1967 Door Water Shields - Vintage Mustang Forums
post #1 of 5 (permalink) Old 03-26-2019, 06:07 PM Thread Starter
Have some repro black coated (1 side) paper water shields for my '67 with deluxe interior and have some install questions/assumptions:
Shields go on coating side toward the interior?
Shields go on before the door cup angle bracket?
Goop around the window crank and door handle shafts - anywhere else? Photos?
Punched holes for door panel clips don't seem to align very well with holes in door, is this typical?
Is it typical to have to trim any of the outer edges? I don't see a need yet but thought I'd ask.
Any other tips/tricks, things I should know?
Simple job I know but thought I'd ask just in case.
Thanks!
nmb67fb is offline
post #2 of 5 (permalink) Old 03-26-2019, 09:34 PM
22GT's Avatar
The black side out, so you'll be looking at brown when they are installed.
I think not.
Seal the edge with strip-caulk.
Sadly. You need to finesse the clips before installation.
Not usually, they are die-cut.
Probably, just keep asking.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #3 of 5 (permalink) Old 03-27-2019, 06:07 PM Thread Starter
Can't the repro manufactures' even get these right? Sheesh!
I think not.
My disassembly photos show shield behind the angle bracket - doesn't mean that's the way it came from the factory. It does mean I'd have to cut a slit for it.
Shield holes just don't align with holes in doors for the panel clips, to the point where to finesse them would mean punching new holes beyond the shield edges - a good 0.25" to 0.375" out. Hey, maybe I can steam them into submission.
These are definitely hand trimmed unless of course the die has ragged, scissor-like edge contours.
I'll bet a lot of folks don't even bother with these?
Thanks for your reply.
Has anyone gotten a set without the problems described above and if so where?
nmb67fb is offline
post #4 of 5 (permalink) Old 03-27-2019, 06:58 PM
69GT350H's Avatar
I bought a set for my car, but after struggling to get the deluxe door panels on, totally forgot to install them. I even have a tube of the proper adhesive from NPD.
VMF Build Thread - 1969 Shelby GT350 Hertz rebuild Gallery
Used by Hertz for the 1969 "Rent-A-Racer" program at Miami Internation Airport.
69GT350H is online now
post #5 of 5 (permalink) Old 03-27-2019, 07:47 PM Thread Starter
lol - I envisioned doing exactly the same thing so I'm not even going to test fit the panels and clips until I get the water shields worked out. I'm sure I would have called it done after a fight if I had. Though I did cheat a little by test fitting with only 2 clips.
nmb67fb is offline
Similar Threads
1967 - 1973 Cougar & Mustang AOD / Tremec Conversion Crossmember-Free Shipping NEPM 1964 1/2 through 1966 Mustang Parts For Sale 0 03-07-2019 01:33 PM
1967 - 1973 Cougar & Mustang T5 / T-5 Conversion Crossmember - Free Shipping NEPM 1964 1/2 through 1966 Mustang Parts For Sale 0 03-07-2019 01:31 PM
Sale: 1967 - 1973 Cougar & Mustang AOD / Tremec Conversion Crossmember-Free Shipping NEPM 1967 through 1968 Mustang Parts For Sale 0 01-10-2019 10:03 AM
Jazzman's 1967 Ford Mustang Build: FlipTop gets a Sister! Jazzman Build Forum 2 07-19-2018 02:39 AM
Please educate me on disk disc brake Dust Shields Mustangerbob1 Vintage Mustang Forum 8 04-13-2018 05:00 PM
