Need Engine Gurus!!! - Page 6 - Vintage Mustang Forums
 27Likes
post #76 of 89 (permalink) Old 04-06-2019, 11:31 PM
Scarlet-302's Avatar
From experience, its not too bad a job to drop the pan and start pulling bearings. If you're also thinking of pulling heads again, it may be better to just yank the motor and go through it again on a stand. It's a bummer but it'll be easier to inspect everything and clean the junk out. Aluminum in oil will appear as a golden color so it could be bearing material. Did you find a lot of material? Could be leftover machining junk if you didn't personally clean the block when you got it, or did you have the machine shop build the bottom? When I had my block machined they claimed to have cleaned it but I went through 3-4 cans of brake clean once I got it home just rinsing it out and the junk that came out of the oil galleys and such surely would have doomed my rebuild.
gikort and bbmach like this.
Scarlet-302 is offline
post #77 of 89 (permalink) Old 04-07-2019, 03:51 PM Thread Starter
gikort's Avatar
I didn't find too much, just some small flakes. I think I'm going to pull the pan and look at a few bearings. If they're bad, then I'll pull the engine. My dad's jeep is under the hoist and its engine is on the stand, so it may be a couple weeks before I can pull it if that's what I end up needing to do.
gikort is offline
post #78 of 89 (permalink) Old 04-13-2019, 02:59 PM Thread Starter
gikort's Avatar
I pulled the thrust cap and one rod bearing. Rod bearing looked good. Thrust bearing looked like this:
What do you guys think? Mains too tight causing the bog when they heat up and expand? I believe they plastigauged at .0015" when I built it.
gikort is offline
post #79 of 89 (permalink) Old 04-13-2019, 03:45 PM
MrFlash's Avatar
Odd wear pattern.
Almost like something’s not straight or is out-of-round.
1970 Mustang coupe
MrFlash is offline
post #80 of 89 (permalink) Old 04-13-2019, 10:27 PM
When I pulled my mains after 2500 miles because I had a Piston issue, none of my bearings looked polished like that, they all mostly looked as they did when they came out of the box with some light marks. Seems to me you're probably out of spec there if that's what it looks like after as little run time as you have
gikort likes this.
post #81 of 89 (permalink) Old 04-13-2019, 10:58 PM
Turnall's Avatar
Originally Posted by MrFlash View Post
Odd wear pattern.
I would agree.
What rpm do you plan to spin that engine gikort? I ask because I've read "loose is fast" so I went with bearings that are .001" smaller on the mains putting me at .002" on them. My rod bearings are tighter at .0015". Not sure that would make any difference on the thrust bearing to what you are seeing though...
Allen
Turnall is offline
post #82 of 89 (permalink) Old 04-15-2019, 12:48 PM
That looks like they machined the mounting/bolt face flat but did not line bore the cap to get the overall diameter correct again.
bbmach likes this.
68 GT Vert - J Code (1st car I ever drove in '73, dad bought it in '71)
67 C Code Vert Sports Sprint (1st car I ever bought in '75)
06 Vista Blue with Pony Package (1st Mustang I ever bought new)
MCA #49294 Grayson, GA (Atlanta)
daves67ss is offline
post #83 of 89 (permalink) Old 04-15-2019, 02:54 PM
gikort,
You may have a situation where the ring grooves in the piston are not deep enough for the rings you are using. This would show by the rings sticking up above the side of the piston when the piston is held on it's side. IF the rings stick above the side of the piston , they WILL bind as the piston grows with heat and stop the engine from running. As soon as they cool enough , the engine will " start right up" until the heat causes the ring to bind again. You would be surprised how many guys have had this happen. After listening to all of the well meaning ideas others have given I feel confident this s what's happening to you.
Randy
68Hildago likes this.
'66 GT350H-3 time cover car - Car Craft July'77,Modified Mustangs and Fords Feb2011 ( w/article), Mustang Monthly June 2014. Bracket raced by me for the last 44 years. Yes it is a real one.
'68.5 R code GT fastback
'67 Ranchero 408W -427 glass hood
'78 F350 "Oleynik" car hauler
Ford Experimental parts collector
GT350HR is offline
post #84 of 89 (permalink) Old 04-15-2019, 03:45 PM
What about the thrust surface? That looks like something is going on too.
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #85 of 89 (permalink) Old 04-15-2019, 04:02 PM Thread Starter
gikort's Avatar
Originally Posted by Turnall View Post
I would agree.
Allen
Hey Allen, built to spin to 7kish. The wear is on the journal surface, not the thrust (no wear on the thrust). I plastigauged all of them between .0015 and .002 but something does not look right now.
gikort is offline
post #86 of 89 (permalink) Old 04-15-2019, 04:03 PM Thread Starter
gikort's Avatar
It was line honed, but something sure doesn't look right.
gikort is offline
post #87 of 89 (permalink) Old 04-15-2019, 04:04 PM Thread Starter
gikort's Avatar
That is why I pulled the thrust bearing to start with, but there isn't really any wear on the thrust surface at all (except a tiny little scuff on one side).
gikort is offline
post #88 of 89 (permalink) Old 04-15-2019, 04:06 PM Thread Starter
gikort's Avatar
Originally Posted by GT350HR View Post
gikort,
Randy
I want to think this isn't the case since the rings and pistons came as a kit, but it very well could be the cause. The main bearing has me wondering if that's not causing it however. I need to check the rest of the mains and see how they look still.
gikort is offline
post #89 of 89 (permalink) Old 04-15-2019, 08:20 PM
Turnall's Avatar
Just as a clarification, I am talking about the thrust bearing and not just the part that you are calling the "thrust". I think most others are as well. We call it the thrust bearing because that's the name of that particular bearing. We all see the wear on the part that goes around the journal.
Hope this clears it up a bit. Still hoping you find the solution...
Allen
Turnall is offline
Similar Threads
Question for Engine Gurus, Timing/Balancer BigJoeWV Vintage Mustang Forum 21 02-25-2019 09:12 AM
Fresh engine, timing issues. 1970coupe Vintage Mustang Forum 21 01-21-2019 02:17 PM
How do I inspect a used engine before buying traditional Vintage Mustang Forum 16 11-01-2018 01:45 PM
Last piece of the puzzle - engine one_fast67 Vintage Mustang Forum 18 07-25-2018 09:03 PM
65 mustang engine position 5.0 & T5 mustang5.0 Vintage Mustang Forum 7 04-04-2018 12:25 AM
