'64 Falcon Race Car Build - Page 2 - Vintage Mustang Forums
 7Likes
post #16 of 105 (permalink) Old 07-01-2014, 11:50 PM Thread Starter
Originally Posted by stephen_wilson View Post
That cage really needs a diagonal in the main hoop plane.
FIA Appendix K K-11 modification. The diagonal attaches from the R rear of the main hoop to the L rear mounting point rather than in the main hoop plane.
iufan993 is offline
post #17 of 105 (permalink) Old 07-02-2014, 08:32 AM
It may meet the spec , but IMO it will be stronger/safer with the added diagonal that SCCA requires.
stephen_wilson is offline
post #18 of 105 (permalink) Old 07-02-2014, 02:25 PM Thread Starter
SCCA recs...
2. Main Hoop Bracing
a. Main hoops shall incorporate a diagonal brace. The brace
shall either be in the plane of the main hoop, or extend
from the top of one rear brace (described in 9.4.B.2.c) to
the bottom of the opposite rear brace.
iufan993 is offline
post #19 of 105 (permalink) Old 07-02-2014, 03:47 PM
I see there is an alternate configuration, but there still is a benefit to adding that diagonal. My comment was informational, you can obviously do as you please.
66stangFb likes this.
post #20 of 105 (permalink) Old 07-10-2014, 10:21 PM Thread Starter
Rear suspension nearly complete
Lots of work last few days: Maier Panhard assembly welded, 9 inch 3.89 with Strange 3rd member and 31 spl. Moser axles assembled. New leaf springs and bushings, and Master Power drum brake kit with Porterfield R4S shoes. Everything painted and finally on the ground...
iufan993 is offline
post #21 of 105 (permalink) Old 07-10-2014, 11:20 PM
silverblueBP's Avatar
Awesome build!
-Mark-
1966 Mustang 2+2
silverblueBP is offline
post #22 of 105 (permalink) Old 07-11-2014, 12:47 PM
jeffreycustoms's Avatar
Looking good! I'm running the Master Power drum brake kit with Porterfield R4S shoes as well - I'm interested to hear what you think of the setup.
1968 Mustang Time Attack Racer - Build notes
jeffreycustoms is offline
post #23 of 105 (permalink) Old 07-13-2014, 02:23 PM
66KevinC-code's Avatar
Cool.
Some others, including that of Rowan Atkinson (aka Mr Bean):
Ford Falcon racing picture gallery¬*
Kevin
"One life, right? Don't blow it
66KevinC-code is offline
post #24 of 105 (permalink) Old 07-28-2014, 04:31 PM
jguinta's Avatar
Rear spring perches from Aftco - the slider style - may be something you want to look at. CA has them.
Very cool build - Love Falcons with attitude.
John Guinta
1965 GT350 comp clone
jguinta is offline
post #25 of 105 (permalink) Old 08-07-2014, 10:37 PM Thread Starter
Finally back to work
Progress on the engine last 2 weeks, but unfortunately no pics. Tacked subframe connectors tonight and installed rear Konis.
iufan993 is offline
post #26 of 105 (permalink) Old 08-09-2014, 10:26 AM
Looking good. Hope it works awesome for you.
Mike Maier is offline
post #27 of 105 (permalink) Old 08-14-2014, 08:18 PM Thread Starter
I think the rear end setup will be great with the leafs and the panhard bar. I have seen some of the British Falcons in vintage, and the rear suspension/leaf spring setups are very similar you yours, but unlike anything else I have seen for sale in the US.
I will certainly give you feedback. The panhard bar is a tight fit back there between the fuel cell and the diff, but I think it will be the trick to having some adjustability at the track.
Most of my track experience is 6+ years of Lemons and Chump car, where we have actually fabricated suspension parts and put together our own leaf springs. The best part of that racing is literally hundreds of hours of seat time, and I think I have a good feel for handling at the track, albeit with low horsepower RWD cars. This will be my first experience with high horsepower and bias ply RWD in a sprint race format.
I know I am working on a completely different level with great quality suspension parts from C.A., Opentracker, and Maier and look forward to getting to the track in Feb or March. By next summer I hope to field a car in SVRA/VDCA/HSR here in the southeast.
iufan993 is offline
post #28 of 105 (permalink) Old 08-15-2014, 12:47 AM
Good stuff! We just had a customer in a Falcon win a rally race in Africa that was 6000 miles long using that same stuff. It should be a good starting point. Drive the heck out of it, Would ya?
post #29 of 105 (permalink) Old 10-19-2014, 08:27 PM Thread Starter
After a hiatus of working on another car, and waiting on the engine, I can say that the motor is finally done. I don't do engine work, and the shop was 3 hours away, so progress was slow. I was trying to use my rare 2x4 intake, but ultimately it was too much of a headache for a reliable road race car. A single 4 with a Holley 650 ended up with the best dyno results. Will post the dyno sheets when I get a chance, but we got over 450hp with a 289 block .040 over. It's wound pretty tight, but overall really happy with the results. Worked on fitting the fiberglass doors and fenders this weekend. Now I should be able to make some more headway.
iufan993 is offline
post #30 of 105 (permalink) Old 10-22-2014, 09:04 AM Thread Starter
Engine!
1965 289 block, .040 over, JE custom pistons, GT-40 iron cyl heads, Comp cams bolt down adj. rockers, Comp cams custom cam, 3.00 stroke Eagle crank, Crower roller lifters, Canton racing pan, Edlebrock Vic Jr. manifold, Holley 650, MSD dist.
iufan993 is offline
