Ignition Timing & Rotor Position Question - Vintage Mustang Forums
 1Likes
  • 1 Post By Pony Gaz
post #1 of 14 (permalink) Old 09-14-2016, 12:16 AM Thread Starter
Quick question about rotor position in a "healthy" engine.
Timing set at 12 degrees BTDC on compression stroke. Rotor pointing to plug #1.
Crank turns twice for every one turn of the cam.
So after one turn of crank, stopping at 12 degrees BTDC, the rotor would be pointing at the #6 plug.
Is this correct or am I mistaken?
Djohnyvonne is offline
post #2 of 14 (permalink) Old 09-14-2016, 04:24 AM
mustang-art's Avatar
after one crank turn you you turned cam 180 degrees so rotor pointing 180 degrees in other direction
mustang-art is offline
post #3 of 14 (permalink) Old 09-14-2016, 07:24 AM
zray's Avatar
This is correct if your firing order is
1 5 4 2 6 3 7 8
It should be mentioned , That is not the only possible firing order
Clock
Ford 302HO / 5.0L and 351W Firing Order
1 3 7 2 6 5 4 8
(Plug 6 is the same position)
http://www.gtsparkplugs.com/firing-o...0-289-302.html
http://www.gtsparkplugs.com/firing-o...d-302-351.html
Z
zray is offline
post #4 of 14 (permalink) Old 09-14-2016, 07:31 AM
awhtx's Avatar
1 5 4 2 6 3 7 8
Z
Look at any V8 firing order you wish- AMC, Chevy, Ford or whatever. There is a 90% probability that #6 is the 5th cylinder in the firing order. If you find an engine that doesn't have 1 and 6 as the first and fifth cylinders please post it here.
awhtx is offline
post #5 of 14 (permalink) Old 09-14-2016, 09:33 AM
PetesPonies
Posts: n/a
That is correct. It will be point to it's "piston pair".
1-6
5-3
4-7
2-8
post #6 of 14 (permalink) Old 09-14-2016, 12:37 PM
1-6
5-3
4-7
2-8
Pete's right you can change "when" you fire them but NOT when they are both at TDC. The cam lobes must be changed in orientation as well. Three different firing orders have been used on production V8s over the years. 15426378 is the most popular. Chevrolet uses the same sequence though their cylinders are numbered differently and the dist turns clockwise.
'66 GT350H-3 time cover car - Car Craft July'77,Modified Mustangs and Fords Feb2011 ( w/article), Mustang Monthly June 2014. Bracket raced by me for the last 44 years. Yes it is a real one.
'68.5 R code GT fastback
'67 Ranchero 408W -427 glass hood
'78 F350 "Oleynik" car hauler
Ford Experimental parts collector
GT350HR is offline
post #7 of 14 (permalink) Old 09-14-2016, 08:23 PM Thread Starter
Thumbs Up
Thank you to all that replied. My motor is a 1967 390 s code, so yes, #6 is 180 across from #1. Just double and triple checking everything before I break in this rebuild.(my first time)hope all goes well.
post #8 of 14 (permalink) Old 09-14-2016, 11:21 PM
zray's Avatar
Originally Posted by awhtx View Post
"........If you find an engine that doesn't have 1 and 6 as the first and fifth cylinders please post it here.
I'm hoping my next Mustang will have this firing order: 1-5-4-8-3-7-2-6
Hint: (think Voodoo)
Z
zray is offline
post #9 of 14 (permalink) Old 09-15-2016, 08:55 AM
Well, it seems like GM were the black sheep with the Buick Nailhead's whacky firing order. 1-2-7-8-4-5-6-3
11thAirborne likes this.
Do it right. ONCE!!
Pony Gaz is offline
post #10 of 14 (permalink) Old 09-15-2016, 09:05 AM
PetesPonies
Posts: n/a
GM numbers their cylinders differently . . so you can' compare that to Ford. It may not be as wacky as you think.
post #11 of 14 (permalink) Old 09-15-2016, 12:55 PM
zray's Avatar
Z
^^^^^. this ones a Ford.
Z
zray is offline
post #12 of 14 (permalink) Old 09-15-2016, 01:04 PM
zray's Avatar
just as you say Pete, not that wacky, the nailhead Buick #4 corresponds to the Ford #6
I am surprised no comment on my posted Ford firing order of 1-5-4-8-3-7-2-6. I guess everyone's already in the know.
Z
zray is offline
post #13 of 14 (permalink) Old 09-15-2016, 01:11 PM
Z
Yup , only with a flat crank.
GT350HR is offline
post #14 of 14 (permalink) Old 09-15-2016, 04:53 PM
zray's Avatar
With fewer cars having V-8's these days, I wonder if the engines that used to be considered just for exotic cars, like the flat plane V-8, will be used more often as the V-8 becomes more specialized & strickly performance oriented.
Z
zray is offline
