Grinding noise in reverse - Vintage Mustang Forums
post #1 of 14 (permalink) Old 04-26-2018, 07:13 PM Thread Starter
rfollwe1's Avatar
Hey Guys,
I pulled my 67 out of the garage to do a parts run tonight. When I put in reverse I heard a grinding noise. I thought maybe u joint was bad, but still heard the grinding when stopped. I blocked the rear wheel and put it in reverse. Drive shaft not moving but still grinding noise. Car has C4 and 8" limited slip. Any ideas? Thanks, Rich
rfollwe1
67 GTA Mustang, Fastback, A-Code,
Candy Apple Red/Red Deluxe Interior
rfollwe1 is offline
post #2 of 14 (permalink) Old 04-26-2018, 08:38 PM
Weíll reverse doesnít have a synchronizer for one thing so you can get some grinding. The other your clutch may be dragging, meaning not fully disengaging due to adjustment, wear or sticking
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is online now
post #3 of 14 (permalink) Old 04-26-2018, 09:26 PM
awhtx's Avatar
Since the OP states that "car has C4" I don't think it's a synchronizer or clutch problem.
Is the starter completely disengaging from the flexplate after the engine starts?
awhtx is offline
post #4 of 14 (permalink) Old 04-26-2018, 09:26 PM
Dave R.'s Avatar
I'm pretty sure that a C4 has no clutch as well. Dave R.
Dave R. is offline
post #5 of 14 (permalink) Old 04-26-2018, 09:39 PM Thread Starter
rfollwe1's Avatar
It sounds like it's coming from the rear of the car. But since driveshaft isn't moving I'm stumped. I'll put is up on jack stands this weekend.
rfollwe1
rfollwe1 is offline
post #6 of 14 (permalink) Old 04-26-2018, 09:45 PM
Paul1958's Avatar
Sound can bounce around off the underbody. Probably coming from the rear of the C4.
Paul
Okay. Engine Stop. ACA out of Detent. Mode Control, both Auto. Descent Engine Command Override, Off. Engine Arm, Off. 413 is in.
-Buzz Aldrin, Apollo 11 LMP
Actual first words from the surface of the moon
Early Fox: 5.0L HO SEFI conversion, 5-speed, 8.8 w/3.27:1 TL, full dual exhaust
1968 coupe - Ordered 12.15.67 Delivered 2.1.68: 8T01T, 65C, 289 conversion, hanger queen
Paul1958 is offline
post #7 of 14 (permalink) Old 04-26-2018, 10:50 PM
Dave R.'s Avatar
The noise can't originate in the rear end if the noise is present without the driveshaft turning. I'm not a trans guru but does the noise go away in neutral and drive? Noisy in reverse only? Cross member bolts loose? Flexplate bolts? Just spitballing here. Dave R.
Dave R. is offline
post #8 of 14 (permalink) Old 04-26-2018, 11:05 PM
LOL, major brain fart. Donít know what I was thinking. Obviously I wasnít. At least it was good for a laugh
Tom
post #9 of 14 (permalink) Old 04-26-2018, 11:24 PM
awhtx's Avatar
Welcome to the world of "old age"!
awhtx is offline
post #10 of 14 (permalink) Old 04-27-2018, 12:10 AM
Ainít that the truth!
Tom
post #11 of 14 (permalink) Old 04-27-2018, 12:36 AM
Transmission fluid
Hey Guys,
I had a 68 Mustang with a C4 and I remember the tranny making a ratchety grind noise the first time that I would put it into gear or reverse while the car was in park. It ended up being low on tranny fluid. You probably already checked the fluid, but worth mentioning.
image98 is offline
post #12 of 14 (permalink) Old 04-27-2018, 07:18 AM Thread Starter
rfollwe1's Avatar
I'm hoping low fluid is the issue. I do have a persistent pan leak. I ordered a new pan and will install it this weekend. Thanks.
rfollwe1
rfollwe1 is offline
post #13 of 14 (permalink) Old 04-27-2018, 09:56 AM
Dave R.'s Avatar
Husky, I am not laughing at you but I am laughing with you. I'll be 66 next month so I know from where you speak. Dave R.
Dave R. is offline
post #14 of 14 (permalink) Old 04-27-2018, 04:46 PM
Oh no, I knew you were laughing with me. Iím 62.
Tom
