i need to trade intakes - Page 2 - Vintage Mustang Forums
post #16 of 27 (permalink) Old 03-26-2009, 06:08 PM
What size are the head bolts? If they are 7/16 you have a 302 if they are 1/2" you have a 351W.
69 Mustang Sportsroof 351W 5 Speed
Itsmystang is offline
post #17 of 27 (permalink) Old 03-26-2009, 11:12 PM
That looks like a 302 block, a 351 has a metal ridge by the distributor hole. I take a pic of mine soon.
John L. Anschutz
Allen, TX
68 Diamond Blue Coupe - 302 (Dia)
68 Acapulco Blue Coupe - 351 (Frank)
janschutz is offline
post #18 of 27 (permalink) Old 03-27-2009, 09:22 AM
dm289's Avatar
Do you have a gasket kit for the motor? If it is a 289/302 gasket kit, see whether the intake manifold cork end gaskets fit the contour of the block. If they are too short then you have a 351. If the cork ends fit into the notches of the intake gaskets then somebody has modified your intake.
Reading your first post, you mentioned placing the intake on the motor, did you use gaskets at this point? Without gaskets the intake will not fit correctly, the gaskets are probably 1/8" thick each.
dm289 is offline
post #19 of 27 (permalink) Old 03-27-2009, 10:07 AM Thread Starter
1968mustang6's Avatar
here is a pic of the intake on the motor without gaskets. i dont think the gaskets will fill this gap. Will they? Plus what about the ridge at the top sides of the heads, they dont suppose to meet with the intake Let me know what yall think.
1968 Coupe, Grab-a-trak front and rear suspension, 302 HO, c4, 8 inch rear, 2005 split 5 star rims, making a modded california special.
1968mustang6 is offline
post #20 of 27 (permalink) Old 03-27-2009, 10:56 AM
302
1970 Mach I, 351C, 4-spd, Medium Gold Metallic, 1 of 1 with delivered options
1967 Shelby GT-500, Dark Moss Green with Parchment Interior (1 of 64), concours restored
unitedwestand212 is offline
post #21 of 27 (permalink) Old 03-27-2009, 12:30 PM
run 2 rows of silicone side-by-side and then one on top of the other 2. That will seal it.
John L. Anschutz
Allen, TX
post #22 of 27 (permalink) Old 03-27-2009, 01:40 PM
The_Dude's Avatar
I agree. A milled block, heads or manifold will cause that. The cork gasket for the ends is pretty worthless anyway. Silicone works wonders.
'69 Convertible 351w, 5-speed
'69 Mach 1 S-code, 4-speed
'70 Boss 302
'90 5.0 LX Notch
'04 Cobra
'17 GT350
The_Dude is offline
post #23 of 27 (permalink) Old 03-27-2009, 02:48 PM
That is definatley a 302, here is a 351
mock it up with gaskets, you might be surprised.
BigStudly is offline
post #24 of 27 (permalink) Old 03-27-2009, 03:36 PM Thread Starter
will the blue gasket stuff work well?
post #25 of 27 (permalink) Old 03-27-2009, 03:58 PM
if you are talking about RTV, yes, but I always use the Red just to be on the safe side.
post #26 of 27 (permalink) Old 03-27-2009, 08:30 PM
The_Dude's Avatar
The black stuff is supposed to be oil resistant.
'70 Boss 302
'90 5.0 LX Notch
'04 Cobra
'17 GT350
The_Dude is offline
post #27 of 27 (permalink) Old 03-29-2009, 10:59 AM
dm289's Avatar
Don't knock the cork end gaskets, they work if installed correctly. I used the stick on cork end gaskets with a very light skim coat of black RTV on the top where the intake rests and where the cork meets the intake gaskets. 5 years - 5K miles, I had no leaking issues before taking off the intake.
dm289 is offline
