Clutch Press plate suggestions? - Vintage Mustang Forums
 2Likes
  • 1 Post By j persons
  • 1 Post By awhtx
post #1 of 12 (permalink) Old 10-08-2019, 12:53 AM Thread Starter
Ok, piecing together T5 parts and trying to select a decent clutch/pp combo. I admit I've run built automatics all my life so your recommendations are useful here. I'll keep it simple, T-5 conversion, 3:80 trutrac rear, and roughly 325hp out of an early 302. This motor sees 6k+ regularly in autocross which is roughly 90% of my time. I am admittedly overwhelmed by the # of manufacturers and quantity of parts. Stock isn't gonna cut it, but dual clutch is an overstatement. Suggestion on reputable performance clutches/pp would be helpful here. I'm leaning towards a diaphragm type with a lighter weight fly wheel, partly due to my aarp status.
groho is offline
post #2 of 12 (permalink) Old 10-08-2019, 08:45 AM
j persons's Avatar
I used a Centerforce dual friction disc and PP combo in my FF Cobra with no problems. The engine was a 331 with aprox 420 HP, custom T5 box and a 3.55 rear axle ratio. Light actuation, no clutch shudder or anything weird. It would easily boil a set of 315/35/17 tires.
capemustang likes this.
F-150 SCab daily driver
j persons is online now
post #3 of 12 (permalink) Old 10-08-2019, 09:11 AM
awhtx's Avatar
I have a 164T flywheel on my 302 so I use an 11" Centerforce clutch for a FE (390/427/428). It has the standard 10 spline hub.
awhtx is offline
post #4 of 12 (permalink) Old 10-08-2019, 10:14 AM
LeeFred's Avatar
The first question to ask is what flywheel do you have now and are you going to stick with it?
LeeFred is offline
post #5 of 12 (permalink) Old 10-08-2019, 12:00 PM
maladezo's Avatar
I am no expert, but it seems to me a lighter FW would be good for autocross. Just don't go too light. The diameter of the PP will influence the overall weight of the FW. Research the weight, could take some serious thought. I would have a machine shop balance the PP/FW combo. Diaphragm PP is always my preference. Just get a good one. I run a McLeod clutch. Perfection Clutch is questionable quality. Careful about really stiff racing clutches.
'67 coupe, 390, 4spd.
maladezo is offline
post #6 of 12 (permalink) Old 10-08-2019, 01:52 PM Thread Starter
That's the good parts, I haven't selected a flywheel yet, plan to run something around 15lbs, 157 tooth, 28oz, not too light to stall at idle but light enough to allow me to spin up faster. If I can find a complete combo, that would be great.
groho is offline
post #7 of 12 (permalink) Old 10-08-2019, 06:09 PM
I run this flywheel. Pretty sure they have 164T also if thatís what you need.
https://www.summitracing.com/parts/ctf-900220
Spins up fairly quickly.
Iím using a standard RAM 3 finger and Toploader, so I canít help there.
patrickstapler is offline
post #8 of 12 (permalink) Old 10-09-2019, 08:04 PM
Nailbender's Avatar
I'll be following this thread. The clutch setup I got with my MDL conversation was for a cruiser not an autocrosser. I pretty much fried it trying to launch in second gear.
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, FPA Headers, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is online now
post #9 of 12 (permalink) Old 10-09-2019, 09:18 PM
j persons's Avatar
Which one did you get? They sold me the Kevlar clutch, the car is still in pieces so I haven't had an opportunity to run it yet. If that doesn't work I guess a twin disc in in my future.
post #10 of 12 (permalink) Old Yesterday, 07:51 PM
Nailbender's Avatar
My clutch and pressure plate were listed as "Super King Cobra" that ended up being on of those decent Korean packages that are popular on eBay. I've bought similar before and they work good on the street. Given my Sciatica I'll sadly be looking at the twin disc setup.
post #11 of 12 (permalink) Old Today, 08:05 PM
cheapbastard's Avatar
Look at National Parts Depot. I believe they have a diaphragm pressure plate with a Long style bolt pattern. I currently have a diaphragm pressure plate and had a Long for years and I don't know that I can tell the difference.
It sucks to get old but at least the expectations are lower. 65 mustang coupe, 306, 10.4 compression, 180cc homeported Chinese heads, funnel web, t5z, 4.56 gears in a 9 inch locker
cheapbastard is offline
post #12 of 12 (permalink) Old Today, 09:35 PM
I'm using a DURALAST diaphragm kit from AZ without issue ,although even with 11.39 SLR I wouldn't try to "launch" in 2nd
2nd 66 is online now
