Question Re; 69/70 door window guide identification - Vintage Mustang Forums
post #1 of 6 (permalink) Old 04-20-2018, 06:41 PM Thread Starter
71steed's Avatar
The vertical door glass guide rods, I understand that there are left and right, front and rear. I have a couple that I can read the marks on the bottoms but most of them I can't. I can see the difference between the right and the left; the bottom plate angle. How can I determine between the fronts and the backs? Does it make a difference? Thanks in advance. Bob
1971 Spring Sport Special.
1969 Fastback, 408ci, 5 Speed.
1971 Mach 1, M code, ram air, 4 speed, loaded.
1969 GT California Special, M code, Tach, Speed Control, Tilt, AC, AM/FM, Intermittant Wipers, Ford Dealers Wife's car, all the goodies.
71steed is offline
post #2 of 6 (permalink) Old 04-20-2018, 11:06 PM
22GT's Avatar
Front and rear are the same, only left and right matters.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #3 of 6 (permalink) Old 04-21-2018, 09:31 AM Thread Starter
71steed's Avatar
Then where does this one go? It is marked LH and also has an "R".
71steed is offline
post #4 of 6 (permalink) Old 04-21-2018, 09:44 AM
69XR7RestoMod's Avatar
The part number for the passenger side is C9ZZ-6521546-A and the part number for the drivers side is C9ZZ-6521547-A
So thatís not helpful at all - can you find the part number stamped anywhere else on the door run?
69 XR-7 408w, FiTech, TKO-600
69XR7RestoMod is offline
post #5 of 6 (permalink) Old 04-21-2018, 10:09 AM Thread Starter
71steed's Avatar
The books may show the part numbers but the pieces do not. The different sides are evident but why is the one that I can read also have an "R" as some others do too. Unfortunately, the numbers are stamped on the bottom of the part and that is where they rust, thus reading the number impossible. I'll line them all up and see what I can determine.
71steed is offline
post #6 of 6 (permalink) Old 04-21-2018, 06:23 PM Thread Starter
71steed's Avatar
Maybe Cougars are different and some of them I have are from Cougars?
71steed is offline
