Throttle Cable And Bracket For Sniper EFI - Vintage Mustang Forums
 2Likes
  • 1 Post By mikeyhunts
  • 1 Post By rhutt
post #1 of 12 (permalink) Old 03-21-2019, 11:57 AM Thread Starter
I am getting ready to install Holley Sniper EFI in my 1969 build. What throttle cable and carb (Sniper throttle body) brackets work with an OEM accelerator pedal. I am not sure if a Lokar cable will work with a stock pedal. Also not sure if a stock cable and carb bracket will work with the Sniper. What are you all using out there with the Sniper?
cg in tx is offline
post #2 of 12 (permalink) Old 03-21-2019, 12:30 PM
mikeyhunts's Avatar
I had to get creative.
Ordered in three different bracket and nothing worked.
I adapted my JEGS bracket over with an aluminum plate I made.
I can take closer pics if needed when I get home.
Super Sniper on 351c.
Lokar cable on factory pedal.
68 coupe
mikeyhunts is online now
post #3 of 12 (permalink) Old 03-21-2019, 12:33 PM
Grabber70Mach's Avatar
What was the deciding factor for the Super Sniper over the Sniper?
Grabber70Mach is offline
post #4 of 12 (permalink) Old 03-21-2019, 12:35 PM
Lokar sells a Sniper bracket; http://www.lokar.com/assets/instruct...FI-Bracket.pdf
I used this JEGS 24 in. Throttle Cable. There was a slight modification to the cable to be able to use the stock accelerator pedal. I removed the clevis pin and then the clevis bracket slides off. The stock cable has a little plastic washer that should be moved over to the universal cable. You have to cut your original cable to get the washer out. You might be able to find a steel washer that will work, but plastic is quieter. I didn't want to destroy my original cable and found a similar cable on a junkyard Lincoln.
Lokar sells prettier cable and a billet accelerator pedal but Lokar is never cheap.
cougar70 is online now
post #5 of 12 (permalink) Old 03-21-2019, 12:36 PM
mikeyhunts's Avatar
HP
My motor is a rowdy 700hp.
Allegedly.
Havenít dynoíd it,
But at this point during test drives, itís barely streetable IMO.
The Super is rated to 700hp, and has some many more bells and whistles like the terminator.
Grabber70Mach likes this.
post #6 of 12 (permalink) Old 03-21-2019, 12:40 PM
post #7 of 12 (permalink) Old 03-21-2019, 12:45 PM
I can't help you with the actual cable installation, but on my '66 I was able to use the exact same linkage as I was running on the 670 Street Avenger that the Sniper replaced. The same linkage was also used on my first carb, a 600cfm Edelbrock. If your current linkage is configured to work with a standard Holley or Eddy carb, you should have no problem adapting it to the Sniper.
I did fabricate a small plate that extends the length to the throttle lever, making the transition off idle much smoother.
Rowdy likes this.
'66 GT Fastback, 302, Edelbrock Top End, Sniper EFI/Aeromotive, MSD, JBA Headers & 2.5" Exhaust, T5Z, Currie 3.55 Trac-Loc
rhutt is online now
post #8 of 12 (permalink) Old 03-21-2019, 12:47 PM
2-70's's Avatar
I used a Lokar cable and bracket for my install, and I didn't have any issues with the cable attaching to my pedal. I have too much throttle cable but it was the shortest I could find from Lokar.
2-70's is offline
post #9 of 12 (permalink) Old 03-21-2019, 01:59 PM Thread Starter
I am starting from scratch. The only items I currently have are the stock pedal and the Sniper. I don't want to order stuff that doesn't work. Done that too many times already.
cg in tx is offline
post #10 of 12 (permalink) Old 03-21-2019, 02:00 PM
mikeyhunts's Avatar
Me and you both.... A PITA.
post #11 of 12 (permalink) Old 03-21-2019, 02:28 PM
If you have an automatic you will need the Lokar kickdown cable/bracket. I have one but the eyelet is too small to fit the kickdown lever on the transmission. There's always something else.
post #12 of 12 (permalink) Old 03-21-2019, 02:34 PM Thread Starter
Using a 4R70W so don't need a kickdown cable.
cg in tx is offline
Similar Threads
Throttle Cable Connector(s) for 1969 302 2 Barrel MrMagoo Vintage Mustang Forum 7 11-03-2018 01:53 PM
Lokar C4 transmission kick down cable bracket Bella Vintage Mustang Forum 2 09-09-2018 10:16 AM
E-Brake cable bracket don_k Classic Mustang Wanted Ads 4 02-19-2018 09:46 AM
T5 Swap MDL Clutch cable bracket support upgrade jcsinc Vintage Mustang Forum 2 01-23-2018 10:39 AM
MDL clutch cable bracket Tubbster1966 Vintage Mustang Forum 1 12-01-2017 03:33 PM
