3" Wheel Studs - Vintage Mustang Forums
 2Likes
  • 1 Post By gikort
  • 1 Post By 66stangFb
post #1 of 13 (permalink) Old 07-23-2018, 10:32 AM Thread Starter
gikort's Avatar
3" Wheel Studs
I've read through a lot of old posts about this, but I couldn't find a confirmation. Can anyone confirm if these will work with stock (2-piece) front KH disc brakes https://www.summitracing.com/parts/msr-8010/overview/ ?
Can I use the same ones on the rear, or are they different?
Thanks.
66stangFb likes this.
gikort is offline
post #2 of 13 (permalink) Old 07-23-2018, 05:46 PM
CP66's Avatar
It appears that the rears use a .618 knurl vs .625 for the part number listed. Can't find any info on the fronts but they are a different part number than the rears.
CP66 is offline
post #3 of 13 (permalink) Old 07-23-2018, 07:38 PM
I canít answer your question, but I bet a quick call John at ORP or Shaun at SorT would remove all guess work.
patrickstapler is offline
post #4 of 13 (permalink) Old 07-29-2018, 05:09 PM
66stangFb's Avatar
I can't be sure either, but personally I'd suggest using ARP. The resources that Patrick suggested will likely be able to help or try Cobra Automotive. Mustang Competition Wheel Studs
j persons likes this.
Darrell George
'66 Fastback
66stangFb is offline
post #5 of 13 (permalink) Old 07-29-2018, 07:20 PM
If your front brakes are like the 2 piece rotors on my '69, these are the ARP wheel studs that worked for my car:
https://www.jegs.com/i/ARP/070/100-7707/10002/-1
They were actually a bit short for thick Weld Wheels so I switched to one piece front rotors that used more reasonably priced long wheel studs that worked with the Weld Wheels.
afrett is offline
post #6 of 13 (permalink) Old 09-25-2018, 12:58 PM
app01's Avatar
I used those same ARP ones on my 70 that afrett mentioned. The are very nice.
Comparison to a standard stud:
www.PalmieriConcepts.com custom showboards
9.911 @136.86(still practicing)
70 Mach 1 w/Boss 460 Stroker Engine, 670HP N/A-Build http://forums.vintage-mustang.com/bu...ld-thread.html
70 Boss 302-May 70, Dearborn-Build http://www.palmiericoncepts.com/My-M...970Boss302.htm
62 Corvette-Build http://www.palmiericoncepts.com/My-M...roon/index.htm
MCA, MCCNE Member
app01 is offline
post #7 of 13 (permalink) Old 09-25-2018, 02:19 PM Thread Starter
gikort's Avatar
Those look great. Thank you for replying, I'm about to upgrade pads and I want to do this at the same time.
gikort is offline
post #8 of 13 (permalink) Old 09-25-2018, 02:33 PM
j persons's Avatar
About the only way to be sure of what you need is to knock one of the old studs out and measure the stud hole To get an accurate measurement, measure in an area that hasn't been deformed by the splines. ARP may be the only ones that are strong enough to use with wheel spacers or excessively offset wheels. Their thread tolerances are much tighter than most others, especially OEM studs.
F-150 SCab daily driver
j persons is offline
post #9 of 13 (permalink) Old 09-26-2018, 06:21 PM Thread Starter
gikort's Avatar
It's looking like the only ones that fit the 2-piece rotor are the expensive ARP ones @app01 posted because of where the knurls are located. Lots of cheaper options for the rear.
gikort is offline
post #10 of 13 (permalink) Old 09-27-2018, 12:24 AM
rpm
rpm's Avatar
I've bought a lot of ARP fasteners, been to their plant, and toot their horn as often as I can, but...good Lord are those wheel studs expensive!
Bob
There are 2 types of people, those who own pickups and those who borrow them.
69 M code Mach 1, 393w AFR 185, AOD trans, 3.50 traction lok N case, 13" 01Cobra 4 wheel disc, QA1 4 wheel coil covers, Chromo tube susp arms, Triangulated rear arms, Convertible inner rockers & seat riser, 8 point roll bar.
Build Pics http://s782.photobucket.com/user/rob...?sort=3&page=2
Build Thread
http://1969stang.com/forum/index.php...bitch-is-back/
rpm is offline
post #11 of 13 (permalink) Old 09-27-2018, 07:29 AM
app01's Avatar
Expensive like gold-- hey they are gold colored
MCA, MCCNE Member
app01 is offline
post #12 of 13 (permalink) Old 09-27-2018, 08:55 AM
j persons's Avatar
ebay is your friend
https://www.ebay.com/p/ARP-Auto-Raci...4588951&chn=ps
post #13 of 13 (permalink) Old 09-28-2018, 09:28 PM
rpm
rpm's Avatar
Originally Posted by j persons View Post
ebay is your friend
OK. The ad I was in shock over listed them for $75. $70 is still crazy for 5 studs, but I have no doubts about their quality.
Bob
Build Thread
rpm is offline
