rpm intake (not air gap) for 408w street car - Page 3 - Vintage Mustang Forums
 2Likes
post #31 of 53 (permalink) Old 01-01-2017, 01:19 PM Thread Starter
Im sure I will eventually upgrade, but I can go for the air gap or vic jr and do lower motor mounts at same time. or a cowl hood. Get me by for now, and the car currently has a stock block 302 in it now, so its gonna be way better than that
dads67coupe is offline
post #32 of 53 (permalink) Old 01-01-2017, 01:27 PM
cmefly's Avatar
You will be amazed at the difference even a mild 408W will make. It will have an insane amount of Torque. You will probably not feel the need to upgrade.
cmefly is offline
post #33 of 53 (permalink) Old 01-01-2017, 01:45 PM Thread Starter
The 302 was also pushing 2.80 gears, now its got 3.70... never drove the 302 with 3.70, so its an all at once upgrade lol
be like a whole new car
post #34 of 53 (permalink) Old 01-01-2017, 02:48 PM Thread Starter
How much hp should I expect to make? with port matched rpm, hydro roller cam custome built (not ordered yet) and a 770 cfm street avenger? 10.2 to one c/r. Hooker 6208's
post #35 of 53 (permalink) Old 01-01-2017, 03:20 PM
cmefly's Avatar
The 2400 stall converter is going to limit your cam choice a little but 500Hp should be easily attained even with the RPM intake and small carb. It takes some real work to get a 408W to dyno under 500 at the flex plate.
cmefly is offline
post #36 of 53 (permalink) Old 01-01-2017, 03:24 PM Thread Starter
I dont mind bumping up the stall a bit, just trying to keep stall speed just under cruising rpm to not heat the trans up during car club cruises. The intake will eventually go away for a big single plane, but I gotta save up for either a cowl hood or ron morris motor mounts..... trying to do it all at once will kill the build. I'm already over budget lol. Been trying to buy the best I can even if I have to save for an extra couple weeks.
post #37 of 53 (permalink) Old 01-01-2017, 04:39 PM
THE EVIL TW1N's Avatar
I have a Victor Jr intake on my 427w and I wish I woulda went bigger. I also do run a 1/2" carb spacer. For a 408, I'd go Victor Jr. at the minimum.
1969 MaCh 1 - CHP 427w 10.8 comp
460 rwhp / 489 rwtq SAE
TFS 205cc 11R heads || Vic Jr. intake || Holley 950HP || 14" 6 piston / 13" 4 piston Wilwood brakes || T56 Magnum || SPEC 2+ hyd clutch || Detroit Locker || 3.70's || Aluminum DS || TCP R&P || TCP 1 1/8" front sway bar || TCP front adj coilover's || TCP Panhard Rod & rear sway bar || Maier rear leafs || Bilstein shocks || Forgeline GA3C wheels - 18"10", 19"x12" 325/30
THE EVIL TW1N is offline
post #38 of 53 (permalink) Old 01-01-2017, 07:08 PM
SVTguy's Avatar
I see you are running your air cleaner up into the Mach 1 scope. I have debated if I want to cut the stock hood up in my 69 and run the air cleaner up through the hole so I can run a taller intake on my 408w as well.
Do you have stock height or drop motor mounts?
Sharp looking 69 by the way!
SVTguy is online now
post #39 of 53 (permalink) Old 01-01-2017, 07:42 PM
Thx!
I just installed some 1/2" drop mounts recently, so I have room to run up to a 1" spacer now. But otherwise, without the 1/2" drop motor mounts, I was able to fit everything in there with a 1/2" spacer with zero issues.
post #40 of 53 (permalink) Old 01-01-2017, 09:38 PM
SVTguy's Avatar
Thx!
Cool thanks, and your hood scope is still the stock Mach 1 scope?
I might have to really think hard on running a Vic Jr then.
post #41 of 53 (permalink) Old 01-01-2017, 09:47 PM
Yeah stock hood scoop. Also, forgot to add, I don't run the metal grill in the scoop. I also grinded down the nubs and rib where the bolts for the metal grill bolted onto inside of the scoop for a cleaner look. I don't remember if it was necessary, but it's very easy to do since the scoop is fiberglass.
post #42 of 53 (permalink) Old 01-02-2017, 08:39 AM
I too didn't want to cut my hood so I went went with RPM, mine made 545hp 497fts on the dyno with it so I don't really feel it hurt me that much.
srsfunk is offline
post #43 of 53 (permalink) Old 01-02-2017, 09:09 AM
dobrostang's Avatar
Your RPM will always be worth the boat-buck you spent on it if you decide to upgrade but after 550hp when is enough enough unless you are seeking ETs.
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
post #44 of 53 (permalink) Old 01-02-2017, 10:59 AM
turbo2256b's Avatar
Have run all the intakes mentioned on SBFs. Depending on the build which is picked can make a night and day difference. I have also flowed most of them on a flow bench attached to a head.
If hood clearance is needed a torker II flows almost identical to a VrJr with in a couple CFM.
As far as the air gap vs RPM there isnt much difference at all definitely not worth the extra 100.00
turbo2256b is offline
post #45 of 53 (permalink) Old 01-02-2017, 11:39 AM Thread Starter
More info on your combo?
