Installing long tube headers problems. - Page 2 - Vintage Mustang Forums
 5Likes
post #16 of 18 (permalink) Old 06-20-2018, 01:16 AM
LeeFred's Avatar
I'm assuming the pic of the headers is showing the shorty headers which you had before with a solid flange, and the long tube headers which have the individual flanges. I have similar long tubes and I have learned over the years is to thread the bolts into the rear holes of the flanges first, and then do the front holes. I use Remflex gaskets that don't have the hooked holes, so it's a bit more difficult. On the driver's side, I start threading bolts into the rear holes on the #5 and #8 exhaust ports, and then do #6 and #7. Like mentioned previous, I thread just enough to have the bolt started and then go to the next one. Once the rears are done, then I start working on the fronts. Once they're all started in, I tighten one flange at a time.
LeeFred is offline
post #17 of 18 (permalink) Old 06-20-2018, 07:10 AM
Originally Posted by Badass70 View Post
Did your 1 tube come separate from the rest? Mines has a clamp down by the collector. I was very careful not to bend or bang them but Iíll see what it looks like Iíve tried prying up on it to get it to line up maybe that bent is some idk
Yes, the first tube did slip in. My advice is pull the header out and if you have a spare head available test fit it or check against a gasket. Otherwise youíll go crazy, I know I did.
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #18 of 18 (permalink) Old 06-23-2018, 07:29 AM Thread Starter
Ok so I spoke with Mac reguarding this situation they instructed me go drill out the hole one size bigger. He said that in some cases the powder from the coating gets too thick in areas and ends up making the holes too small. Going to give it a try and see what happens. Thanks for all that responded with good advice
MUSTANG65FBK and geicoman58 like this.
Badass70 is offline
