Soft Top Replacement components - Vintage Mustang Forums
 6Likes
post #1 of 18 (permalink) Old 06-14-2018, 12:32 PM Thread Starter
JonnybravoM3's Avatar
Hi all
My 65 Mustang Soft Top has seen better days. So I'm ordering a new Scott Drake one from Summit. Apparently this comes as is, just a top with a plastic window and nothing else. My soft top is a manual mechanism.
Thinking what other components I will need as well. Everything else works well, with the exception of the passenger side latch which doesn't close properly, overlaps when shut, so I can change that. There's also a small gap on the passenger side, maybe I'm over thinking this one. (pix attached).
So far, this was my shopping list based on recommendations from the sales rep on live chat. Not sure if I need all of this or not, and welcome your thoughts!
Among the items are:
- New latch assembly with springs for driver and passenger side (my drivers side one is actually fine, issue is with my passenger side one, but when changing the top, is it best to just change both?)
- New hold down clamps (mine are fine, when changing the top is it best to change both?)
- Tension cable stud (not sure what this is or where it fits)
https://www.cjponyparts.com/converti...-1965/p/CTTC1/
- Weatherstrip kit (I think mine is fine but when removing the old top, might damage existing rubbers, so just in case).
https://www.cjponyparts.com/converti...-1968/p/WSCT1/
- Top pad set (not sure what this is or where it fits)
https://www.cjponyparts.com/kee-auto...65-1993/p/CTP/
Any advice would be much appreciated!
JB
Sent from my HTC U11 using Tapatalk
Current Stable:
1965 Ford Mustang 289 V8 Convertible (Betty)
2011 Range Rover HSE (Her Ladyship)
2012 Bentley Flying Spur Speed W12 (51 Series) (Bernard)
2014 Porsche 911 (991) Turbo (Yellowbird)
2015 Range Rover Sport SVR (Brutus)
2018 Rolls Royce Wraith (Gray)
JonnybravoM3 is offline
post #2 of 18 (permalink) Old 06-14-2018, 03:44 PM
ziurtoys's Avatar
While you're at it, I would suggest you to inspect all bushings & replace them if needed, especially the main pivot bushings & pins. They are located inside both sides of convertible top wells.
msh-r and JonnybravoM3 like this.
ziurtoys is offline
post #3 of 18 (permalink) Old 06-14-2018, 04:05 PM
Our friend Richard (DalorzoF) wrote a definitive piece on early top replacement. While he was alive, he freely distributed his work to fellow hobbyists, just for the asking. Not sure who might still have a copy that would be willing to share. Anyone here?
JonnybravoM3 likes this.
url]http://i87.photobucket.com/albums/k156/jefftepper/IMG_0027_edited-1.jpg[/url]
*Principal wrench on this 69 Mach I*
JeffTepper is offline
post #4 of 18 (permalink) Old 06-14-2018, 04:45 PM
You will need stainless steel staples, a proper staple gun I recommend pheumatic if you have a compressor. You will need the proper adhesive as well.
You will likely need to replace some of the tack strips, but you won't know until you get it apart.
Flade
68 289 convertible Candy-apple red & white
66 200 coupe Blue
94 GT convertible Red & black
98 GT convertible White & black
98 V6 convertible White & tan
Flade is offline
post #5 of 18 (permalink) Old 06-14-2018, 05:39 PM
If you look at your pic of the bent latch, see the grey cloth strip that the top sits on. That is for top pad. They attach to the frame and provide alignment and proper position of the top bows.
Think of the top as a body. The frame is the skeleton, the top pads and cables are the tendons and ligaments that hold it all together. The top is the skin that covers it all.
I always replace the cables when replacing a top. If they are stretched the top will not seal properly.
The weatherstripping bolts along the bottom of the frame when it contacts the Windows.
I buy my supplies from Convertible Top Guys.
https://www.convertibletopguys.com
Their website has all the tools, manuals and tech info you will need. To get started
Woodchuck and JonnybravoM3 like this.
Flade
66 200 coupe Blue
Flade is offline
post #6 of 18 (permalink) Old 06-14-2018, 05:46 PM
I can email anyone that pms me their email address the convrt top bible by richard. Wes
DonP likes this.
mustang656man is offline
post #7 of 18 (permalink) Old 06-15-2018, 12:14 AM Thread Starter
Sent
Current Stable:
post #8 of 18 (permalink) Old 06-15-2018, 01:02 AM
NEFaurora's Avatar
Flade, I'd be a little leary of that https://www.convertibletopguys.com website. Most of their stuff, they charge DOUBLE of what other places charge, and that is before shipping For example, Their ARROW T50 Electric Staple gun is almost $60. You can buy the same one on ebay for $27.00 Another one is their Top Boots. They want like $129.00 for a '65-'66 Top Boot. You can buy the best ones (TMI) from NPD for like $69.00...and their Top Boot bag in Black is $30. You can buy the same bag everywhere else for $17.00 and so on... Just a word to the wise...
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #9 of 18 (permalink) Old 06-15-2018, 01:05 AM Thread Starter
Tony K.
I emailed them. I'll compare their prices with what I've got in my Summit shopping cart.
Important is quality as well.
Current Stable:
post #10 of 18 (permalink) Old 06-15-2018, 01:53 AM
NEFaurora's Avatar
"Important is quality as well."
Their Quality won't be any better than what NPD carries... and you can take that to the bank...
The only thing that I do like from the "Convertible Top Guys" that they carry is their Convertible Top Motors.... IT looks pretty damn good...if what they sell is exactly like their pics on the website. Other than that....I seriously doubt their other stuff is any better than NPD....especially Hydraulic Top Pump Cylinders. I would never buy those anywhere other than NPD... I've literally had horror stories with them from other vendors.. NPD carries the very best ones...period.
Tony K.
Tony Kovar
MCA#70001
post #11 of 18 (permalink) Old 06-15-2018, 05:37 AM
Tony K.
Thanks Tony,
I've only used them for SN95 tops and they were pretty competitive there. They also have a some great packages with all the needed supplies. I'll likely buy supplies from them and parts form NPD.
Flade
Flade
66 200 coupe Blue
Flade is offline
post #12 of 18 (permalink) Old 06-27-2018, 03:41 PM Thread Starter
Cancelled my Scott Drake Top order from Summit and will be ordering an EZ-ON from NPD. I've been communicating with them over email and I'm happy with their service and knowledge and support. Thanks guys for your recommendations.
Current Stable:
post #13 of 18 (permalink) Old 11-19-2018, 08:58 PM
Would like to get a copy of the convertible Top bible If possible. Having trouble figuring out how to PM. Joined a few years ago but have only browsed posts. Have a 65 convert with the top out and need to figure out how to repair/rebuild. Top Frame is 80% good and I did buy the Dynacorn from bow piece ( with latches, etc) as the old one was pitted terribly. Bows have some rust ( vert sat in a field for many years with no cover) and have no idea what tacking / felt material goes where, etc. Any help appreciated, Bill
Blaze65
Blaze65 is offline
post #14 of 18 (permalink) Old 11-20-2018, 03:40 AM
blaze65- need email to send doc to! Wes
post #15 of 18 (permalink) Old 11-20-2018, 07:06 AM
geicoman58's Avatar
mustang656man, could you add me as well please!! [email protected] thank you!
geicoman58 is online now
