post #1 of 33 (permalink) Old 01-07-2005, 08:08 PM Thread Starter
Verndog's Avatar
I'm wondering what grade and brand of oil works best in our winter climate. After I did my 4V conversion I changed oil to my old standby Castrol GTX 10-40. After oil change I noticed a difference (could be 30 deg weather also)...anyway at cold startup I get about 5 seconds lifter tapping which immediately quites down. I have bone stock heads and no real history on engine, except 67K no smoke no oil leaks and sounds good.
Likely this is somewhat normal, just more curious what others are running. I'm sure this will get into the ol synthetic debate...fire away.
-Kevin- 69 Mach 1 - 351W - FMX - mostly original. My 69 Pics--Sold 4-25-17
Verndog is offline
post #2 of 33 (permalink) Old 01-07-2005, 08:23 PM
MarkMach1's Avatar
Mobil 1 15W-50
Mark Prokop
69 Mach 1 13.51 in the 1/4, so far...65 fastback major project, hell, it can't even drive out of the garage much less do the 1/4, yet.
MarkMach1 is offline
post #3 of 33 (permalink) Old 01-07-2005, 09:25 PM
MCABOSS is offline
post #4 of 33 (permalink) Old 01-07-2005, 09:39 PM
All of my pre-2000 cars/trucks get stright 30w, usually Valvoline....never had a problem ::
Dean is offline
post #5 of 33 (permalink) Old 01-07-2005, 10:30 PM Thread Starter
Verndog's Avatar
OK...I'll bite. Any of you synthetic guys have any issue with leaking seals? I run Mobile 1 in my Tundra 4.7L but figured I'd run dino oil in the Mach and change 2x per year...I would only prob. put 1500 on between changes.
Also...anyone change oil weight in winter?
Verndog is offline
post #6 of 33 (permalink) Old 01-07-2005, 10:37 PM
Teebone's Avatar
I use the same thing you are using 10W40...and thats in my cold New England climate..never had a problem.
59 T-Bird (elegant old lady)
68 Fastback (work in progress)
70 Mustang convert (wonderful sunny day driver)
72 Mach One (Greenwich Concours 1st place winner)
95 Vette convert LT1 (faster then my ability to drive it)
VMFTP 2.0 Question #19 Winner! (sort of)
Teebone is offline
post #7 of 33 (permalink) Old 01-07-2005, 11:49 PM
MarkMach1's Avatar
You think I'd let my car take, I mean have a leak Not a chance. That'd drive me nuts, and after what Mr. Schall went through at Pony Trails last year, no thanks. No leaks here.
Mark Prokop
post #8 of 33 (permalink) Old 01-07-2005, 11:54 PM
c6fastback's Avatar
Send a message via AIM to c6fastback
Castrol 10w30on the new engine . Will switch to Mobil 1 once I have a few miles on the engine . Expensive oil change since I have an aluminum cobra pan . Oh well .
68 302-4V w/1.84",1.54" ported , Comp XE268H , 2200 rpm Hughes converter, 3.25 9" w/10x2.5" shoes , MSD box/distrib , RPM intake , 670 Holley , cross flow aluminum radiator , Granada discs......
Michael S.
c6fastback is offline
post #9 of 33 (permalink) Old 01-08-2005, 12:14 AM
70rcodevert's Avatar
I run Mobil 1. I change it in the spring and the fall.
1970 428 CJ "R" Code Convertible.
70rcodevert is offline
post #10 of 33 (permalink) Old 01-08-2005, 01:21 AM
65Topless's Avatar
Hey Vince! Which brand tastes best?
Keith
65Topless is offline
post #11 of 33 (permalink) Old 01-08-2005, 03:03 AM
copasspupil's Avatar
Amsoil for my diesel and will do the same for the mustang after the break in period.
copasspupil is offline
post #12 of 33 (permalink) Old 01-08-2005, 10:08 AM
widgit's Avatar
Remember - synthetic oil's main advantage is the protection it gives at start-up.
I run Mobil 1 in all 5 cars, 3 of which are daily drivers. As far as leaks are concerned none of the cars have developed any leaks despite claims that if you put syn. oil in a high mileage car it will always leak. I sold a minivan to our neighbor that had 116k miles on the original engine when we bought it and I started putting Mobile 1 in it right away. We sold it 8 years later with 228k miles and it never leaked a drop. SWMBO's car is the only car we've used syn in since new and with 47k miles there are no oil related problems to report.
This is me and your practices may vary but I run 10w-40 in every car including the 65. I change around 5k miles (Twice a year on the 65) and I keep the same grade in the winter. Summers can hover above 100 and winters can stay below zero at times and I've never changed grades depending on climate.
That's a good idea. If you don't drive in the winter moisture can build up in the engine with repeated warm up and cool down of a shop or running the car for short periods and I would want it out before I put it on the road in the spring. And you don't want oil you've used all summer sitting in there all winter. Of course originally from Oregon I remember salt not being an issue so you guys probably get to enjoy your cars once in a while during the winter, don't you? :wall:
- Just my 2 cents worth.
"Your actions speak louder than words"
Misc Pics
widgit is offline
post #13 of 33 (permalink) Old 01-08-2005, 01:30 PM Thread Starter
Verndog's Avatar
It's rare when they need to salt roads in this area....prob. happens 3-4 times per year tops in my immediate area. So far I usually can get out at least every 2 weeks without getting the car wet. I'm trying to not expose the car to any more of the elements then necessary. The whole synthetic deal doesn't seem to be worth it for a car that gets 2-3K per year...not cost effective...and as far as startup protection, well since its a fair weather car, it's not started often enough to justify IMO. But then again....when has cost been a factor with a classic. :rolleyes:
Verndog is offline
post #14 of 33 (permalink) Old 01-08-2005, 01:46 PM
66CoupeNW's Avatar
Mobile 1. I have no idea why. The stuffs real expensive, so that makes it good, right?
[color:"green"]"You can't have a proper midlife crisis on only 6 cylinders"[/color]
DanM, Seattle area
www.modernvintageauto.com
66 Coupe & 66 convertible
The Coupe ... 265 of its closest friends!
66CoupeNW is offline
post #15 of 33 (permalink) Old 01-08-2005, 01:50 PM
66CoupeNW's Avatar
Careful with that Amsoil in the 6.0 Danno. Your Ford warranty specifically states "API certified oil", and Amsoil isn't. My understanding is it's great oil, but I believe there have been warranty issues with it's use.
DanM, Seattle area
