255/50/16 RA1s on a 8" wide rim - Page 2 - Vintage Mustang Forums
 5Likes
post #16 of 20 (permalink) Old 05-06-2019, 08:17 PM
Mutang's Avatar
I have done so much to the body I have no idea what stock clearances are. Anything is possible with enough hammer work welding and bondo.
Mutang is offline
post #17 of 20 (permalink) Old 05-07-2019, 08:43 AM Thread Starter
They fit with no mods on the passenger side. On the drivers side I have to center the wheel in the opening and the roll the lip it looks like.
1969 coupe
372 Cleveland, 4 speed, 9" T.50 Trac Lock axle, Toploader, Global west suspension, Big Lincoln Trans Am Brakes front, Eldorado caliper/ MK VII disk rear.
Jsams is offline
post #18 of 20 (permalink) Old 07-05-2019, 03:36 PM
Eastwood Tool
Eastwood makes a nice tool to roll the lips. Bolts on to the wheel flange.
Oldhenry1 is offline
post #19 of 20 (permalink) Old 07-08-2019, 09:40 AM
Huntingky's Avatar
Just to add to the confusion, brand of the tire can make a huge difference. I had a Sumitomo 255 tire mounted on an 8 inch rim to do some clearance testing on the front end. I currently have some 245 Nexens on front. Surprise! The supposedly wider Sumitomo's aren't. The Nexen's seem to be closer to manufacturers specs. I wouldn't have been too surprised if they had been about the same width but to be a totally size diff in other direction was something else.
Coyote build in 65 GT Fastback in body work https://forums.vintage-mustang.com/b...e-powered.html and on Facebook @65gtmustang
F150 SCREW Ecoboost as my daily
66 Emberglow Coupe first car,71 Torino GT, 82 Fastback slooooow 6 banger, 71 Boss 351, 85 GT all long gone
Huntingky is offline
post #20 of 20 (permalink) Old 07-09-2019, 05:59 AM
j persons's Avatar
Check ebay for that wheel lip tool, a bunch cheaper and some of the ebay fender lip rollers are identical to the Eastwood tool.
F-150 SCab daily driver
j persons is offline
