Trade Lots of 65-70 Parts for 69-70 Console/Mirror/FB/428 Parts - Vintage Mustang Forums
post #1 of 10 (permalink) Old 12-23-2009, 09:50 AM Thread Starter
Send a message via AIM to 68stang289
Have the following to trade for some nice 69-70 Console parts. I need everything but the base. Car is a 4 speed car looking for the manual top plate (although if the trade is right for the automatic that will work too). Also looking for a passenger side 69/70 sport mirror. I also need the finish parts for the fastback rear by the package tray. I also need the upper clutch rod for a 70 428 SCJ. This is what I have:
Ford Mustang 289/302 Small Block Clutch Equalizer/Z-Bar
This came off of my 70 Mustang Mach 1 with a 428 SCJ but it is not correct for an FE. I believe this is for a 289/302 small black. This is the clutch equalizer/z bar. It's been repainted and is in fantastic shape.
1968/69 Ford Mustang Styled Steel Wheels
Two 1968/69 Ford Mustang styled steel wheels. I believe they are 14x6. 5 lug pattern. They have been sanded down a bit and sprayed with an acid etching primer. They were on the front of my 70 Mach 1 and seemed to run true and straight with no problems. Somewhere I have the GT center caps that go on here as well and if I can find them I will throw them in as well. No tires, just the wheels.
1965, 66, 67, 68, 69 Ford 289/302/351 Water Pump Pulley
This came off of my 1968 Ford Mustang 289. Should fit any 1965-69 Ford 289, 302 or 351 motor. This is a single grove pulley. Part number is C8AE 8A528F. It is in great shape.
1969/70 Ford Mustang Hood Scoop Turn Signal Lamps
Pair of Ford Mustang (or any Ford with the turn signal hood scoop I believe) turn signal lamps. There is some over spray on the lower parts but that will not be visible when installed. The lenses are in perfect shape. There is a minor pit or two on each but they are hardly noticeable.
New Ford 289 Cloyes Double Roller Timing Chain, Adjustable Sprocket
I picked this up new for my 1968 Ford Mustang 289 and never installed it. Cloyes double roller timing chain with 9 way adjustable sprocket. It is brand new in the box with instructions. Should work for any 289.
Cloyes says it's either 9-3535X9 or 9-3635X9 depending on the chain used.
1970 Ford Mustang Tail Light Bezels
I took these off of my 1970 Ford Mustang Mach 1. They are great for a driver car. 1 is in absolutely great shape and the other has some small pitting.
1967, 68, 69, 70 Ford Mustang Steering Box/Gear
Took this off of my 1970 Ford Mustang Mach 1 with manual steering. Should be a 16:1 ratio. Has part number C7ZR3550A, 9K29 and the tag reads SMB K 0A21B. It was in good working order prior to taking off.
New 1968, 69, 70 Ford Mustang Disc Brake Distribution Block
I purchased this brand new to install in my 70 Mustang for a disc brake conversion and ended up finding my old one. This is a brand new Scott Drake disc brake distribution block for a 1968-70 Mustang. Was taken out of the package but still includes everything it came with as new. Never installed.
1969/70 Ford Mustang Driver Side Racing/Sport Mirror
This came off of my 1970 Ford Mustang Mach 1 (will also fit 1969). The car was painted along with this mirror and it turns out I had two drivers side sport/racing mirrors that were painted so this one must go. It is in perfect shape. The glass is good with some normal very light minimal scratches in it (nothing major and it's not noticeable unless you are looking for it). It is currently disassembled. I also have the remote for this but it is disconnected.
**Would also trade for a nice passenger side sport/racing mirror.
Ford 260, 289, 302 Victor Reinz Gasket Kit
Victor Reinz Gasket Kit for a Ford 260, 289 or 302 motor. Not all of the gaskets are there, but it has quite a few of them. I can probably get a list of what is left if necessary. In perfect shape, just sitting in my garage.
1969/70 Ford Mustang Pop Open Gas Cap
1969/1970 Ford Mustang pop open gas cap. Number on the back is D0ZA9A112B. This is in driver condition. The emblem needs to be cleaned up but it would be decent for a driver.
1969/70 Ford Mustang Quarter Panel Extensions
Pair of 1969 or 1970 (I believe they should fit both years, they will fit 1970 for sure as that's what they were taken off of) Ford Mustang Quarter Panel Extensions for a fastback but may work for both coupe and convertibles as well (please double check this before purchase). These have been media blasted clean and primed to prevent any additional rust. They are in very good shape overall. The passenger side has some rust damage in the lower portion of it that has gone through. The drivers side has a small dent and some holes in the grove where the bumper would fit into. I was told it's fairly easily repairable.
1969/70 Ford Mustang Deluxe/Mach 1 Door Panel Lights
Pair of 1969 or 1970 Ford Mustang Deluxe/Mach 1 Door Panel Lights. There is some pitting on the chrome but the lenses are in fantastic shape. These would be perfect for a driver quality vehicle.
1965, 66 Ford Mustang Door Handles - You pay shipping?
Took these off of my 66 Mustang. They have some pits on the top area. They have new push latch mechanisms on them. Good for a driver if you're just looking for something to get by. You pay shipping and we'll call it a deal.
1965, 66, 67, 68 Ford 289/302 2 Grove Crank Pulley
Took this off of my 68 289 Mustang to install a 3 grove pulley. This is two separate one grove pulleys that bolt together. They worked great together and I had zero problems. Casting number says C7OE 6A312C. In great condition. Two groove pulley's retail for $90 so save big money over new! Should work for any 65, 66, 67, 68, or 69 Ford Mustang with a 289 or 302 or any Ford 289 or 302 motor. Please ensure proper fitment.
Ford 2V Carb and 2v to 4v Manifold Adapter
Autolite Ford 2 barrel carburetor with 4 barrel adapter plate. Also comes with Napa rebuild kit that has been opened so I'm not sure what is missing or has been replaced. It should be gone through before it is installed. Comes in original Autolite box with an original Autolite package with intake manifold gasket.
1965, 66, 67 and 68 Ford 289 Crankshaft Harmonic Damper/Balancer
I picked this up for my 1968 Mustang 289 and ended up selling the car before it was ever installed. It has Ford stamped into and is brand new. The number listed on it C82E6316 B1 1200. Should work for any 289.
1969-1970 Ford Mustang/Cougar Console Ash Tray
Ash tray for a 69-70 Ford Mustang or Mercury Cougar Console. In great shape. The chrome around it is in nice shape. It needs to be repainted and the inside of it cleaned out a little bit. Otherwise in great shape.
Lets work out a deal!
70 Mach I, 428 SCJ, 4 spd, 3.50:1, nicely built
06 GT Premium, 5 spd, iup, 18" polished aluminum bullitt rims - For Sale (PM me for info)
Pics Finally!
68stang289 is offline
post #2 of 10 (permalink) Old 12-23-2009, 09:47 PM
trashline's Avatar
I will trade you for the Z bar... Any of my custom parts or something from my list of parts to trade.
Brian
_____________________________________________
65 Mustang handfully modded Pics of progress
88 Tbird
06 Cobalt
BCP Custom
trashline is offline
post #3 of 10 (permalink) Old 12-24-2009, 08:43 AM Thread Starter
Didn't really see anything on there that I need trashline but feel free to make me an offer on it if you're interested!
Pics Finally!
post #4 of 10 (permalink) Old 12-24-2009, 10:51 AM
astang68's Avatar
top plate
i believe i have a top plate for a manual but will have to check it first, interested in the pop open gas cap
astang68 is offline
post #5 of 10 (permalink) Old 12-24-2009, 11:06 AM Thread Starter
Ok, keep me posted. I'm watching one on ebay right now that includes the mid-plate and ashtray but we may be able to work something out!
Pics Finally!
post #6 of 10 (permalink) Old 12-24-2009, 11:23 AM
trashline's Avatar
aside from parts I have nothing to offer...
Maybe a custom polished throttle rod to trade?
Brian
88 Tbird
06 Cobalt
BCP Custom
post #7 of 10 (permalink) Old 12-24-2009, 05:38 PM Thread Starter
Nah, thanks for the offer but I have a nice Lokar setup that I just put on my car.
Pics Finally!
post #8 of 10 (permalink) Old 12-25-2009, 08:07 AM
Disc brake distribution block.....
Does it have the proportioning valve also. If so how much?
Craig
68 Mustang GT Fastback S Code
428CJ 5SP Tremec[color:red][/color][color:blue][/color][color:blue][/color]
mushoss is offline
post #9 of 10 (permalink) Old 12-25-2009, 09:56 AM Thread Starter
Craig
No, it does not have the proportioning valve built in. It is just the distribution block for disc brake cars. Drop me a PM if you are still interested.
Pics Finally!
post #10 of 10 (permalink) Old 12-27-2009, 10:31 AM Thread Starter
Have some new stuff like:
All the grille trim (left and right fender extensions, center valance and hood molding)
A pair of 70 headlight doors (the plastic ones, not the actual headlight buckets)
70 lower door seals
65-70 radiator support to hood seal
65-66 and 69-70 door handle seals
Maybe a few others I can't think of off hand!
Pics Finally!
