255/50/16 RA1s on a 8" wide rim - Vintage Mustang Forums
 5Likes
post #1 of 20 (permalink) Old 04-20-2019, 06:01 PM Thread Starter
Guys,
There is a lot of conjecture out there on max tire size for an 8" wide rim.
I have found a pretty good deal on a pair of 255 wide RA1s and Tire Rack's web site says they will "fit" on my 8" wide rims.
My question is, will the tire be supported enough to not feel squishy in turn in?
1969 coupe
372 Cleveland, 4 speed, 9" T.50 Trac Lock axle, Toploader, Global west suspension, Big Lincoln Trans Am Brakes front, Eldorado caliper/ MK VII disk rear.
Jsams is offline
post #2 of 20 (permalink) Old 04-20-2019, 06:17 PM
your good 16x8x4.5 225/50/16. @dobrostang has a formula for rim vs tirewidth
I actually run 16x7x4.5 with a 1" adapter with 225/50/16 with fair results
2nd 66 is offline
post #3 of 20 (permalink) Old 04-20-2019, 06:59 PM Thread Starter
First of all, this is for a 69 mustang and I already have 225s and looking for more contact patch. I can certainly run larger tires than 225s on the front.
Thanks for the reply.
1969 coupe
Jsams is offline
post #4 of 20 (permalink) Old 04-20-2019, 07:01 PM
Sorry read it wrong, I thought I read 225. I see now it says 255 ,long day
2nd 66 is offline
post #5 of 20 (permalink) Old 04-20-2019, 08:56 PM
Ideally, 225 is the perfect tire for for a 8” rim. RA1’s are pretty sticky. They’re probably going to roll over a bit on you.
2nd 66 likes this.
patrickstapler is offline
post #6 of 20 (permalink) Old 04-20-2019, 09:30 PM
dobrostang's Avatar
THe story I understand is that you want your side walls to be parallel as possible. This puts a flat contact patch on the ground. 0.9 to 1.1 times the rim width. Yes many will tell you they got a 315s on a 5" rim and it handled great, I have no idea if what I heard is right but my 225s on 8"rims are a delight to drive on the track or autocross so I'm sticking with it, call it a superstition but hey - its an internet forum you didn't expect a scientific answer did you? I did'm\nt do so good in science - was kinda hard.... ;o)
2nd 66 likes this.
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
post #7 of 20 (permalink) Old 04-20-2019, 10:27 PM Thread Starter
I have seen a similar formula that says .85 to 1.00 of tread width...
So using that formula, 245 is the widest you can run on an 8 inch without Ill effects.
Russstang likes this.
1969 coupe
Jsams is offline
post #8 of 20 (permalink) Old 04-22-2019, 08:46 AM
I disagree, even the Mfg. has a suggested range of 7-9" for that size tire. I run "oversize" tires, ( 275/35-18 on a 9" wheel ) on my Boxster. I didn't feel any extra "squishiness" or "ill effects". Your 8" is right in the middle of the range, you'll be fine. Those numbers are ideals in theory, but most of use don't have the luxury of changing wheels every time we make a tire change ! IMO section width around 1" wider than the wheel is perfect for most situations, that's where modern Z06's and Porches are at. I think section=rim width is a bit stretched.
Huntingky and rpm like this.
'65 A-code coupe, T-10 4-speed, 8" 3.25 limited slip
stephen_wilson is offline
post #9 of 20 (permalink) Old 04-22-2019, 12:27 PM
jdub's Avatar
Every tire is different. You'll look at ten different 225s that have different tread widths. 225 may in be in the ball park for an 8" but other sizes can probably fit and not be in a sub-optimal situation.
Personally, I think 255 is pushing it on an 8" rim. Only real way to know is to try it out.
1965 Mustang
jdub is offline
post #10 of 20 (permalink) Old 04-23-2019, 07:55 AM Thread Starter
Well Iím going to try it ....
Jsams is offline
post #11 of 20 (permalink) Old 04-23-2019, 06:12 PM
Mutang's Avatar
Been doing it for years on the track. no issues what so ever. Have even gone with 275/45/16. 255/50/16 toyo ra1's are the best track tire I have ever run so far.
Mutang is offline
post #12 of 20 (permalink) Old 04-23-2019, 08:52 PM Thread Starter
I figure that 255s on the front ought to increase grip...
1969 coupe
Jsams is offline
post #13 of 20 (permalink) Old 05-04-2019, 03:24 PM Thread Starter
Ok, they are on the wheels and on the car. The drivers side has less tire clearance. I’ll have to install upper arm shims and then lengthen the strut rod to center the wheel in the arch. Then roll the fender.
One step forward, two steps back....
1969 coupe
Jsams is offline
post #14 of 20 (permalink) Old 05-04-2019, 09:44 PM
We can only lead you to the water...itís all up to you after that.
post #15 of 20 (permalink) Old 05-04-2019, 10:39 PM Thread Starter
I donít think clearence was ever discussed in this thread,
My cars body is shifted to the drivers side about 3/8Ē when measured from side to side.
Jsams is offline
