Need help running msd w/o box - Vintage Mustang Forums
 1Likes
  • 1 Post By Hemikiller
post #1 of 13 (permalink) Old 02-24-2019, 08:37 PM Thread Starter
wscott00's Avatar
Does anyone know how or if i can run my pro billit distributor without the 6a box? The person helping set things up wants to set the timing without the box.
He says its running at 30* btdc at idle and that the box has the timing all over the place.
wscott00 is offline
post #2 of 13 (permalink) Old 02-24-2019, 08:54 PM
bbmach's Avatar
I believe some can, some can't. What model Pro Billet Distributor?
Do you still have the original instructions? A hit of the MSD website will likely help...
1969 Mach-1 Mustang
460 / C6 / 9"
Back in Dixie DSO 22 (Charlotte)
bbmach is offline
post #3 of 13 (permalink) Old 02-24-2019, 09:08 PM Thread Starter
wscott00's Avatar
Its the 8577. For some reason it will only wants to start at 30* or so. Then the timing jumps around
wscott00 is offline
post #4 of 13 (permalink) Old 02-24-2019, 09:20 PM
blueovalfan68's Avatar
Looking at summits website, says PN 8577 requires the use of an external ignition box, like the 6, 7, 8, or 10 series ignition box.
Not sure how you’re getting the car to run without the box, but I highly recommend you hook it up to an MSD ignition box and set your timing from there.
FYI, I have a 6AL ignition box with the PN 8598 dizzy (same as yours, but with a wide cap).
If checking timing with a light, and it’s all over the place, make sure the wires from the dizzy to the box are correct (I shortened those wires, and accidentally swirched them around. Timing was super erratic)
Hope this helps.
-Chris
'68 Mustang
347ci that has a lot of neat stuff in it
T5 manual trans, alum driveshaft, 9" w/3.70 gears
Suspension parts from SoT, Global West, Maier Racing, and a few others. Works for me!
TCP manual rack (love it)
EPAS (Love this the most)
VWW V45 wheels (like these too)
SoT 13" brakes (stopping is good)
And I finally got a paint job!
blueovalfan68 is offline
post #5 of 13 (permalink) Old 02-24-2019, 09:25 PM
bbmach's Avatar
https://documents.holley.com/8577.pdf
I have the same one in my 460. Needs a box. Have you checked inside the distributor to make sure the weights and springs haven't, well, sprung?
1969 Mach-1 Mustang
460 / C6 / 9"
bbmach is offline
post #6 of 13 (permalink) Old 02-24-2019, 09:34 PM
GT289's Avatar
Originally Posted by blueovalfan68 View Post
If checking timing with a light, and itís all over the place, make sure the wires from the dizzy to the box are correct (I shortened those wires, and accidentally swirched them around. Timing was super erratic)
Hope this helps.
Yup, when the trigger wires are backwards they run strangely if they run at all......
- Douglas Adams
GT289 is offline
post #7 of 13 (permalink) Old 02-24-2019, 09:43 PM
Hemikiller's Avatar
Also, some timing lights do not like the multi-spark and get all screwed up by it. My $400 Snap On digital timing light is useless on an MSD equipped car, the timing jumps all over the place. Have to drag out the old school Craftsman.
kenash likes this.
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
post #8 of 13 (permalink) Old 02-24-2019, 09:48 PM
kenash's Avatar
Yes, the multi-spark can be a problem with some timing lights. I believe you need an analog timing light, (AKA Old school), as suggested.
Ken ..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Maryland
kenash is offline
post #9 of 13 (permalink) Old 02-24-2019, 09:52 PM Thread Starter
wscott00's Avatar
Does it make since that it only wants to start when set around 30*
wscott00 is offline
post #10 of 13 (permalink) Old 02-24-2019, 10:09 PM
Have you verified that your pointer to the harmonic balancer is set correctly?
-Chris
'68 Mustang
post #11 of 13 (permalink) Old 02-24-2019, 10:23 PM Thread Starter
wscott00's Avatar
Nope. It ran well when we pulled it out if the foxbody. I was hoping to just drop it in and go. But i guess thats too mich to ask for.
Should i seg it where it runs the strongest and figure it out once i can take it off the stands and drive it
wscott00 is offline
post #12 of 13 (permalink) Old 02-24-2019, 10:30 PM
Hmm... fascinating. Get the ignition box set up with the dizzy, and probably verify the pointer if you think that it could have been disturbed whe plucked from the donor car into yours. Verify all that you can, one by one. Not trying to insult your intelligence, but when things stop working correctly, especially when it previously was, it helps to go through all the obvious stuff again.
Just seems really odd thay it *only* idles at 30 degrees.
-Chris
'68 Mustang
post #13 of 13 (permalink) Old 02-24-2019, 10:40 PM
The MSD 6A won't alter the timing unless it has somehow lost its brain if it even has a brain. I also got the 6A because at the time I was shopping around(years ago) the rev limiter was not working exactly on the money with the plug in chip so I skipped it. I would probably have wound up not using the limiter anyway.
The timing is run by the pro billet distributor which uses centrifugal weights and springs. Total timing can be altered with one of a series of colored donuts of different sizes. If you have a broken spring or a spring that has disconnected itself from the weight post or something else inside there that has gone wrong that will make the timing act wonky.
65 2+2, 331, C4 presently apart for complete a restore
1979 Ford F150 custom, 302, C4, AC, tilt wheel, main transportation
macstang is offline
Similar Threads
How can i test msd box and coil wscott00 Vintage Mustang Forum 12 02-17-2019 10:57 PM
Classic Performance Products (CPP) Steering Box Installation 1965 Coupe pastangguy Vintage Mustang Forum 4 12-20-2018 07:48 AM
66 Coupe Ignition Wire for MSD box? quick50stng Vintage Mustang Forum 3 10-23-2018 02:09 PM
Pro-Billet MSD Distributor for 351W p/n 8478. Brand new in box. cjkcue Engine and Drivetrain Parts For Sale 2 12-22-2017 08:34 PM
