'67 rear quarter panel extension, the $64 question - Vintage Mustang Forums
post #1 of 17 (permalink) Old 07-10-2017, 07:32 PM Thread Starter
j persons's Avatar
I need a Left side fastback quarter panel extension, and NPD has them from $64 to $100. for the OEM type extension. I would rather not spend $100 on this, but I don't want to buy something that doesn't fit well either. Anyone have any experience with this? TIA,
F-150 SCab daily driver
j persons is offline
post #2 of 17 (permalink) Old 07-10-2017, 07:39 PM
Woodchuck's Avatar
Good used one? It ain't like it'll be all rusty.....
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #3 of 17 (permalink) Old 07-10-2017, 07:46 PM
Boom's Avatar
I have an OEM 68 one that I'll let go for less then that. Let me know if you're interested.
-Brett
1968 fastback 351w
1986 Iroc-Z
Boom is offline
post #4 of 17 (permalink) Old 07-10-2017, 08:15 PM
dcubedus's Avatar
Not to hijack this thread, but what is the difference between the coupe/convertible version and the fastback version?
I have 3 of these original parts lying around the garage (each with different stampings):
LH C7ZB-65286073-B
LH C7ZB-65286072-B
RH C7ZB-65286073-A
I believe that these are all for coupe/convertible, but have never held them up next to my fastback to discern the difference.
Dcubedus
Nightmist Blue 67 Coupe (C Code - C4) - Owned since 1987
Nightmist Blue 67 GT Fastback (S Code - 4spd) - Owned since 2013
dcubedus is offline
post #5 of 17 (permalink) Old 07-10-2017, 08:27 PM
Woodchuck's Avatar
LH C7ZB-65286073-B
LH C7ZB-65286072-B
RH C7ZB-65286073-A
Dcubedus
All three of those are extensions for a hardtop. Right after the hyphen the next two digits are the body code. If they were for a Fastback it would be "63" and for a convertible, "76", if the fastback and convertible used a different piece.
Bart
What, me worry?
- Alfred E. Neuman
post #6 of 17 (permalink) Old 07-10-2017, 08:31 PM
22GT's Avatar
The fastback item is entirely different above the taillight. A fastback part would have an engineering number that read C7ZB-63286073. The "63" means fastback. Before these were reproduced, I was paying $100 each for used ones.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #7 of 17 (permalink) Old 07-10-2017, 08:58 PM Thread Starter
j persons's Avatar
Back in the early '90's I was looking into casting them in fiberglass, but it never panned out.
post #8 of 17 (permalink) Old 07-10-2017, 09:34 PM
Lizer's Avatar
This is the part where you go to Ebay and buy an original one with all the parts still there.
67 coupe with 5.0 and C4 (Viper GTS Blue, paint code PBE, since everybody asks)
69 Mach 1 428 SCJ drag pack
Lizer is offline
post #9 of 17 (permalink) Old 07-10-2017, 09:36 PM
sixtysevenGTconv's Avatar
Best I know coupe and conv same rear panels so extensions the same. As 22 said FB is diff, longer.
But comment as far as rust, yea no, BUT being a cast metal part, they sure crack easier. But brittle, if you look to buy used, make sure the lower mounting hole is even still there. Many used that lower hole (tab) snapped right off.
If you borrow a tool more than twice, you need to own it You get what you pay for!
George email: <[email protected]>
sixtysevenGTconv is online now
post #10 of 17 (permalink) Old 07-10-2017, 11:22 PM
dcubedus's Avatar
OK. So, I held an uninstalled coupe quarter extension (gray) next to my fastback quarter extension (black) and now see the difference in depth (front to back) from a side view.
See attached pic.
Thanks,
dcubedus
dcubedus is offline
post #11 of 17 (permalink) Old 07-11-2017, 08:01 AM
lennyB's Avatar
You can buy OEM ones on Ebay starting about $25. I bought one about a month ago that was OEM and flawless for $40 there.
lennyB is offline
post #12 of 17 (permalink) Old 07-11-2017, 08:17 AM Thread Starter
j persons's Avatar
Right now I have three left side OEM extensions, and all of them have problems, it's usually the inside upper "lip" is interfering with the trunk lid closing. I have a repo in the right and it has no interference with the trunk lid. One of the problems with these things is they are made from pot metal, and trying to get one to conform usually ends up with it cracking. If I can get a good pair, I may make some molds and see if I can lay them up in fiberglass.
post #13 of 17 (permalink) Old 07-11-2017, 10:17 AM
OldMil's Avatar
I find that a bit odd. Usually the OEM quarter extensions are very consistent, and should not have differences unless there was some sort of damage. If you tried 3 OEM pieces and all three interfered with the trunk lid, I would guess that your issue is with panel alignment, not the quarter extension. Have you replaced any sheet metal? That being said, post a wanted ad in that section of the forum and you will find a quality part for a good price. Good luck! Jack
1970 428CJ Mach-1
MCA# 60075
"Every day's a Holiday, and every meal's a Picnic"
[email protected]
OldMil is online now
post #14 of 17 (permalink) Old 07-11-2017, 11:09 AM Thread Starter
j persons's Avatar
This whole car is reproduction. I have a repro RH quarter cap and it actually fits better than any of the original three I got from ebay. The trunk lid fits the opening just fine, but I still need to get the hinges adjusted correctly. The only thing I can think of is the ebay quarter caps were all junk yard picks off of wrecks.
post #15 of 17 (permalink) Old 12-07-2018, 11:37 AM
BTK
Check EBay I just bought a pair for $25 need the be refinished
BTK is offline
