How can i test msd box and coil - Vintage Mustang Forums
post #1 of 13 (permalink) Old 02-17-2019, 06:42 PM Thread Starter
wscott00's Avatar
Im having an electrical issue and need to test the msd box and the coil. When i test the box by arching the green and purple wire im not getting a spark. Im not even hearing the little buzz from the box.
Is there a way to test the box with out looking for a spark? Can i get a reading from the red and black wire that go to the ignitoin coil?
wscott00 is offline
post #2 of 13 (permalink) Old 02-17-2019, 08:07 PM
Redneckgearhead's Avatar
Are you getting voltage to the msd box? If you're getting a "buzz" from the msd box at any time you've got bigger issues.
Scott
Never let the truth get in the way of a good story
Redneckgearhead is offline
post #3 of 13 (permalink) Old 02-17-2019, 08:13 PM
mikeyhunts's Avatar
I think there are some you tube videos on the subject....
Seems like I remember seeing it.
mikeyhunts is offline
post #4 of 13 (permalink) Old 02-17-2019, 08:19 PM
MrFlash's Avatar
The MSD box has two heavy gauge wires (red and black) that need to be connected to the battery.
Two smaller gauge wires (orange and black) that connect to the coil.
And a smaller gauge red wire that gets switched on by the ignition switch.
With all those properly connected and the ignition on, you should measure 12v from the + side of the coil to a chassis/engine ground.
Shorting the green and purple wires won’t do anything. Those are for the trigger sense circuit and must be connected to the magnetic pickup coil in the distributor.
1970 Mustang coupe
MrFlash is offline
post #5 of 13 (permalink) Old 02-17-2019, 08:20 PM
Actually shorting those two is a way to test for spark. The coil should fire when the circuit is broken.
Scott
post #6 of 13 (permalink) Old 02-17-2019, 08:51 PM
MrFlash's Avatar
However, you could use the white wire and hold it against a good ground. Pull the white wire off and you should get a spark.
1970 Mustang coupe
MrFlash is offline
post #7 of 13 (permalink) Old 02-17-2019, 08:57 PM Thread Starter
wscott00's Avatar
When i put a screwdriver on the other end of the ignition coil wire, lay it close to ground, and jump the 2 wires i dont get a spark.
I should get an arch from the screw driver and usually hear a little zap. I need to get a coil tomorrow. Im looking for a way to know that the box is sending emergy to the coil
wscott00 is offline
post #8 of 13 (permalink) Old 02-17-2019, 09:00 PM
Test for voltage at the coil.
Scott
post #9 of 13 (permalink) Old 02-17-2019, 09:16 PM
MrFlash's Avatar
Apparently I didn’t fully understand the function of the MSD box.
Diagnosis instructions here:
https://www.holley.com/support/troub...ng_techniques/
Never too late to learn something new.
1970 Mustang coupe
MrFlash is offline
post #10 of 13 (permalink) Old 02-17-2019, 09:21 PM Thread Starter
wscott00's Avatar
Should i get a constant reading or just just when i jump the green and purple
wscott00 is offline
post #11 of 13 (permalink) Old 02-17-2019, 09:22 PM
mikeyhunts's Avatar
post #12 of 13 (permalink) Old 02-17-2019, 10:23 PM
Hemikiller's Avatar
If you had a buzzing noise from the box and now it doesn't make any noise and you have no spark, the ignition needs to be repaired by MSD.
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
post #13 of 13 (permalink) Old 02-17-2019, 10:57 PM
maladezo's Avatar
The MSD boxes will not show 12 volts at the + side of the coil. Stock ignitions will.
'67 coupe, 390, 4spd.
maladezo is offline
Similar Threads
Pertronix vs MSD coil Brian66 Vintage Mustang Forum 17 02-07-2019 10:33 AM
FiTech Wiring w/CDi Box and Petronix Distributor stangtim22 Vintage Mustang Forum 4 04-29-2018 09:53 AM
I'm stumped, need help (starting issues) bonjoursm Vintage Mustang Forum 27 01-27-2018 10:27 AM
MSD wiring and misc electrical questions :( Jobucina Vintage Mustang Forum 12 01-03-2018 02:15 PM
MSD 6AL Installation John7660 Mod and Custom Forum 23 12-07-2017 02:21 PM
