Detroit Speed Selecta-Speed in a 68 - Vintage Mustang Forums
 1Likes
  • 1 Post By sr1032
post #1 of 13 (permalink) Old 04-14-2019, 08:46 AM Thread Starter
Has anyone used it in a 67/68?
gspitale is offline
post #2 of 13 (permalink) Old 04-14-2019, 09:26 PM
awhtx's Avatar
Back in 1959 Ford came out with the Select-0-Speed transmission for tractors. My 1967 5000 has one.
awhtx is offline
post #3 of 13 (permalink) Old 04-14-2019, 11:05 PM
1966notch's Avatar
Itís for windshield wipers lol, I had no idea what it was for until just now either. I would have guessed a transmission piece too!
'66 coupe 347 4spd toploader
1966notch is offline
post #4 of 13 (permalink) Old 04-14-2019, 11:12 PM
Grimbrand's Avatar
In my experience, even with just "Off", "Low", and "High", it's not much fuss. And on those misty days where the sky can't make up its mind whether to drizzle or not, a gentle tap of the windshield washer pedal will kick the wipers over to clear your view. I like it that way.
IMHO, not worth drilling new holes, and figuring out how to mount a Camaro/Firebird motor, linkage, and wire it all up. Not to mention finding a switch that won't look like you've butchered your dash.
Grimbrand is online now
post #5 of 13 (permalink) Old 04-15-2019, 03:21 AM
I chose it for my 65 so I can't help with the 67/68, however it's not like what Grim is describing. It's a lot of money so I'm not sure I would do it again but for the Pacific Northwest it's great to have the flexibility and I wanted something all inclusive. The kit comes with everything you need and is very easy to install. You don't have to figure out how to mount anything, there is a wiper motor spacer that puts it in the right place using existing holes and there is a switch included that allows you to use the stock setup there as well. All you have to do is add power and ground which were already routed to the old setup so you use those. In hindsight I could've looked for all the different setups that are available but this was nice and has intermittent.
Grimbrand likes this.
1965 Coupe - Wimbledon White Road Race Car
1967 Coupe - Red Street Cruiser
Bunch of other non-Ford cars no one will car about
US Navy MMCPO
sr1032 is offline
post #6 of 13 (permalink) Old 04-15-2019, 07:57 AM
Magnus's Avatar
For delayed wipers on my '67 I used this:
https://www.npdlink.com/product/swit...ttent-7/150990
All you have to replace is the switch and it works. It's a little goofy having to bump it one way or the other to speed up or slow down, but it's better on a drizzly day than having to keep hitting the pedal.
That said NPD shows being out of them and the manufacturer's web site (musclecarswitch.com) is expired so they may not be available anymore. If you can find one though they do work and you don't have to deal with any extra wiring or replacing your wiper motor or anything.
If they are still in business, their contact info (from Archive.org) was: Muscle Car Switch, 7808 Medallion Way, Rohnert Park, CA 94928 USA, (650) 458-7423
Magnus is offline
post #7 of 13 (permalink) Old 04-15-2019, 09:33 AM Thread Starter
Thanks for the replies all ... if you google the NPD part number, it is still available from a couple of sources.
PN: FM6768WI
One site I found that says they have it:
https://restorationpartssource.com/s..._moreinfo.html
Haven't decided what I'm going to do - but I like modern things wrapped in classic skin.
gspitale is offline
post #8 of 13 (permalink) Old 04-15-2019, 07:58 PM
bmcgc's Avatar
For 67+ why not use a F100 intermittent switch? Pretty much plug-n-play.
1965 Mustang Coupe 289/C4
1967 Mustang Coupe 200/C4
2017 Mustang EB Premium
bmcgc is offline
post #9 of 13 (permalink) Old 04-15-2019, 09:41 PM
Magnus's Avatar
The problem with the 67/68 is that they didn't use a normal wiper switch, they made it a three position slider on the instrument cluster.
Seen here above the speedo next to the left turn indicator:
It looks cool, but you've either got to reach around or through the steering wheel to turn the wipers on. And of course it's completely different from everything else so you can't just swap it out.
Unless I'm missing something and there's actually a way to install the F100 delay wiring with the 67's oddball switch. I do miss that delayed wiper switch on my old F100. They definitely got it right when they designed that one.
Magnus is offline
post #10 of 13 (permalink) Old 04-15-2019, 09:59 PM
bmcgc's Avatar
Duh, and I own a 67.
bmcgc is offline
post #11 of 13 (permalink) Old 04-16-2019, 08:22 AM
Magnus's Avatar
Yeah, saw that after I posted.
You've got me (and I'm sure everyone else) curious now though. Do you know if it's actually possible to put the F100 wiring in a 67? I just don't see how it'd work, and as much as I like the Muscle Car Switch upgrade over the stock switch it's still not as nice as that F100 one is.
Magnus is offline
post #12 of 13 (permalink) Old 04-16-2019, 06:18 PM
bmcgc's Avatar
My understanding is that the F100 intermittent switch will work with Ford 67+ 2 speed motors.
IDK why it will not work with 65/66 2 speed motors, but thats what the boys on the net say, so it must be true.
Of course the 67/68 problem is the Mustang does not have a rotary wiper switch.
bmcgc is offline
post #13 of 13 (permalink) Old 04-16-2019, 06:34 PM
sessayan's Avatar
Umm, Why are you driving your car in the rain ? It deserves better then that Just saying.....
Steve E.
1965 Wimbledon White Vert.
T5, FiTech EFI, Borgeson Power Steering ,Ididit tilt, Street or track 4 wheel disc, coil overs, 3 link rear, 3G alternator, Custom sound system
sessayan is offline
Similar Threads
DETROIT V.S. RUST (Game On) LOL. 1969sag General Discussion (Non-Vintage Mustang) 16 10-02-2018 10:54 AM
Need for speed macstang General Discussion (Non-Vintage Mustang) 5 07-15-2018 07:00 PM
3 and 4 speed shift levers: Which is correct and fill in the blanks Mustangerbob1 Vintage Mustang Forum 1 04-20-2018 08:14 PM
Time, Distance, Speed Rallys Brian66 The Track 3 04-06-2018 02:22 PM
FS: Detroit Speed sub-frame connector C7Z 1964 1/2 through 1966 Mustang Parts For Sale 0 03-20-2018 11:05 PM
