Has anybody run their PCV to the rear port on an small block Edelbrock RPM intake manifold? If so, is the factory formed PCV hose long enough to reach?
I'm sure it's been done, but a much better way is to use the PCV spacer that fits under the carb, or if your carb had a PCV port, use it. Doing it the correct way distributes the gasses more evenly to each cylinder than to just one cylinder.
Just wanted to second this response; if you run the PCV to a port in the manifold all the PCV gases (unburned fuel, oil vapors, etc.) go to one cylinder, plus to the extent you're pulling in air through the breather that cylinder will run lean relative to the others. It won't hurt the engine any time soon but if you have the option of running it to the carb (which you do) then that would be ideal.
Yes the hose will reach, I did it this way because I was worried about clearance between the air cleaner and the hood and my Holley has no PVC port. But I see what John is saying about the gases going to one cylinder.
I will further clairify, I have a Edelbrock carb and while it is equipped with a PCV port in the front, I would prefer to keep the appearance neat and not have a hose run towards the front. That is why I am asking. Looking down the intake manifold, where the hole is installed is in the common area where runners run to both sides of the engine.
I believe Edelbrock recommends using the back port on the carb for the brake booster and front port for PCV.
Is there any other options for where the PCV hose could be connect? Running the hose around the front just doesn't look clean. Would prefer to not use spacer.
Which Edelbrock carb are you running? Do you have power brakes installed that require a vacuum port? Most Edelbrocks have two large manifold vacuum ports suitable for PCV use, one in the front and one in the rear. You can cap the front PCV designated port and use the rear port. If you require a brake booster vacuum source, you can plumb it directly to the intake manifold. To get the answer you're looking for, you have to provide a picture or model number of the carb.
Related Threads
Vintage Mustang Forums
4M posts
89.2K members
Since 2001
