How much oil goes in an AC compressor? - Vintage Mustang Forums
 1Likes
  • 1 Post By wolfeman
post #1 of 4 (permalink) Old 09-26-2016, 02:56 AM Thread Starter
I am replacing an old style York compressor, with a rebuilt one the manuel says i need 7/8 inch on a dip stick, but i remember reading stemware about how many ounces of oil was needed for each component. in the event any part is removed. This methiod seems easier/ more practical than evacuating a system just to check oil level.
How many ounces of oil should I add to the newly rebuilt empty compressor?
1965 mustang I6 working original style AC system
toad is offline
post #2 of 4 (permalink) Old 09-26-2016, 09:28 AM
TheRktmn's Avatar
My manuals only go back to '67, but it shows the York as holding 10 Fluid Ounces (max).
Bob
Contact and business info removed to comply with new management ad rules.
TheRktmn is offline
post #3 of 4 (permalink) Old 09-27-2016, 03:30 PM Thread Starter
Is that is for the entire system?? or just The compressor??
so the compressor might only hold 6 ounces of the 10 total??
toad is offline
post #4 of 4 (permalink) Old 09-28-2016, 07:21 PM
Did the replacement compressor come with any oil in it? Some do, some don't. If it did, drain it out and measure it. I recommend draining the oil from the drier also and flushing the evaporator and condenser with AC flush solvent to remove any oil from them. Then add 10 oz. total to the compressor.
After running the AC for a while most of the oil in the system is returned to the compressor. At that time, it should still have about 10 oz. in it. You can then check the oil level as you described with the dipstick. You don't need to drain, evacuate and recharge the system to check the oil with the dip stick if you isolate the compressor with the back-seating valves and then take the oil plug out. The procedure is described in the factory service manual.
TheRktmn likes this.
65 GT coupe. 351W. Edelbrock Performer RPM heads, manifold, cam. Hooker Super Comp headers. 2 1/2" exhaust. Toploader. 9" with 3.70 trac-loc. 4 wheel discs. Leather seats. The actual car I learned to drive in over 45 years ago (except for the mods!).
wolfeman is offline
