Engine knocking and runs like crap - Vintage Mustang Forums
 4Likes
post #1 of 17 (permalink) Old 12-31-2018, 11:11 AM Thread Starter
wscott00's Avatar
Im starting yr 6 of a 2 yr build, and finally got the engine in and started. I pulled the engine and transmission from a '90 gt about 4 trs ago. It ran fine before it was pulled.
Its running and idles rough and has a knock. How kind i find the source or eliminate optoins? Since it hasnt run in yrs should i let it idle for 10-15 min and see what happens?
Walter
https://youtu.be/3el6WK5eyF4
wscott00 is offline
post #2 of 17 (permalink) Old 12-31-2018, 11:21 AM
happystang's Avatar
Definitely sounds like a header gasket/exhaust leak. I see you have EFI, my guess is that the exhaust leak is throwing off the O2 sensor readings and making it run like crap .
Huskinhano likes this.
1969 Convertible field find (450hp spaghetti noodle)
1968 Fastback (428 and a 4 speed)
www.SaveClassicCars.net
-Armon
happystang is offline
post #3 of 17 (permalink) Old 12-31-2018, 11:23 AM
Ditto, definitely a exhaust leak
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is online now
post #4 of 17 (permalink) Old 12-31-2018, 11:29 AM Thread Starter
wscott00's Avatar
Ive got a cheap header gasket from autozone. Should i buy specific kind or use some rtv?
wscott00 is offline
post #5 of 17 (permalink) Old 12-31-2018, 11:38 AM
happystang's Avatar
Opinions will vary, but I'm a big of Percy's Aluminum gaskets- they're blow-proof and reusable.
-Armon
post #6 of 17 (permalink) Old 12-31-2018, 12:40 PM
Ya, there definitely needs to be an audio sticky somewhere to teach the differences between a tick, a tap, a slap, a rattle, a knock and an exhaust leak
Any correct gasket should work, if they don't you have torqued them improperly or there's an imperfection on either surface. No type of sealer is gonna work there.
I think the biggest thing is having some sort of pressure twisting on the manifolds from the pipes or its hitting something so when you think its tight its really not. You should be able to press by hand tightly to the head or else you're fighting yourself.
Don't get all HeMan on those little bolts either!
1ofAMillion+ is offline
post #7 of 17 (permalink) Old 12-31-2018, 12:42 PM
MrFlash's Avatar
Did you plug the thermactor “smog” holes at the back of the heads?
A threaded plug goes into each hole.
Huskinhano and 1ofAMillion+ like this.
1970 Mustang coupe
MrFlash is online now
post #8 of 17 (permalink) Old 12-31-2018, 01:01 PM Thread Starter
wscott00's Avatar
Ill check for the smog delete plugs. Should it be on the back of the heads
wscott00 is offline
post #9 of 17 (permalink) Old 12-31-2018, 01:21 PM Thread Starter
wscott00's Avatar
There is a threaded hole on both side. Should there be a plug in them?
So you know what size bolt
wscott00 is offline
post #10 of 17 (permalink) Old 12-31-2018, 01:38 PM
MrFlash's Avatar
When that engine came out of the 90 mustang, there was a crossover tube at the back of the heads that connected the smog holes to the smog pump.
Those holes need to be plugged.
1ofAMillion+ likes this.
1970 Mustang coupe
post #11 of 17 (permalink) Old 12-31-2018, 01:41 PM
MrFlash's Avatar
post #12 of 17 (permalink) Old 12-31-2018, 02:12 PM Thread Starter
wscott00's Avatar
Will i be able to feel air coming from the holes when its running
wscott00 is offline
post #13 of 17 (permalink) Old 12-31-2018, 02:28 PM
MrFlash's Avatar
Most likely.
1970 Mustang coupe
post #14 of 17 (permalink) Old 01-01-2019, 08:47 AM Thread Starter
wscott00's Avatar
When i look into the holes on the back of the heads it blocked off and a straw only goes 1.5" or so inside. I also dont see any smome or feel any air coming out
Is it possible that theae heads dont have a thermactor port
File Type: jpg Screenshot_20190101-084211_Video Player_1546350338507.jpg (267.1 KB, 3 views)
wscott00 is offline
post #15 of 17 (permalink) Old 01-01-2019, 09:16 AM
MrFlash's Avatar
Ok. It appears your heads do not have the holes. Those apparently are not factory ford E7 5.0 heads.
Just for reference, this is what a plugged smog hole looks like.
File Type: jpeg BFB2C60C-6C33-47EC-8003-5AE00E675408_1546352163883.jpeg (59.1 KB, 3 views)
1970 Mustang coupe
