Track car pics - Page 16 - Vintage Mustang Forums
 118Likes
post #226 of 252 (permalink) Old 12-12-2018, 12:50 AM
Originally Posted by Sik66 View Post
Recently got to make a couple of full passes. Still dialing in the suspension. 12.30's @112
drive train specs ?
2nd 66 is offline
post #227 of 252 (permalink) Old 12-12-2018, 01:00 AM
Ponyboy's Avatar
Originally Posted by 2nd 66 View Post
drive train specs ?
Hey that's my line!
I failed and didn't ask eveyone how to spend more money on my Mustang.
Huntingky and 2nd 66 like this.
66 coupe, '93 Fox seats, Three point belts, 289, Edelbrock, Weiand, JBA tri-y's, 2" duel exhaust (H-pipe), T5 trans(3.35), Pro 5.0 shifter, 3.40 open, KH front disc, Porterfield R4-S pads, 1" front sway bar, Shelby drop, Spring perch relocation, Shelby quick steer, GT progressive coils (1/2 coil cut), 4.5 leaf mid-eye, Bilstein street shocks, Export brace, Monti-Carlo bar, Sub-frame connectors, Performance alignment (+3.5 caster/-.5 camber), 16x7 wheels, 215/55/16 & 225/55/16 BFG G-force
Ponyboy is offline
post #228 of 252 (permalink) Old 12-14-2018, 11:35 AM
Originally Posted by Ponyboy View Post
What are the details of your set-up?
I've realized I've done a lot of stuff to this car!
Engine/Transmission
• 1982 200 Block
• .30 over with flat top pistons
• Stock 1965 rods/crank
• 10:1 compression
• Classic Inlines aluminum head
• Classic Inlines 4 barrel intake
• Fitech Go Street fuel injection
• Clay Smith 264/274 cam
• 6 into 1 header with 2.5” exhaust
Driveline
• NWC T5 transmission
• 5.0 bellhousing machined to fit the 200 block
• Neutral balance ACT flywheel with stock replacement 5.0 diaphragm clutch
• 8” rear axle with trac-lok and 3.80 gears
Cooling
• Spal electric fan
• Champion V8 aluminum radiator
Fuel System
• Tanks Inc. in-tank EFI system
• LS-style fuel filter
Front Suspension/Brakes
• Converted to V8 specs
• Shelby Drop
• Stock upper and lower control arms
• 1” front sway bar
• Street or Track strut rod
• Roller spring perch
• Manual 1” bore aluminum master cylinder
• Street or Track Trans Am front brakes (12”x1.25" Galaxy-based)
• Bilstein shocks
Rear Suspension/Brakes
• Mid-eye 4 leaf springs
• Fays2 Watts Link
• Bilstein shocks
• Stock 10” drum brakes
Ignition/Electrical
• Custom-curved HEI-style ignition
• American Autowire Classic Update harness
• Rear mounted Odyssey battery
• 94 amp 3G alternator
Wheels/Tires
• Rev 100; 15x7 front and 15x8 rear
• 205/60/15 front and 225/60/15 rear
Steering
• 2005-2010 Toyota Prius Electric steering
• Flaming River 16:1 box
• Shelby Quick-Steer roller pitman/idler arm
Other Features
• GT350 fiberglass front fascia
• Fiberglass rear bumper
• Fiberglass stock-style hood with NACA ram air
• Original paint (mostly)
• Custom Monte Carlo/Export bars
• Custom motor mounts
• 67-style roll hoop with provision for 4 point harnesses
• 66-style rear seat delete
What’s next?
• GT35 Turbo (~5-7lbs. boost)
Huntingky, 120mm and 2nd 66 like this.
gus91326 is offline
post #229 of 252 (permalink) Old 12-16-2018, 09:42 AM
Ponyboy's Avatar
Gus91326, Totally surprised me you built a 6 into a race motor. Great list, thanks!
Ponyboy is offline
post #230 of 252 (permalink) Old 12-16-2018, 04:56 PM
Thanks! I wouldn't call it a race motor, but It's definitely healthier!
gus91326 is offline
post #231 of 252 (permalink) Old 12-16-2018, 05:57 PM
silverblueBP's Avatar
Any in car video?
Mark
2nd 66 likes this.
-Mark-
1966 Mustang 2+2
silverblueBP is offline
post #232 of 252 (permalink) Old 12-16-2018, 08:09 PM
Originally Posted by silverblueBP View Post
Any in car video?
Mark
Just this weekend I got my gopro mount set up in the car- next time for sure!
silverblueBP likes this.
gus91326 is offline
post #233 of 252 (permalink) Old 12-16-2018, 08:12 PM
.30” over 200 cubic inches...what does that make it exactly?
patrickstapler is online now
post #234 of 252 (permalink) Old 12-16-2018, 10:09 PM
202 ci.
gus91326 is offline
post #235 of 252 (permalink) Old 12-17-2018, 12:10 AM
Sik66's Avatar
331 with 9.25 CR
Out of the box AFR 185's
Comp cams 294S
Air gap with Proform 750
Doug's Tri Y's / 2 1/2 full exhaust
Toploader
Narrowed 8.8 with 3.73's and a Tru Trac
Sik66 is offline
post #236 of 252 (permalink) Old 12-17-2018, 07:12 AM
331 with 9.25 CR
Comp cams 294S
Toploader
I’m thinking, there’s something missing here.
Mark
-Mark-
1966 Mustang 2+2
post #237 of 252 (permalink) Old 12-17-2018, 07:30 AM
Mark
As in pictures?
post #238 of 252 (permalink) Old 12-27-2018, 11:35 PM
Hey, nice pictures. Seems like you had a nice track trip.
Maribelsutton is offline
post #239 of 252 (permalink) Old 05-11-2019, 05:01 AM
Sik66's Avatar
Just installed a Weiand mini blower. First pass went 11.60 @ 120
File Type: jpg IMG_20190324_094624_001_1557565112631.jpg (1.30 MB, 25 views)
File Type: jpg FB_IMG_1555387302381_1557565257762.jpg (130.5 KB, 20 views)
Huntingky, 2nd 66 and 68Ghost like this.
Sik66 is offline
post #240 of 252 (permalink) Old 05-18-2019, 12:36 AM
very nice setup!!
Tom65 is offline
