Emergency brake with T5 and JBA H-Pipe - Vintage Mustang Forums
Old 02-04-2019, 10:06 AM Thread Starter
I put a t5 and a JBA 2 1/2 H-pipe on my 66 coupe. I am now working on getting the parking brake hooked backed up but noticing that the standard set up will not fit with the h pipe crossover. Not sure if this is a common issue for the aftermarket exhaust guys but wanted to check. Any advice is appreciated.
Thank you.
cjkcue is offline
Old 02-04-2019, 10:54 AM
I have the same setup in my '66 Fastback. IIRC, I had to slightly tweak the parking brake equalizer lever to clear the H-pipe section, but it was just to prevent it from rattling, not because it was a mile off!
'66 GT Fastback, 302, Edelbrock Top End, Sniper EFI/Aeromotive, MSD, JBA Headers & 2.5" Exhaust, T5Z, Currie 3.55 Trac-Loc
rhutt is online now
Old 02-04-2019, 10:56 AM Thread Starter
Thank you. I will see if I can adjust enough to make it fit. I think it may be far off though. Maybe I tucked the H-pipe up too tight to the body?? I just hate seeing the exhaust hang down if I can avoid it.
cjkcue is offline
Old 02-04-2019, 11:04 AM
I'm running JBA headers which sets up the height of the H-pipe section. You can see where my exhaust ended up through that critical area.
rhutt is online now
Old 02-04-2019, 11:16 AM Thread Starter
This is very helpful. Thank you. I am also running the matching JBA headers. I will get under it tonight and see what tweaks I can make.
cjkcue is offline
Old 02-04-2019, 11:37 AM
RestoMike66's Avatar
I have a quick video of my JBA shorty headers with their H-pipe where you can see the parking brake equalizer lever.
'66 Coupe: GT40 5.0: 670 Holley & Edelbrock RPM AirGap: JBA shorties: AOD w/TCI shiftkit: Granada Disks: R&P steering: 3.55 Currie
RestoMike66 is offline
Old 02-04-2019, 11:52 AM
namloh's Avatar
I have the exact same problem but I have Tri-Y's instead of JBAs. I had a local muffler shop install the exhaust and they tucked the pipes really close to the body. The e-stopp is the only other solution I've been able to figure out but it's awfully pricey! https://www.estopp.com/product-page/...p-standard-kit
namloh is offline
Old 02-04-2019, 12:30 PM
The attached picture might help. Which trans crossmember do you have installed?
rhutt is online now
Old 02-04-2019, 12:36 PM Thread Starter
Very helpful. I have the T5 crossmember. Tubular off eBay.
cjkcue is offline
Old 02-04-2019, 12:39 PM
I just edited the post to flip the image. Sorry. The lever should pass over the top of the tube.
rhutt is online now
Old 02-04-2019, 02:00 PM Thread Starter
Do you guys have any problems with the cables rubbing the driveshaft? With my T5 the cables will rub on the driveshaft unless I secure them to the frame closer to the linkage.
cjkcue is offline
Old 02-04-2019, 04:51 PM
Heem's Avatar
Look at the Mustang Steve Ebrake setup picture. It appears if you use the original mount points it "should" follow the original cable path.
https://www.mustangsteve.com/product/cobra-cables/
Heem is offline
Old 02-04-2019, 06:14 PM
I had a similar problem with my AOD with LBA long tube headers and Magnaflow exhaust. I solved it by bending the parking brake arm to ensure it cleared the exhaust and the driveshaft. You can see it in the pics.
jebsen is offline
Old 02-04-2019, 07:25 PM
I use the Modern Driveline crossmember pictured below. It locates the lever in a position the enables the parking brake cables to clear the driveshaft. It is possible that the pivot point on your crossmember is causing all these clearance issues.
rhutt is online now
Old 02-10-2019, 12:55 AM
tx65coupe's Avatar
I tried to use the JBA H pipe with their headers. It ended up not clearing the T5 cross member from Modern Driveline. I ended up having to modify it to work. If I recall correctly the parking brake equalizer did contact it as well. I retained the down pipes from the headers and completely re-made the H pipe.
1965 Mustang 302, T5, 9 Inch
Instagram @a65stang
tx65coupe is offline
