What's up with my battery tray? - Vintage Mustang Forums
 3Likes
  • 1 Post By mustang656man
  • 2 Post By happystang
post #1 of 10 (permalink) Old 04-10-2019, 10:19 PM Thread Starter
beardking's Avatar
As the title suggests, I'm confused by my battery tray. Looking at other pictures of battery trays for 68 mustangs, mine doesn't seem to look like the rest and it's making it difficult for me to figure out the hold down bracket situation (i.e., there is no hold down bracket in my situation).
Any guidance as to what I'm missing here (parts?) would be greatly appreciated.
Thank you
1968 Coupe, 302 (not original), auto, in need of plenty of work and I'm looking forward to it.
beardking is offline
post #2 of 10 (permalink) Old 04-10-2019, 10:24 PM
you are missing the proper tray and hold down- available at most mustang vendors. Whatever is there now is homemade. Wes
Rorin67 likes this.
mustang656man is offline
post #3 of 10 (permalink) Old 04-10-2019, 10:25 PM
happystang's Avatar
Looks like it had rusted away then someone cobbled together whatever you see now. Regardless, you likely have a date with an angle grinder and welder.
Rorin67 and 66ryan like this.
1969 Convertible field find (450hp spaghetti noodle)
1968 Fastback (428 and a 4 speed)
www.SaveClassicCars.net
-Armon
happystang is offline
post #4 of 10 (permalink) Old 04-10-2019, 10:30 PM
68Ghost's Avatar
Looks like it rusted away?!
Here my fender apron after I removed the rusted tray:
Here’s the tray and backing plate:
Just ordered and installed this tray from CJPP. $11 and fits great. Did some clean up, rust converter / encapsulator and epoxy prior. The backing plate will cost ya a bit more if you need one. Hope this helps!
https://www.cjponyparts.com/cj-class...-1970/p/M3535/
'68 Mustang Hardtop, 302, C4
AKA "Dr. Wolf"
68Ghost is offline
post #5 of 10 (permalink) Old 04-10-2019, 11:10 PM Thread Starter
beardking's Avatar
Well, the date with the angle grinder I can handle, but that welder thing not so much. I don't know how to weld, nor do I have one.
Are you suggesting the welding for fixing any rust to the fender that is likely under that welded in sheet that is in the pic? Or for installing the proper tray? From what I've seen at the link above, it looks like the CJPP battery tray doesn't require welding.
post #6 of 10 (permalink) Old 04-10-2019, 11:26 PM
DaleB's Avatar
Looks like that fender apron will need POR.
Not the rust treatment paint...
Patch Or Replace.
DaleB is offline
post #7 of 10 (permalink) Old 04-11-2019, 09:19 AM
Magnus's Avatar
Look up underneath it and see if the metal looks ok from the outside. The apron metal might be alright.
The new package tray just bolts on. So you should probably plan to buy the bolts too.
And you'll need the hold down handle and the long bolts that actually hold it down.
So, something along the lines of:
Tray: https://www.npdlink.com/product/batt...l-1-2mm/100916
Bolts: https://www.npdlink.com/product/moun...-sems-6/100914
Hooks: https://www.npdlink.com/product/moun...correct/100922
Bracket: https://www.npdlink.com/product/batt...duction/100902
Also just so you're prepared, the lower bolts go in from the outside right above where the bumper bracket bolts on, so you might need to take that loose to get the bolts in.
Magnus is offline
post #8 of 10 (permalink) Old 04-11-2019, 09:12 PM Thread Starter
beardking's Avatar
Well THAT was a bad idea.
I think for now I'll leave it as it is and rig up a better hold down system than just an old bungee cord that was originally there.
post #9 of 10 (permalink) Old 04-11-2019, 09:46 PM
What you can do is this:
Clean up as much as you can. Cut out the damaged part of the apron. Take a replacement apron and cut out a patch. Use a 1” overlap with the old panel. Use screws to hold it to the old panel. Paint everything to protect it. Bolt on a new battery box.
Done carefully it is difficult to tell without looking close and it will last for a long time until you can find a friend who can help you weld it in
Flade
68 289 convertible Candy-apple red & white
66 200 coupe Blue
94 GT convertible Red & black
98 GT convertible White & black
98 V6 convertible White & tan
Flade is online now
post #10 of 10 (permalink) Old 04-11-2019, 09:49 PM
Magnus's Avatar
Well that's not what you were supposed to find.
At least now you know what you've got to work with I guess.
Magnus is offline
Similar Threads
Replacing battery and related stuff bmcgc Vintage Mustang Forum 2 04-10-2019 04:10 PM
Battery Tray question ophthos Vintage Mustang Forum 7 03-10-2019 01:20 PM
66 Mustang battery tray supposed to be parallel to rad support? Eitelbj Vintage Mustang Forum 7 03-05-2019 10:12 AM
New battery box macstang Vintage Mustang Forum 2 01-08-2019 10:35 PM
65-66 Battery Tray Upgrade Issues jgrote Vintage Mustang Forum 3 06-30-2018 06:12 PM
