'67 Cast Door Hinge Pin Removal - Vintage Mustang Forums
 2Likes
  • 2 Post By clive
post #1 of 7 (permalink) Old 05-04-2019, 06:17 PM Thread Starter
Hi,
Any tips for removing the hinge pin on a lower hinge? The hinge is the cast type and is out of the car.
The upper hinge pin drifted out easily, but the lower one is not budging at all. I have tried penetrating fluid, heat, and the biggest f hammer I have.
Curious thing is that bottom end (from where I am using a punch & hammer) rotates with the door part of the hinge, but the pin head is fixed to the body side of the hinge as it should be. I suppose the pin is broken.
Thanks,
Clive.
clive is offline
post #2 of 7 (permalink) Old 05-05-2019, 07:55 AM
Mach1 Driver's Avatar
West Coast Classic Cougar has a good repair video- see #73 Door Hinge Rebuild
Original Owner 69 Mach1
Mach1 Driver is offline
post #3 of 7 (permalink) Old 05-05-2019, 09:16 AM
BradAlbrecht's Avatar
Use an air chisel with a punch bit.
BradAlbrecht is online now
post #4 of 7 (permalink) Old 05-05-2019, 08:32 PM
You said heat, but, I used a oxy/acetylene torch with a cutting/burning tip.
Roddster
67 GT 350: MCA & SAAC Gold winner
67 S code GTA coupe
Roddster is offline
post #5 of 7 (permalink) Old 05-05-2019, 08:55 PM
Mustangerbob1's Avatar
Sadly, this is why the lowers get trashed and the reproduction is used. Repo is inexpensive, and OEM are an absolute bear to fix.
[email protected] ed ay +3112
Richardson TX
1968 GT500 Arrest Me Red (The Big Boy Toy)
1966 K Code Vert (The K 'Vert)
Mustangerbob1 is offline
post #6 of 7 (permalink) Old 05-18-2019, 04:52 PM Thread Starter
Thanks for the tips everyone.
After pounding away with practically no movement, I decided to get serious with it!
First I cut the pin in the two gaps between the two parts of the hinge. A hacksaw blade fit the gap without damaging the hinge pieces - effectively I cut through the shoulders of the bushings to get to the the pin.
The pin ends that were in the door side of the hinge drifted out easily - so the problem was in the door part of the hinge. Again pounding on this did not make much of an impact. I could drift it back and forth about 1/32 in, but no more. Time to get serious again.
I drilled the pin using a 1/4 in bit - to make sure that if not centered it would not damage the hinge. I drilled about 1/2 in - enough to go past the depth of the bushing. Then I used a 1/4 in drift in the hole, and the pin came out
Don't know why it was so stubborn. The pin had powdered rust around it, but nothing serious. I can only assume that rust had expanded the pin inside the bushing (plus mushrooming of the pin by the drift) made it too tight.
So if I'm faced with the same on my second hinge, I know what to do. It will take less than 30 mins to cut, drill and drift out the pin - easy :-P .
Clive.
englishman and 66Ccode like this.
clive is offline
post #7 of 7 (permalink) Old 05-19-2019, 04:13 PM Thread Starter
Just did the other side - less than 30 mins! This time it turned out that the head end of the pin that was held solid- the middle part literally slid out, and the bottom drifted out easily.
I drilled into the top part of the pin from the other end of the hinge, that is I did not drill into the head of the pin. Drilling means the punch locates in the hole, does not mushroom the pin, and possibly weakens the walls of the pin. Anyway, a couple of dozen of hits and it was out. Job done :-)
Clive.
clive is offline
Similar Threads
Bellhousing dowl pin removal tool coupe3w General Discussion (Non-Vintage Mustang) 4 02-06-2019 01:06 PM
Vacuum Modulator Pin 69GT350H Vintage Mustang Forum 2 01-16-2019 08:38 AM
Aluminum v. Cast Iron water pumps evans1 Vintage Mustang Forum 10 05-23-2018 08:08 AM
Pin Gage Set ) 0.011" to 0.60" zray Engine and Drivetrain Parts For Sale 6 01-29-2018 09:17 PM
Removing cam dowel pin arbys Vintage Mustang Forum 23 01-26-2018 12:12 PM
