About 15 years ago I painted my engine using Duplicolor 1606, it is out of the car and needs some freshening up. Has anybody every bruished POR15 Engine Paint over cleaned and sanded rattle can paint? The egnine is currently sitting on a set of storage legs with the transmission attached, not in the best configuration to rattle can... thanks
bad idea. won't work. POR will not stick. it needs a bare rusty surface to adhere to. read their instructions. i would just clean & refinish with the previously used product unless you want to redo it in a short time.
This is Ford Corporate Blue POR 15 brushed on my 331 Stroker build. I removed all the old paint & took the block down to bare metal. POR 15 also has a metal prep fluid to use prior to the actual color.
I painted my bare engine with POR-15 Ford Corporate Blue as well, brushed it on and am very pleased with how it turned out. I'd check with their tech department if you want to know the proper way to paint the engine enamel over a previously painted engine. I had brush strokes showing in mine so I contacted them and their tech advised that I sand the engine with 320 grit sandpaper, blow off the dust or use a tack cloth (no solvents or cleaners) then apply another coat thinned 5-10% so it will flow better. I suspect painting over old, previously applied paint would probably entail the same process, but remember your topcoat is only as good as the substrate. If you feel your base is good then it would be worth a shot. I soda blasted my engine while it was together then painted it.
Related Threads
Vintage Mustang Forums
4M posts
89.2K members
Since 2001
