Gearing for the track - Vintage Mustang Forums
 6Likes
  • 1 Post By 2nd 66
  • 1 Post By patrickstapler
  • 1 Post By Garth66
  • 1 Post By GT350HR
  • 1 Post By Mutang
  • 1 Post By Sandy Ganz
post #1 of 14 (permalink) Old 07-02-2019, 03:01 PM Thread Starter
Sparky66's Avatar
Looks like I'm looking at new rear gears. It will (eventually) be paired with a WC T5, but for now it'll be with my C4.
Current gears are 3.23. Tires are 25.65" tall.
Speeds on track range from 35mph-120ish.
Thinking either 3.25s or 3.40s should work well. What does everyone else run? Thoughts?
1966 Restomod/track car, 1973 Q-code Mach 1, 1997 F250 diesel, 2000 VW Beetle Rallycross car, 2010 Crown Vic (ex-City of Lakewood PD), 2015 Focus ST-2
Sparky66 is offline
post #2 of 14 (permalink) Old 07-02-2019, 07:39 PM
Chad-1stGen's Avatar
I'm running 3.70's with a T56.
If you look at a final drive ratio of 1:1 (for your C4 or 4th gear on the T5) then your tire height and 6500 RPM yields a top speed with 3.23's of 153 mph which is much higher than your intended usage. 3.70's give a top speed of 134 mph at 6500 RPM.
Are you strictly interested in track performance or also freeway manners?
Also, there are a few tracks out there where you can most likely exceed 120mph.
Chad-1stGen is offline
post #3 of 14 (permalink) Old 07-02-2019, 08:27 PM Thread Starter
Sparky66's Avatar
I don't want my engine to implode, so I limit it to 4800. 4000 on the C4 is ~94mph. 4000 with the T5 and with 3.25s would be 149mph, with 3.40s would be 142mph, and with 3.55s would be 136mph. My concern is that 3.55s might be too deep, and I might do too much shifting on a road course, using 5th for just the straightaways...but maybe that's not a terrible thing?? I like having options though lol.
I don't often run it on the highway, mainly because of the C4/3.23 combo it has now.
Sparky66 is offline
post #4 of 14 (permalink) Old 07-02-2019, 08:39 PM
4800? That is very low.
I lapped CMP in 3rd and 4th with 3.50 rear gear.
I would at lest run 3.70 for rear gears.
1969 coupe
372 Cleveland, 4 speed, 9" T.50 Trac Lock axle, Toploader, Global west suspension, Big Lincoln Trans Am Brakes front, Eldorado caliper/ MK VII disk rear.
Jsams is offline
post #5 of 14 (permalink) Old 07-02-2019, 08:43 PM
I like my 3.40TL behind my 3.35/.68 T-5
Sparky66 likes this.
2nd 66 is offline
post #6 of 14 (permalink) Old 07-02-2019, 08:45 PM
I used to open track a Ď83 GT. After I grenaded my T5 and 7.5Ē rear, I changed to a WC T5 and a 8.8Ē with 3.73ís. It was OK...needed 3.89 or 4.11 to get out of the turns better. Also depends on the track. Small and technical, or long and speedy. Donít be afraid of imploding your engine. Should be good to at least 6000 on a regular basis. Itís only o key to be there for a few seconds at most anyway.
patrickstapler is online now
post #7 of 14 (permalink) Old 07-03-2019, 04:11 PM Thread Starter
Sparky66's Avatar
The tracks I run on - Pacific Raceways and The Ridge - are mostly technical, with lots of tight turns and only really a single straight away.
My friend/mechanic who's helping with all this wants me to put in a Toploader...but I don't see why? I know they're bulletproof, but don't they also have 1.0 4th gear like 3rd on the C4? I fail to see his reasoning, but what do I know lol.
I'm still undecided and have a tentative track day on the 23rd. Arggggg.
Sparky66 is offline
post #8 of 14 (permalink) Old 07-03-2019, 05:04 PM
Garth66's Avatar
If you don't want to 'impolde' your engine, then the most important thing is to make sure you're using a quality baffled Road Race oil pan from someone like Aviad, Armando or Kevko. You don't want a street or drag pan as the baffling won't help you in those tight technical turns.
________________________
66 Mustang GT Fastback
70 Mustang Mach 1
72 DeTomaso Pantera
69 Cutlass Convertible
Garth66 is offline
post #9 of 14 (permalink) Old 07-03-2019, 05:08 PM
I'm not trying to insult you but it takes a fairly healthy engine to pull 120 mph @ 4,800 rpm. A 3.80 (8" I assume you have) would be good for Pacific raceway's long straight. Your mechanic is suggesting a four speed for better ratio selection in lower speed corners. It would make you faster that you are with the C4. If you are going to a T5, make sure you get one with the 2.95 low as the standard 3.35 low might be too much rpm in a lower gear and not enough in a higher gear due to the "wider" ratios. That is a technical track for sure.
Randy
'66 GT350H-3 time cover car - Car Craft July'77,Modified Mustangs and Fords Feb2011 ( w/article), Mustang Monthly June 2014. Bracket raced by me for the last 44 years. Yes it is a real one.
'68.5 R code GT fastback
'67 Ranchero 408W -427 glass hood
'78 F350 "Oleynik" car hauler
Ford Experimental parts collector
GT350HR is offline
post #10 of 14 (permalink) Old 07-04-2019, 03:56 PM
Mutang's Avatar
Gearing will depend on a few factors. You gave speed, tire height and possible transmission, what motor are you running and where will it make the best torque and hp and what rpm range does it make it? When I was running 289/302 engines, gearing was 456, 411, and 370. Went to a 351 and gearing was 370 and 350. Later went to a stroker and gearing is 350 or 325 all depending on the track.
Mutang is offline
post #11 of 14 (permalink) Old 07-04-2019, 04:13 PM
Mutang's Avatar
With the spec's in your post, you will need a 300 gear to give you 120mph @ 4800. fast, cheap, durable ... you can only pick 2
Mutang is offline
post #12 of 14 (permalink) Old 07-05-2019, 11:34 AM Thread Starter
Sparky66's Avatar
Randy
No insult taken - I'm spinning closer to 5k to get to 120mph. I just used the 4k as a comparison with the different gears.
Warmed over 289. Power band is about 2600-3400.
Funny you should mention a 3.00...I'm "borrowing" a friend's 3.00 3rd member this weekend - not to keep permanently, but just to narrow down the cause of the noise, to see how bad of shape the current gears are, and to buy me time to order new ones and get the 3rd rebuilt.
While I would LOVE to get lower gears, the T5 install is a ways off, and I need to run this car with the C4 for the foreseeable future. It sucks, as I would rather do it all at once and be done with it, but I'm still about $1300 short of the T5 conversion. Grrrr. Thanks all for the advice!!
Sparky66 is offline
post #13 of 14 (permalink) Old 07-17-2019, 12:50 PM
Sandy Ganz's Avatar
I did A helpful tool for determining gearing a while back. Helpful to get an understanding of top speed and shift point given transmission, rear end ratio and tire size.
Works better on a desktop then phone.
http://www.gtsparkplugs.com/GearCalc.html
Sandy
2nd 66 likes this.
65 Mustang Fastback 331 Alloy block, Global West Front and Rear suspension, Dry Sump in process, other stuff...
All my projects at GTSparkplugs
Sandy Ganz is offline
post #14 of 14 (permalink) Old 07-25-2019, 03:23 PM
66coupe289's Avatar
3.00 gears and a C4 for track use? How did that go? I expect you found going from 3.23 to 3.00 was the wrong direction. Did you run out of power on the top end before you run out of RPM range on the long straight?
My street car evolved from C4 w/3.00 to C4 w/3.55 to T5z w/3.55 all running 225r14-60 tires. I cannot imagine a road course scenario where the 3.00 would be over a 3.55, for a warmed up 289.
Shelby delivered cars with 3.89. A friend that vintage raced a '65 GT 350 typically used a 4.11 on tracks such as Mid Ohio.
Chris (Sussex, WI)
289 w/AFR 165, T-5z, 3.55T-loc, Granada Discs and 6 bolt Moto-Lita Steering Wheel
66coupe289 is offline
