2100 carb question - Vintage Mustang Forums
 1Likes
  • 1 Post By Woodchuck
post #1 of 10 (permalink) Old 11-27-2016, 01:34 PM Thread Starter
2100 carb question
Working on my first restore, 1968 289 c 2 brl. I've got the timing set to 8 btdc, new plugs, new wires, new cap. New 2100 carb, the motor starts, won't run, spits and sprays fuel out of the carb as it's sputtering...
Here is the funny thing, the drivers side exhaust manifold is warm, all of them are warm, the passenger side, cold... I have spark, tested with a light, plugs are oily/ smell like gas...
Any ideas?
Steve
Sent from my XT1575 using Tapatalk
steveperryman is offline
post #2 of 10 (permalink) Old 11-27-2016, 01:42 PM
Shaummy66's Avatar
First thing I'd check would be to make sure you have the firing order correct..i.e. the right spark plugs to the right spots on the cap. You can still have spark to a plug but if its not firing at the right time it's not going to work.
Shaummy
66 convertible 289 C Code Sauterne Gold with Black power top.
Shaummy66 is offline
post #3 of 10 (permalink) Old 11-27-2016, 01:46 PM Thread Starter
Thanks, the motor was worked on by the Po, I have checked and rechecked the firing order, i am tempted to set it up as a 351 firing order and see what happens... Will I stress the motor if i set up the firing order as a 351?
post #4 of 10 (permalink) Old 11-27-2016, 04:34 PM Thread Starter
https://cloud.tapatalk.com/s/583b503d...161853769.jpg?
Turns out the front 3 cylinders aren't getting fuel. These plugs, the 3 whites are from the front 3 cyls, the remaining 5 all look like the black ones....
Could the be a clog in the intake manifold? I pulled the manifold and powerwashed it through but never checked if the was passage through the intake...
Steve
post #5 of 10 (permalink) Old 11-27-2016, 05:45 PM
Not to set any alarms off but it could also be wiped cam lobes. With the valve covers off, suggest checking to make sure the intake valves are opening on those cylinders.
rreitz is offline
post #6 of 10 (permalink) Old 11-27-2016, 05:53 PM
Woodchuck's Avatar
Pull all the plugs. Pull the coil wire at the distributor and ground it. Block the throttle wide open. Run a dry then wet compression test and post the results.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is online now
post #7 of 10 (permalink) Old 11-28-2016, 07:55 AM Thread Starter
Well, the compression check sure put me in a sour mood....
All plugs pulled, throttle opened wide choke opened wide.
pass side (trouble side)
80 dry (90 wet) / 0 / 0/ 165
drivers side
100 (100 wet) / 0 / 0 / 130
ugh man... my minimal understanding of this tell me that this is a valve problem and a head gasket... I'm assuming no compression = no ignition... Although I wonder why I get a warm exhaust header on the drivers side...
Am I looking at new heads and gaskets?
-Steve
post #8 of 10 (permalink) Old 11-28-2016, 01:35 PM
Shaummy66's Avatar
drivers side
-Steve
Really hard to say... but I'd start from the top and work your way down. Who knows..maybe the rockers were never set correctly allowing no compression on some cylinders...or lifters that aren't working the way they should.
If you haven't already, at least take the valve covers off and check the rocker arms, valves, pushrods and the like look like they should before tearing into taking the heads off.
Shaummy
post #9 of 10 (permalink) Old 11-28-2016, 05:07 PM Thread Starter
Thanks for the reply, I did remove the covers and the rockers and valves look great.... Arms look good, Must be the head / valves... I hope not rings., I can get a couple heads for $50 and gaskets are cheap, so I'l likely change them out and recheck compression.
-Steve
post #10 of 10 (permalink) Old 11-28-2016, 07:37 PM
Woodchuck's Avatar
Time to go back and set valve lash the RIGHT way....
Engine Valve Adjustment Procedure - The Right Way
Just substitute the Ford firing order for the GM shown. The 221-260-289-302 firing order is 1-5-4-2-6-3-7-8.
daves67ss likes this.
Bart
What, me worry?
- Alfred E. Neuman
