351c eating oil ...Help - Vintage Mustang Forums
 3Likes
post #1 of 49 (permalink) Old 09-22-2018, 11:00 AM Thread Starter
josephqatarcarguy's Avatar
Hey . My 351c is eating oil and and need to top up after a week of driving .. there is black stains out of the exhaust on the rear pan under the rear bumper ... no oil on the spark plugs and no leaks..where else should I check ? Value stem seals ? Intake manifold sucking oil?
josephqatarcarguy is offline
post #2 of 49 (permalink) Old 09-22-2018, 01:17 PM
TommyK's Avatar
On a cleveland the intake gaskets are are a common failure mode which present as excessive oil consumption especially if you used Fel-Pro print-o-seals.
However before you take it apart do a compression test and a leak down test. Also check the valve guide seals.
1973 Mustang Convertible
460
TommyK is offline
post #3 of 49 (permalink) Old 09-22-2018, 09:45 PM Thread Starter
I did use felpro gaskets ..it started consuming oil after a cam change ...I'm using an edelbrock 2v to 4v manifold ... maybe I should use the recommended edelbrock gasket and not the felpro one ?
post #4 of 49 (permalink) Old 09-23-2018, 09:45 AM
Hemikiller's Avatar
I prefer to use the factory "turkey pan" with a ring of sealant around each intake port. Keeps the hot oil off the bottom of the intake. An oil leak into the intake usually will show on the spark plugs, pull them and see if you have one or two that don't look like the others.
Before you tear anything apart, are you using a valve cover with a proper baffle for the PCV? Oil disappears pretty quickly if it's not baffled.
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
post #5 of 49 (permalink) Old 09-23-2018, 11:58 AM Thread Starter
Not sure if it's baffled... came with it .. here's a picture .... it has a pvc valve installed ..I got spare ones too
post #6 of 49 (permalink) Old 09-23-2018, 12:00 PM Thread Starter
Here's a pic
post #7 of 49 (permalink) Old 09-23-2018, 10:23 PM Thread Starter
do i need to open up the valve covers and check if its baffled ? does anyone recognizance these covers?
post #8 of 49 (permalink) Old 09-23-2018, 10:39 PM
CantedValve's Avatar
I see the problem. You air cleaner is on sideways.
Those valve covers have separate baffles in them that the user needs to install. Pop the PCV out and stick yer finger in. It will be very obvious if it is installed. You should be able to feel it. You donít need to take them off to check. Those are the same covers I have on my engine, except mine are older and say Ford Motorsport.
CantedValve is offline
post #9 of 49 (permalink) Old 09-26-2018, 11:50 PM Thread Starter
The value cover is baffled ...changed the pcv valve...hopefully that helps with the oil consumption....what to check on next ?
post #10 of 49 (permalink) Old 09-27-2018, 10:48 AM Thread Starter
Spark plugs ?
post #11 of 49 (permalink) Old 09-27-2018, 01:46 PM
RV6
RV6's Avatar
Well the fact that it started consuming oil after a cam change tells me it is prolly the intake manifold gaskets, or manifold. Does it smoke after decel and you romp on it? If so I would think valve stem seals and if not it points to the last thing you did. Intake manifold.
After pondering a bit I have another idea. My wife says this is not good, but I'm gonna tell you anyway. You most likely changed the cam for a higher lift, and or added rockers. The valve stems could have been carbon coated and with the higher lift they became damaged by the carboned up valve stems.
Seals are easy to replace without pulling the head or intake. I might check into the valve seals before opening up the engine again. I hate antifreeze and oil.
Gary
Pine, CO
1967 Coupe, 289-4V, T-5
RV6 is offline
post #12 of 49 (permalink) Old 11-14-2018, 10:45 PM Thread Starter
what compression should i have on each cylinder a mostly stock 351c 2v ?
post #13 of 49 (permalink) Old 11-15-2018, 07:01 AM
coupe3w's Avatar
Another vote for intake gasket.
'67 Fastback, 404C stroker, T5, 9" 4:30, Koni's
'34 3 Window Coupe, all steel except fenders, 5.0, AOD, AC
coupe3w is offline
post #14 of 49 (permalink) Old 11-15-2018, 07:18 AM
Iím leaning toward valve guide seals especially on the exhaust valves as they run hotter. If the intake gaskets were leaking I think it would show up on the spark plugs. You said your plugs were clean. Now if the exhaust guide seals were bad, you would be loosing oil here which would never enter the combustion or show up on the plugs.
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #15 of 49 (permalink) Old 11-16-2018, 07:21 AM Thread Starter
i will check the plugs again to eliminate the intake valve gasket leak , is there another way to check?... i started losing oil after a cam change so aye
