Mustang Dry Sump Project - Vintage Mustang Forums
 6Likes
  • 2 Post By Sandy Ganz
  • 1 Post By Sandy Ganz
  • 1 Post By c6fastback
  • 1 Post By BNFab
post #1 of 11 (permalink) Old 07-17-2019, 01:01 PM Thread Starter
Sandy Ganz's Avatar
Finally catching up on starting the documentation on the dry sump project. Been putting some pics here but was rather ad hoc.
Finally created a detailed project page. Lots more to post but it's a start...
http://www.gtsparkplugs.com/Ford-Dry-Sump-Project.html
Sandy
2nd 66 and Tom65 like this.
65 Mustang Fastback 331 Alloy block, Global West Front and Rear suspension, Dry Sump in process, other stuff...
All my projects at GTSparkplugs
Sandy Ganz is offline
post #2 of 11 (permalink) Old 07-17-2019, 01:27 PM
Question: what does the "Wix Racing Filter (51222R) Yes the 'R' is for racing" have to offer that a FL-1A can't ?
2nd 66 is offline
post #3 of 11 (permalink) Old 07-17-2019, 03:14 PM Thread Starter
Sandy Ganz's Avatar
FL1 is likely a filter that would have worked great. Pre-oiler was available for them as well.
The FL1 possibly has smaller particle capture ability. Down side is flow. In a quick discussion a while back with peterson I asked smaller or larger style and they didn't give much advantage other then flow. My thinking was similar to have higher flow due to leaky nature of the aluminum engine.
Also found many anecdotal stories of quality and praise of the larger Wix type R filters with the downside of unclear micron filtering capabilities. To some it was like which brand of synthetic oil is best. Was very clear to steer clear of Fram filters (not intending to have any follow up on the Fram comment)
I have previously ran a canton mecca filter and while they seem to a good job filtering I always felt (anecdotally) they were very restrictive.
Long and short of it just giving it a try.
The comments were about R for race was a bit tongue and cheek 😉
Sandy
2nd 66 likes this.
post #4 of 11 (permalink) Old 07-21-2019, 09:40 PM
Still running the Dambest carb?
1969 coupe
372 Cleveland, 4 speed, 9" T.50 Trac Lock axle, Toploader, Global west suspension, Big Lincoln Trans Am Brakes front, Eldorado caliper/ MK VII disk rear.
Jsams is offline
post #5 of 11 (permalink) Old 07-21-2019, 10:13 PM Thread Starter
Sandy Ganz's Avatar
Yes. Have a couple. Seem to work well.
post #6 of 11 (permalink) Old 07-21-2019, 10:36 PM
c6fastback's Avatar
Send a message via AIM to c6fastback
Just looked up that carb builder. Those are some expensive carburetors.
j persons likes this.
68 302-4V w/1.84",1.54" ported , Comp XE268H , 2200 rpm Hughes converter, 3.25 9" w/10x2.5" shoes , MSD box/distrib , RPM intake , 670 Holley , cross flow aluminum radiator , Granada discs......
Michael S.
c6fastback is offline
post #7 of 11 (permalink) Old 07-27-2019, 09:47 PM
Its probably twice as big, go look at one at the store they are huge... I use them on my track car, I wouldnt use the R filters on anything but a race vehicle.. The will free a small amount of power due to being less restrictive, but they wont filter as small of a particle.
2nd 66 likes this.
BNFab is offline
post #8 of 11 (permalink) Old 07-28-2019, 01:41 PM Thread Starter
Sandy Ganz's Avatar
Their are a couple of filter elements used in that style of filter. The 5222R is the finer filter out of the bunch made for dirt applications. That being said no specs given.
Here is a link to the Wix racing page.
http://www.wixfilters.com/Speciality/Racing.aspx
The Peterson remote filter adapter is available in a few thread type for filters so you can use GM style, FL1 or even FL1995 Diesel filter if you want even more capacity.
Overall not worried about filtration with the 5222R in my application. The main idea was really the pre-lube capability of the remote.
Sandy
post #9 of 11 (permalink) Old 07-28-2019, 01:51 PM Thread Starter
Sandy Ganz's Avatar
A made in China pro series race carb from Holley is in the 800 buck range and will still need to have someone go through it as they are not well tuned. The place that put my enging together was amazed how well it worked out of the box. All made in USA 🇺🇸 too.
c6fastback likes this.
post #10 of 11 (permalink) Old 07-28-2019, 04:41 PM
Pro comp/speedmaster tried to make a copy of the Dambest billet body and failed miserably.
Those Dambest carbs rarely come up for sale used. I have tried to buy a few with no luck.
I believe the booster is in a different location in the Venturi than a Holley has.
1969 coupe
Jsams is offline
post #11 of 11 (permalink) Old 08-03-2019, 01:00 PM
Dry Sump
I made the lines several years ago for a 5 stage pump in a Hydroplane. Be careful with the hose length especially from the pan to the pump. There's an order for installation and removal. The angle of fittings will also come into play. We had a low budget team and didn't have any of the fitting insertion tools and hose cutting tools that are available now. Would've made life much easier.
Take your time, you'll be glad you did.
Oldhenry1 is offline
