LED lights are gonna drive me to the looney bin! - Vintage Mustang Forums
 4Likes
post #1 of 37 (permalink) Old 12-07-2018, 12:00 AM Thread Starter
daveoxide's Avatar
I have converted all the exterior lights and the instrument cluster lights on the wife’s 66 to LED’s. I had some weirdness with the taillights that I traced to bad grounding, which was fixed, so they work fine now. But I have been troubleshooting the front turn signals for two days now and can’t figure it out!
Here is what is going on... when I click the turn signal left or right both front turn signals blink, the commanded light blinks bright and the other side blinks dimly. Now when I turn the headlights on (past the parking light detent) and click the turn signal left or right, the commanded turn signal blinks from high brightness to low brightness and the other side is on low brightness with a dim flash.
When I take either front LED turn signal bulb out and replace it with an incandescent, it fixes nearly all the problems (still have a slight dim illumination on LED bulb with headlights on and blinker on). And with the front LED’s installed, headlights or parking lights on, when I click the turn signal the dash signal indicator will stay lit with a very minor change in brightness as the flasher clicks along.
I have installed a three wire flasher. I found an issue with a previous set of LED bulbs where an internal resistor burnt up, so I replaced the bulbs and still no go. I even went as far as unsoldering the bulbs to make sure they had a diode installed to prevent backfeed, and they do. I am trying to avoid installing ballast resistors as that seems like a bandaid to me, a hot inefficient bandaid. I also took apart the turn signal switch and activated each contact independently and I get the same results.
Anybody running a full set of LED bulbs successfully without using ballast resistors?
daveoxide is offline
post #2 of 37 (permalink) Old 12-07-2018, 02:25 AM
66conv6's Avatar
Did you change the flasher to one for LED lights?
Driving a stock Mustang is like driving a sofa. I'm Real Good at driving sofas!
66conv6 is offline
post #3 of 37 (permalink) Old 12-07-2018, 06:09 AM
awhtx's Avatar
I'm no electrical expert but electricity seeks the path of least resistance. It appears that the path of least resistance to ground in your situation is through the other LED. An incandescent bulb has a lot more resistance than an LED and that's why it doesn't illuminate when swapped out for an LED, the electricity finds a route to ground through something with lest resistance like a ground wire.
GypsyR and Woodchuck like this.
awhtx is offline
post #4 of 37 (permalink) Old 12-07-2018, 06:58 AM
Jerry1834's Avatar
Had a similar problem - turned out to be the idiot light on the dash for directionals. Needed to grounded by it self - found that out from the guy from Vintage LED's - $10 bucks for the LED and all fixed.
Jerry1834 is offline
post #5 of 37 (permalink) Old 12-07-2018, 07:20 AM
I suspect a slight ground problem. A LED bulb had very high resistance and a incandescent bulb has very low resistance. When you have a series circuit everything has the same amperage going through it. You add up the resistance of everything then divide that into the supply voltage and you get the amperage. Then you take that amperage and you multiply it by the resistance of each device, that gives you how much voltage that device has on it. The higher the resistance, the higher the voltage. The voltage of each device added up will equal the source voltage. To go one step farther, if I take a battery with nothing connected, the resistance is infinite. 12 volts divived by infinite resistance will produce amperage. Impossible to read amperage but theoretically yes according to Ohms law. So if you put a LED bulb in series with a incandescent bulb the LED bulb is going to be the choke point in how much amperage. It will be a small amount, enough to power the LED but not enough to operate or produce the needed calculated voltage to make the bulb work.
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #6 of 37 (permalink) Old 12-07-2018, 08:35 AM
I meant to add to what I was saying before about the parking and directional lights. The bulbs have 2 filaments that share a common ground. If you have either a poor or no ground on that bulb the power is going to look for one. That means since the 2 filaments share a common point on the shell of the bulb as the ground, the power will go through the other filament to another bulbís ground. It becomes a spider web for the power to flow.
LEDís have significantly higher resistance then a incandescent bulb which means significantly less amperage flow and heat. Adding a resistor is only going to reduce amperage draw and heat even farther. Bottom line LEDís are going to me more susceptible to small, stray currents and working.
Tom
post #7 of 37 (permalink) Old 12-07-2018, 09:21 AM Thread Starter
daveoxide's Avatar
That’s one thing I haven’t explored yet and is next on my list. Did you just have to run a separate ground to the gauge cluster and/or bulb socket or did you install a special LED bulb?
post #8 of 37 (permalink) Old 12-07-2018, 09:23 AM Thread Starter
daveoxide's Avatar
Oh ya, had to do that to just get the taillights to blink correctly before the rest of the lighting got swapped out.
post #9 of 37 (permalink) Old 12-07-2018, 10:24 AM
Jerry1834's Avatar
Special LED with a built in ground. I know this will sound like something coming from leftfield but can you check for a bad coil wire - OK guys stop laughing but my cousin had an issue with a steady on idiot light and very slow/stopping directional LED's - found the coil wire had a small hairline crack and was jumping over to the fuel line - was running a little rough - we changed the coil wire and his LED problem cleared up - was FM coded fix - Fu*king magic.
Flasher note - I used one with a built in ground wire that needed to be hooked up....Just FYI.
post #10 of 37 (permalink) Old 12-07-2018, 11:11 AM
Nailbender's Avatar
Yep!
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, FPA Headers, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is offline
post #11 of 37 (permalink) Old 12-07-2018, 12:28 PM
I run all LEDs outside and inside. Have had some weird issues in the past but they were all caused by either the turn signal switch (replaced it), the flasher (installed one for LEDs w/ ground wire, $9 on amazon), or bad fuse connections (cleaned contacts).
You've already addressed most of these but I would recommend swapping the bulbs in the dash for LED ones as well (or at least the direction ones). You can't dim them but it removes the risk you are causing problems having incandescent bulbs and LEDs on the same circuit.
I also would take a look at your turn signal switch; given you get at least some light in both signals when you click it left or right it sounds like there's a switch issue too since those should be separate circuits.
1967 coupe in dark blue w/ a 302 and 3 speed from a '68
Ojenkins is offline
post #12 of 37 (permalink) Old 12-07-2018, 01:35 PM
One way to solve LED issues is to run them off parallel circuits with incandescent bulbs. Just some small pigtails with 194 sockets/bulbs hiding somewhere. Wire the 194s in parallel with the turn signal filaments. I did this on my TBird in the rear because there were issues with electric bleed through and also the cruise control. Now there are 2 194 bulbs hidden in the trunk that flash or light with the brakes. Sounds dumb, but it worked perfectly.
cougar70 is offline
post #13 of 37 (permalink) Old 12-07-2018, 02:20 PM Thread Starter
daveoxide's Avatar
Yep!
I have a sneaky suspicion this is the cause. It gets really whacky with the headlights on, so if the ground from the cluster to chassis is amiss I can see it finding a path to ground through the gauge cluster backlight bulb wiring which would in turn light up the running lights portion of the front LED’s.
I’ll dig into it again this evening and will let you know what I find out.
post #14 of 37 (permalink) Old 12-07-2018, 05:59 PM
Alan _MacDougall's Avatar
What year mustang is this? The 1970 mustang parking / directional signal lighting is unique for only one year. If the headlights or parking lights are on, then the marker lights on that side will flash alternately with the turn signals. If the headlights or parking lights are off, then the marker lights on that side will flash in unison with the turn signals. 69 mustang side markers don't blink.
Alan _MacDougall is offline
post #15 of 37 (permalink) Old 12-07-2018, 06:38 PM
Nailbender's Avatar
Actually the grounded turn signal indicator form Vintage Led's is for 64.5 and 65 cars using the single turn signal indicator instrument panel. So unfortunately that shouldn't be the problem on a 66 unless it has a 65 dash.
