No Start (No Spark) after oil change? - Vintage Mustang Forums
 7Likes
post #1 of 17 (permalink) Old 03-25-2019, 01:15 PM Thread Starter
I changed my oil last night, and the car wouldn't start after that. I'll start with a little background first.
289, Pertronix, working perfectly before oil change. I jacked it up and changed the oil. Nothing interesting happened. I pulled the coil wire and turned it over a couple times to fill up the oil filter. Put the coil wire back on and here we are. So far, I've done the following to troubleshoot.
1) Measured primary and secondary resistance at coil. .8ohm, 4.1k ohm. Probably fine.
2) Measured voltage at coil with key on and while turning over. 3.1vdc both times. Seems low.
3) Supplied 12vdc to coil + and tried to start. Nothing.
4) Check voltage to pertronix. 12.01vdc. Fine there
5) Ohmed out coil wire, plug wires. They are fine.
6) Checked under cap. Found a bunch of weirdness.
A: weights are missing?
B: shaft moves up and down and rotates 5-10 degrees freely.
C: Verifed that it was spinning with the motor.
If I want to go back to points, how much am I missing? (See pic.) Am I just better off sticking with pertronix? Is that rotational free play as big a problem as I think it is? And no, I didn't have the key on when changing the oil.
jgrote is offline
post #2 of 17 (permalink) Old 03-25-2019, 02:02 PM
myfirstcar66's Avatar
Try another coil. Maybe something separated when you pulled the wire. FYI, i just pour clean oil into my inverted filter and let it soak up, top it off a little before spinning it on so it isn't dry on startup. I do the same with all my engines and changes. The mechanical disteubutor weights are under the flat plate I believe. And the distributor shaft will turn a small amount by hand.
RV6, Ojenkins and jpacosta481 like this.
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
...my first car
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto •Disc Brakes
•Dual Exhaust •Power Steering
•Dealer Air Conditioning •Console
'66 Nightmist / Blue & white deluxe coupe
•Factory Air Conditioning •Console
WAITING FOR RESTORATION
myfirstcar66 is offline
post #3 of 17 (permalink) Old 03-25-2019, 05:02 PM Thread Starter
I don't think it's the coil. I have a sneaking suspicion it's the igniter. I'm thinking about replacing the distributor entirely. If I do, I'll need 12v for it. I know the wire going to the coil is a resistor wire, but where is the resistor? Is it in the wire in the engine bay, or under the dash?
jgrote is offline
post #4 of 17 (permalink) Old 03-25-2019, 05:30 PM
66ryan's Avatar
If it's a 65 or 66 then the resistor wire is under the dash. It's pink, made of something other than copper, can't be soldered easily, shouldn't be cut. It plugs into a red-green wire at your ignition and then runs to the main disconnect on the right. It's pushed into that connector.
Personally, I'd do one of two things if you want to remove the resistor wire:
1) Use another wire with a bullet connector, plug it into your ignition, and run it through the firewall to the ignition coil. This will give you the full 12v in the run position.
2) Use a relay mounted in the engine bay. Connect the current wiring to the switched power of the relay and connect a 12v source (battery side of the starter relay) to the power for the relay. Then connect that output to the ignition coil. That will also give you a 12v power source when the key is in the run position.
66ryan is offline
post #5 of 17 (permalink) Old 03-25-2019, 10:04 PM
Woodchuck's Avatar
If you have a separate 12V source for your Pertronix red wire then you want to leave the resistor wire in place for your OE-style coil.
It sounds like you've tested everything thoroughly and eliminated all the possibilities except the Ignitor. You DID remember to slip the little plastic "thingy" back over the distributor cam, right?
FWIW, if you want reliable "electronic" ignition you can drop in a DurasparkII distributor and have it trigger any of the "big 3" ignition boxes or a MSD, but my preference is the Mopar Chrome unit because of its size and "package".
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #6 of 17 (permalink) Old 03-25-2019, 10:13 PM
c6fastback's Avatar
Send a message via AIM to c6fastback
Nobody is going to blame it on a Fram oil filter😂
jgrote likes this.
68 302-4V w/1.84",1.54" ported , Comp XE268H , 2200 rpm Hughes converter, 3.25 9" w/10x2.5" shoes , MSD box/distrib , RPM intake , 670 Holley , cross flow aluminum radiator , Granada discs......
Michael S.
c6fastback is offline
post #7 of 17 (permalink) Old 03-25-2019, 10:47 PM
I had an original Pertronix Ignitor quit on me once, 2 hours from home, stopped to visit my brother a few minutes and car wouldn't start. Dropped in my points plate that already has points and condenser mounted in it, checked the gap and fired right up. Ran for a week while I waited on an Ignitor II , still keep the points and a spare coil in my go-bag.
...my first car
post #8 of 17 (permalink) Old 03-25-2019, 10:50 PM Thread Starter
I was a good boy and used a Motorcraft oil filter, along with Valvoline 10w30. I had to buy an STP filter too, because it was cheaper to gt the oil that way. But because my parts guy agrees that you can't put that crap on an old Mustang, he sold me the Motorcraft filter for an extra dollar. I love my local Autozone because they have a core group of people that have been there for at least a few years, are car people, and actually hire women. It's like a Napa that I can afford to shop at. And @Woodchuck, I do have a separate source of power for the igniter. The easy way to fix this is to by another Pertronix, but I really don't want to. My local buddies are trying to talk me into going HEI. It's the cheapest, easiest, reliable option as far as I can tell. Anyone else run HEI? (Off to put on my flame retardant suit now.)
jgrote is offline
post #9 of 17 (permalink) Old 03-25-2019, 11:14 PM
kenash's Avatar
I, for one, think you need to revisit your steps just after pulling the "coil wire" to prime the filter. Yes, all of the other thoughts, although valid in their impact, would be highly unlikely after simply changing the oil. Check the continuity of the "coil wire". Insure it's fully inserted in the cap.
watto1 likes this.
KenA..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, Maryland
kenash is offline
post #10 of 17 (permalink) Old 03-26-2019, 09:31 AM
watto1's Avatar
This..
Originally Posted by Woodchuck View Post
You DID remember to slip the little plastic "thingy" back over the distributor cam, right?.
Sent from my SM-G950F using Tapatalk
watto1 is offline
post #11 of 17 (permalink) Old 03-26-2019, 03:44 PM
JeffH13's Avatar
It's not a resistor sitting by itself, it's the entire wire. Plugs in near the key and runs out to the distributor - it feels different than other wires, very flexible even when 50+ years old. This is what mine looks like, despite the warning I spliced it into my AAW harness to use for my Duraspark coil.
___
JeffH
66 Coupe, 302-4V, SROD
(had to create new username when I changed email address)
JeffH13 is offline
post #12 of 17 (permalink) Old 03-26-2019, 04:48 PM Thread Starter
Yes, I remembered the plastic thingy. I was concerned about the 3.1vdc I read at the coil, but I'm not sure what voltage I'm supposed to have there. However, hooking 12vdc to the coil+ did not help. That kinda rules out any issue with the resistor wire. The coil Ohms out within spec. I have 12vdc at the Pertronix, so power to that isn't the issue. I've decided to just move on and replace the distributor for now. An HEI is $50, and requires little more than 12vdc, new plug wires, and 90 minutes of my time.
jgrote is offline
post #13 of 17 (permalink) Old 03-26-2019, 05:32 PM
66ryan's Avatar
Have you pulled a spark plug to be absolutely sure you're not getting a spark? Have you checked the carb to make sure there's gas getting to it?
66ryan is offline
post #14 of 17 (permalink) Old 03-26-2019, 05:42 PM
jdub's Avatar
My general philosophy is that it's nothing you didn't touch. You touched the coil when you pulled the wire. Seems logical.
However I can't tell you how many times I've gone totally out of my mind when something else failed coincidentally. Last time for me it was the kill switch on my motorcycle. I'd recently replaced the points and rectifier- had to be something related to that, right? Wrong. After a couple days of going crazy I decided to pull the headlight and jump the kill switch. Fired on the first kick. SO, while logic says your problem is related to the coil, experience tells me that with these old vehicles, coincidence comes into play quite a bit. Good luck!
1965 Mustang
jdub is online now
post #15 of 17 (permalink) Old 03-26-2019, 08:24 PM Thread Starter
I'm a service technician professionally. I don't work on cars, but troubleshooting is something I live, eat, and breath. That is why the first thing I checked was all the things I touched. From there, I went back to basics. Fuel, air, spark. Air is a no brainer. I could smell the fuel. To be sure, I pulled a plug and found it quite wet. Besides, fuel problems don't sound like this. It just turns. It isn't even trying to start. Now for some of my limitations. I can't pull a plug and check for spark because I just don't have enough hands. There are some things I can get help from the better half with, but she is not keen on me holding a spark plug while she's trying to start the car. Since that was not an option, I started testing the ignition system from beginning to end. Power to coil: check, but low. Give it 12v. No help. Power to ignitor: check. Coil test passes. Wires ohm out within spec.
jgrote is offline
Similar Threads
Spark Plugs Wayne67vert Vintage Mustang Forum 7 12-31-2018 09:51 PM
Oil change frequency JeffH13 Vintage Mustang Forum 28 09-15-2018 12:36 PM
Oil change, now the oil light comes on (sometimes) TACOaKLey Vintage Mustang Forum 6 05-20-2018 08:10 PM
Rebuilt head installed ready to start. When to change the oil? Now or run it first? reweb67 Vintage Mustang Forum 7 02-18-2018 11:58 PM
High mileage F150 - oil pressure issue Kelly_H General Discussion (Non-Vintage Mustang) 10 12-24-2017 09:21 PM
