Car won't idle for more than 45 seconds - Vintage Mustang Forums
 12Likes
post #1 of 21 (permalink) Old 03-26-2019, 10:10 AM Thread Starter
I was running a hot wire to the starter solenoid from my new carb w/ an electric choke and started to experience a new problem. The car would start and idle fine. When taking the car for a drive, The car would start to die sooner and sooner each trip, It was difficult to get it started then. After some Heart issues I let the car sit for 6 months. Now, I can't get it out of the garage because it will only idle for 45 seconds and then turns off. No stutter or stumble it just shuts off. The car fires right back up without even touching the throttle. My buddy and I tuned the carb last night and it purrs like a kitten for 45 seconds then dies. Is it possible I might have caused some problems trying to run a hot wire from the electric choke to the starter solenoid? I replaced the carb with one with a mechanical choke. I run MSD ignition (6AL) in my 289 66 fastback. Another thing we did was replace all new springs in the distributor at the time. I purchased a new ignition switch and a new MSD blaster 2 coil from summit. If that does not work what should I consider?
fbovi1 is offline
post #2 of 21 (permalink) Old 03-26-2019, 10:51 AM
myfirstcar66's Avatar
Almost sounds like the coil is energized when you start the car but when voltage falls, it dies. Do you have the small wires attached to the correct posts on the solenoid? A new solenoid is cheap. Try that. If it doesn't fix it, you still havea spare. I dunno. Attach a volt meter to various places of interest and watch the voltage. Maybe when running something heats up and loses contact, and cools enough when off to start again. This is why my old car stays low-tech.
fbovi1 likes this.
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •16:1 Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
•Original Styled Steel Wheels
...my first car
'66 Emberglo / Parchment coupe
•289 / 2100 •C4 Auto •Disc Brakes
•Dual Exhaust •16:1 Power Steering
•Dealer Air Conditioning •Console
...son's first car
myfirstcar66 is online now
post #3 of 21 (permalink) Old 03-29-2019, 05:40 PM
22GT's Avatar
I would not connect the choke wire to the solenoid.
For the time being, disconnect the choke wire, and make sure the choke is fully open when you start the engine. That will eliminate choke problems.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #4 of 21 (permalink) Old 03-29-2019, 07:54 PM
jdub's Avatar
My first instinct would be to blame the MSD.
1965 Mustang
jdub is offline
post #5 of 21 (permalink) Old 03-29-2019, 08:27 PM
Woodchuck's Avatar
Time to go back to basics... is it fuel or is it spark?
Grab your timing light and hook up the inductive lead to the coil wire. Run the light and wires out the back of the hood by the cowl and bungee/tape/zip-tie it to the passenger-side wiper arm. Tape the trigger down.
Hop in the driver's seat and fire it up and immediately bring the rpms to around 1,500.
When the engine dies, look at the timing light. If the light keeps flashing as the engine dies you have a fuel problem. If the light cuts out and then the engine dies you have a spark problem.
Once you determine the actual cause you can further diagnose the "system".
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #6 of 21 (permalink) Old 03-29-2019, 08:27 PM
I am not sure why you have wired the hot wire of carb choke to the starter, the choke hot wire should go to a "hot" 12v + when in run.
Have a read through the attached installation instructions.
https://www.cjponyparts.com/mustang-...uctions/a/334/
JSHarvey likes this.
bd8134 is offline
post #7 of 21 (permalink) Old 03-29-2019, 08:34 PM
Woodchuck's Avatar
FWIW, since the voltage of a circuit reflects ALL the resistance in the circuit, adding a big resistor, which is what the heating element in the choke really is, you're significantly reducing the voltage available to the coil when connecting it in this manner.
If your car doesn't have an alternator warning lamp, you can attach the choke heater to the alternator stator (STA) terminal which generates (nice pun, eh) 1/2 of charging voltage only when the engine is turning over, or switch the choke on using a relay triggered by a "key on" circuit.
Bart
What, me worry?
- Alfred E. Neuman
post #8 of 21 (permalink) Old 03-29-2019, 09:02 PM
jdub's Avatar
If your car DOES have an alternator warning lamp, what happens if you connect the choke to the alternator stator? This is how I have mine setup.
Woodchuck likes this.
1965 Mustang
jdub is offline
post #9 of 21 (permalink) Old 03-29-2019, 09:17 PM
Woodchuck's Avatar
Well, that's a good question. As the stator is connected to a sensing circuit in the regulator it would seem dependent on whether said voltage, normally 1/2 of the AC wave, after resistance, would be sufficient to allow the regulator to function "normally". In other words, if it works right then fine, eh?
Bart
What, me worry?
- Alfred E. Neuman
post #10 of 21 (permalink) Old 03-29-2019, 09:18 PM
jdub's Avatar
I don't think my system is charging. The light works but it never turns off. My battery voltage is pretty high (13s) so it's hard to say if I am getting anything by putting a meter across the battery but I am pretty sure I am not.
1965 Mustang
jdub is offline
post #11 of 21 (permalink) Old 03-29-2019, 09:53 PM Thread Starter
When I wired the chock to the Stator terminal it seemed that the butterfly would never completely open. I bought a Manual choke carb.
I REPLACED THE COIL AND THE CAR IS RUNNING LIKE A CHAMP.
Thanks for all the advice especially the person who suggested I start off replacing small parts before I replace the expensive parts until I find the problem. I was going to replace the entire MSD 6AL box, distributor and coil. Luckily it was the cheapest part, the coil.
Now onto:
Brakes
Front suspension
Excessive Heat through the fire wall
Door locks that don't work
oil Leaks
transmission leak
Fan shroud
Thanks Meacum Auctions!
Thanks again
myfirstcar66 likes this.
fbovi1 is offline
post #12 of 21 (permalink) Old 03-30-2019, 12:06 AM
66ryan's Avatar
Originally Posted by fbovi1 View Post
Now onto:
transmission leak
When you figure this out, let the world know. From everything I've seen, these transmissions were designed to leak like it's just as important as switching gears.
66ryan is offline
post #13 of 21 (permalink) Old 03-30-2019, 12:25 AM
Between all my power steering and transmission leaks, it looks like a crime scene under my car.
dobrostang and 66ryan like this.
jgrote is offline
post #14 of 21 (permalink) Old 03-30-2019, 08:26 AM
I don't have any leaks and my fluid looks and smells great but suddenly yesterday it shifts 1-2 and 2-3 like I robbed a bank and the cops just rammed me. I hafta get 3k rpm before it will shift and BAM. I suspect the modulator valve or vac line. I swear, if it isn't one thing...
...my first car
...son's first car
post #15 of 21 (permalink) Old 03-30-2019, 08:47 AM
coupster's Avatar
Originally Posted by myfirstcar66 View Post
I have any leaks and my fluid looks and smells great but suddenly yesterday it shifts 1-2 and 2-3 like I robbed a bank and the cops just rammed me. I hafta get 3k rpm before it will shift and BAM. I suspect the modulator valve or vac line. I swear, if it isn't one thing...
check vacuum modulator and the line to it. Is your car idling really high too? Vacuum leak.
65 FB 289/3sp Rangoon Red/Red interior
68 Coupe 200/6 T-5 Diamond Blue/Blue interior
68 Coupe 302/C4 Black interior
69 Coupe 250/6 C4, Blue/Black interior
70 Coupe 390/C6 Auto Gold Metallic/Ginger interior
2010 Gold V6/Auto Sunset Gold/Black interior
65 Falcon Vintage Burgundy/Palomino interior
coupster is offline
Similar Threads
Congratulations to dobrostang patrickstapler Ride Of The Month Winners! 11 01-04-2019 09:19 AM
Congrats Calamity Jane - Nice WSJ article Garth66 Vintage Mustang Forum 62 10-06-2018 10:44 AM
How to increase foot traffic to your car at a car show 66#3 Vintage Mustang Forum 17 08-27-2018 01:39 PM
How much are 73 h codes worth Skidont Vintage Mustang Forum 46 07-02-2018 10:21 AM
What should I ask for this car? carguytroy Vintage Mustang Forum 7 06-26-2018 01:39 PM
