Need help with transmission - Vintage Mustang Forums
 1Likes
  • 1 Post By Badass70
post #1 of 12 (permalink) Old 08-28-2018, 08:56 AM Thread Starter
Hello everyone, so yesterday taking my car to get my exhaust welded up my c4 trans decides itís not going to go into reverse anymore. Drive works fine. Did a little research from what I found the rear servo ring is split causing I guess no pressure? Little back history trans is an original rebuilt about 9 years ago. Shift kit was installed and a 2200-2600 stall converter was also. My problem is do I jerk around with this trans or buy a new race trans thatís warrantied and is built for the engine thatís in the car. If I do replace it what would you recommend for high performance applications say 4-600hp, plan is to install a Paxton this winter. Also the stall converter what should I match my 3.55 gears with. I have no clue about what works I just know enough to get in trouble🤓
Badass70 is offline
post #2 of 12 (permalink) Old 08-28-2018, 11:36 AM
Ogre39's Avatar
4r70w
17 Mustangs owned to date!
1967 Mustang Convertible
2014 Mustang Fastback
1996 GT Convertible (with MK VIII swap)
Ogre39 is offline
post #3 of 12 (permalink) Old 08-28-2018, 12:01 PM
Agree - 4R70W
cliffgrove is offline
post #4 of 12 (permalink) Old 08-28-2018, 12:18 PM Thread Starter
Originally Posted by Ogre39 View Post
4r70w
What does it take to put one of these in a 1970 Mustang?
Badass70 is offline
post #5 of 12 (permalink) Old 08-28-2018, 12:48 PM
Quite a bit... You will need an electronic controller for starters. Performance Automatic Smart Shift Transmission Controllers PA99102
cougar70 is offline
post #6 of 12 (permalink) Old 08-28-2018, 01:28 PM Thread Starter
Yikes thatís a set back. I spoke to JEGS this morning they recommended Performance Automatics c4 runs 1600 plus frieght, I have to call them back later with cam specs to see if torque converter is sized right.
Huskinhano likes this.
Badass70 is offline
post #7 of 12 (permalink) Old 08-28-2018, 04:16 PM
MrFlash's Avatar
Why not just repair the servo?
You can probably do it yourself without dropping the transmission.
Or drop the transmission, put in a TCI breakaway torque converter, repair the servo(s) with new o-rings and billet aluminum covers, then put the trans back in.
1970 Mustang coupe
MrFlash is offline
post #8 of 12 (permalink) Old 08-28-2018, 04:24 PM
MrFlash's Avatar
Looks like the TC you already have is in the same range as the Breakaway. So you probably won’t need a different TC.
A C4 is great for drag racing. The 4r70w is good for cruising on the street.
If you don’t need overdrive, stick with the C4
1970 Mustang coupe
MrFlash is offline
post #9 of 12 (permalink) Old 08-28-2018, 04:29 PM Thread Starter
Yea Iím pretty sure itís a tci torque converter, is there any info on changing that servo I havenít found much except for what symptoms were.
Badass70 is offline
post #10 of 12 (permalink) Old 08-28-2018, 05:56 PM
69GT350H's Avatar
The reverse servo and band are also used for 1st gear.
https://youtu.be/As5lBDy107c
Bad Shoe Productions How To Video Series - Ford Transmissions & Rears, 1970 & up C4
VMF Build Thread - 1969 Shelby GT350 Hertz rebuild Gallery
Used by Hertz for the 1969 "Rent-A-Racer" program at Miami Internation Airport.
69GT350H is online now
post #11 of 12 (permalink) Old 08-28-2018, 11:27 PM
Woodchuck's Avatar
In any case, if you decide to do something with the C4 then a teardown is in order. You can hope for something simple, but I've seen my share of bad reverse drums...
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is online now
post #12 of 12 (permalink) Old 08-29-2018, 06:57 PM Thread Starter
Today I ordered the PA super Streeter and going to install that once it comes in. Build time is 7-10 days plus shipping. I guess weíll see how it turns out
Badass70 is offline
