Water flow restrictor to heater core (1970) - Vintage Mustang Forums
 4Likes
  • 3 Post By 22GT
  • 1 Post By happystang
post #1 of 15 (permalink) Old 04-19-2019, 11:28 AM Thread Starter
Machin's Avatar
I have replaced a heater core (leaking from a seam) in my '70 Mach 1 four times now. I've owned the car 25 years. Should there be a water flow restrictor going to the heater core to reduce the water pressure to the heater core? What does it look like and where does it go. Thanks in advance
70 Mach 1, 351C 4V , 4 spd , hood tach , Grabber Orange
2007 Shelby GT500 White with blue strips
Machin is offline
post #2 of 15 (permalink) Old 04-19-2019, 11:36 AM
Blues Power's Avatar
wowee that is a lot of work to do 4x
no water restrictions in Stock mach 1s
there is an vacuum valve in the inlet line only if you have AC but it just closes the water flow to the HC when the AC is on
what brand HC are you using. I used Modine back in 96 and thank god its still going.
I do a flush every 2-3 years about 1500 miles
you can try a water restrictor from a 91-93 GT. it will fit in the 5/8th hose and you can give that a shot.
cheap enough insurance anyways
or you can use a 5/8th brass petcock valve in the inlet line and just keep it half open.
1970 Mach 1 San Jose built Dec 23 1969. Marti 1 of 7. Purchased in 1987. Original family owner of the power train
351C 2v FMX.
1993 GT 13,000 miles, Built 2-12-93 Bought 8/3/93 Auto, 3:27 Axle, cloth, sunroof, AC. Unmolested all original car. Purchased new 8-3-93. still has the factory windshield fluid.
Blues Power is offline
post #3 of 15 (permalink) Old 04-19-2019, 12:26 PM
22GT's Avatar
Typically the water outlet on the engine feeding the heater IS a restrictor. What engine do you have?
Note the crushed inlet below. The hexagonal machined type has a very small, maybe 1/4" hole, drilled inside.
Brent, gt350sr and Woodchuck like this.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #4 of 15 (permalink) Old 04-19-2019, 12:37 PM
dzahm's Avatar
4 cores is a lot. If you figure one was factory and old- and maybe one was cheap repro- but still that leaves 2 more? any issue with battery going dead? Or using a trickle charger? (Wondering if maybe an electrical issue/electrolysis eating away at the core)
FWIW- I installed the brass shut off valve on mine- I generally don't drive in the winter BUT its a vert- so I do need a lil heat sometimes. If it was a FB- I would probably leave it shut off if I was in a warm climate
dzahm is offline
post #5 of 15 (permalink) Old 04-19-2019, 01:10 PM
Brent's Avatar
Like 22GT mentioned, make sure your outlet is crimped. On the 64-66 Mustangs the outlet isn't crimped but I had some issues with the heater hoses leaking and a blown heater core so I just crimped it myself. It's been a year now, no heater leaks of any kind, and the heater still cooks me outta the car.
Brent
66 GT350 Tribute in Sapphire Blue built over 12-years and finally being driven!
Brent is offline
post #6 of 15 (permalink) Old 04-19-2019, 01:30 PM
GT289's Avatar
In additional to previous comments already stated I can’t help but think there has been a change in quality in heater cores. I’ve got a 65/66 core from Ford parts back in the 60’s, brand new in the box. It is seriously heavy weight.... way more than the core available today.
- Douglas Adams
GT289 is offline
post #7 of 15 (permalink) Old 04-19-2019, 01:33 PM
gordonr's Avatar
Its a closed system, the pressure will be the same. Flow thru the core will be reduced though. I would start looking to see if you can read for voltage in your coolant and see how much system pressure you are normally running.
1969 Mach 1 S code...2nd owner
gordonr is offline
post #8 of 15 (permalink) Old 04-19-2019, 01:41 PM
Brent's Avatar
Replacing the radiator cap with a new 13 PSI one, or maybe even lower if your region isn't too hot, could solve the issue. The lower rated cap is a bandaid fix but just thought I'd throw it out there.
Brent is offline
post #9 of 15 (permalink) Old 04-19-2019, 01:49 PM Thread Starter
Machin's Avatar
No A/C. All of the replaced heaters have been Modine. Battery does not go dead 351C Yes what a pain replacing them!
Machin is offline
post #10 of 15 (permalink) Old 04-19-2019, 06:32 PM
gordonr's Avatar
Have you had any of the cores checked out by a radiator shop? May give you a clue to move on to an answer.
gordonr is offline
post #11 of 15 (permalink) Old 04-19-2019, 06:57 PM
happystang's Avatar
I had the same issue and went through several heater cores on my '69. The aftermarket water neck coming out of the intake did not restrict enough flow and would pop the core after a while (high flow pump, high RPM engine, and heavy PSI rad cap didn't help).
The solution was a 3/8" pipe plug with a hole drilled into it plumbed into the upper heater hose- this limited the pressure going into the heater core. The same core has been in there for several years now with no issues. I put a hose clamp around the hose where the resistor is just to make sure it stays put.
Woodchuck likes this.
1969 Convertible field find (450hp spaghetti noodle)
1968 Fastback (428 and a 4 speed)
www.SaveClassicCars.net
-Armon
happystang is offline
post #12 of 15 (permalink) Old 04-19-2019, 09:27 PM
Also pick up a heater control valve, like a 69-71 dodge or vintage air 46105-vuh from summit. It's an easy in line shut off for the heater core. Using the suggested restrictor above and this shut off will easily address your heater core prob. I ran both for several years.
groho is offline
post #13 of 15 (permalink) Old 04-19-2019, 09:34 PM
Woodchuck's Avatar
The Vintage Air Replacement Heater Valves 461171 might be a better choice... it's 12V electric so you can hide a toggle switch somewhere.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #14 of 15 (permalink) Old 04-19-2019, 10:16 PM
bmcgc's Avatar
Many Fords used a heater control valve.
https://www.dearbornclassics.com/hea...axie-1963.html
https://www.dearbornclassics.com/hea...1969-1970.html
https://www.autozone.com/cooling-hea...4_148104_13402
1965 Mustang Coupe 289/C4
1967 Mustang Coupe 200/C4
2017 Mustang EB Premium
bmcgc is online now
post #15 of 15 (permalink) Old 04-20-2019, 10:20 AM
gt350sr's Avatar
On my '65 Galaxie with a 390 I had the same issues. What I found was that the length of the elbow in the intake is what made the difference for me. The original had a deep pipe extending past the threaded portion that sat maybe 1/4" off the floor of the intake manifold. When I switched to an Edelbrock alum intake and a new elbow, I kept blowing the lines off the heater core. You think yours was bad- mine requires removal of the fender!! I finally switched to an OE style steel elbow and it solved my problem completely.
Working on old cars teaches us patience... and every curse word imaginable!
gt350sr is offline
Similar Threads
Heater Core Seals 67/68 with A/C Tiggie Vintage Mustang Forum 4 02-21-2019 05:51 PM
Heater core assembly w/ electrical pump Steven van 't Ende Vintage Mustang Forum 5 01-18-2019 09:38 AM
heater core issues Machin Vintage Mustang Forum 14 01-11-2019 03:10 PM
1970 Mustang heater core replacement non ac 70Mach0ne Vintage Mustang Forum 1 07-18-2018 08:56 PM
Where is the Heater Hose Restrictor on a 1970 351C? Klutch Vintage Mustang Forum 15 12-04-2017 04:32 AM
