Have some repro black coated (1 side) paper water shields for my '67 with deluxe interior and have some install questions/assumptions:
Shields go on coating side toward the interior?
Shields go on before the door cup angle bracket?
Goop around the window crank and door handle shafts - anywhere else? Photos?
Punched holes for door panel clips don't seem to align very well with holes in door, is this typical?
Is it typical to have to trim any of the outer edges? I don't see a need yet but thought I'd ask.
Any other tips/tricks, things I should know?
Simple job I know but thought I'd ask just in case.
Shields go on coating side toward the interior? The black side out, so you'll be looking at brown when they are installed.
Shields go on before the door cup angle bracket? I think not.
Goop around the window crank and door handle shafts - anywhere else? Photos? Seal the edge with strip-caulk.
Punched holes for door panel clips don't seem to align very well with holes in door, is this typical? Sadly. You need to finesse the clips before installation.
Is it typical to have to trim any of the outer edges? I don't see a need yet but thought I'd ask. Not usually, they are die-cut.
Any other tips/tricks, things I should know? Probably, just keep asking.
Can't the repro manufactures' even get these right? Sheesh!
Shields go on before the door cup angle bracket? I think not. My disassembly photos show shield behind the angle bracket - doesn't mean that's the way it came from the factory. It does mean I'd have to cut a slit for it.
Punched holes for door panel clips don't seem to align very well with holes in door, is this typical? Sadly. You need to finesse the clips before installation. Shield holes just don't align with holes in doors for the panel clips, to the point where to finesse them would mean punching new holes beyond the shield edges - a good 0.25" to 0.375" out. Hey, maybe I can steam them into submission.
Is it typical to have to trim any of the outer edges? I don't see a need yet but thought I'd ask. Not usually, they are die-cut. These are definitely hand trimmed unless of course the die has ragged, scissor-like edge contours.
I'll bet a lot of folks don't even bother with these?
Thanks for your reply.
Has anyone gotten a set without the problems described above and if so where?
I bought a set for my car, but after struggling to get the deluxe door panels on, totally forgot to install them. I even have a tube of the proper adhesive from NPD.
Related Threads
Vintage Mustang Forums
4M posts
89.4K members
Since 2001
