T5 conversion shifter issue - Vintage Mustang Forums
 1Likes
  • 1 Post By rhutt
post #1 of 14 (permalink) Old 05-13-2019, 10:10 AM Thread Starter
I posted on here a couple weeks ago about an issue with my T5 install on my 66 convertible (was originally a c4 auto). The shifter bolts are roughly 2 inches forward of the hole in the floor where the c4 shifter went through. I got several responses (thanks) but I now have pics to share. So, any folks out there have any idea why the shifter sits this far forward? Have pics of the hole in the floorboard and where the shifter sits, views of the T5, the crossmember, and motor mounts. Please help!
Michael Mehrhof is offline
post #2 of 14 (permalink) Old 05-13-2019, 10:16 AM Thread Starter
Don't know why the pics are getting rotated on the upload. Sorry about that.
post #3 of 14 (permalink) Old 05-13-2019, 10:39 AM
It's difficult to determine the distance that the trans sits below the tunnel sheet metal, but the alignment fore and aft in the car looks like a shifter similar to what is sold by MDL would center the shifter up in the opening. The offset shifter is normal in early Mustangs.
'66 GT Fastback, 302, Edelbrock Top End, Sniper EFI/Aeromotive, MSD, JBA Headers & 2.5" Exhaust, T5Z, Currie 3.55 Trac-Loc
rhutt is offline
post #4 of 14 (permalink) Old 05-13-2019, 10:51 AM
It is possible that you could have to clearance the opening slightly (less than 1/4 ") to clear the surface indicated in red.
Rebel Racing likes this.
rhutt is offline
post #5 of 14 (permalink) Old 05-13-2019, 11:29 AM
awhtx's Avatar
You do have the early style motor mounts but I don't think you have them reversed. I am using the same transmission crossmember that you have. Maybe your description of the shifter being 2" forward is a little exaggerated. A photo of the shifter as seen from inside the car with better lighting and with the carpet pulled out of the way would help me a lot.
awhtx is offline
post #6 of 14 (permalink) Old 05-13-2019, 12:04 PM
22GT's Avatar
OK, relax. The shifter is not centered on the housing, it sits to the rear. You should have installed it before installing the trans, though, now it will be an awkward pain.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is online now
post #7 of 14 (permalink) Old 05-13-2019, 12:34 PM
malarson's Avatar
Looks like it will fit fine to me. Going to be a pain to put in at this point though, may have to drop the back of the trans down.
69 Mach 1, 351W, T5, owned for 31 years, 03 Mach 1 Azure Blue, 65 fastback, 289, C4 (son's), 67 fastback, 289, C4 (wife's)
malarson is offline
post #8 of 14 (permalink) Old 05-13-2019, 06:00 PM
Rebel Racing's Avatar
That's exactly what I had to do......not a big deal at all as I recall.
Rebel Racing is offline
post #9 of 14 (permalink) Old 05-13-2019, 07:52 PM
Nailbender's Avatar
I used the MDL shifter and only had to clearance the front toward the firewall side 1/8" just so I could get the trans as high as possible in the tunnel. The trimming was optional.
You don't have to use the the conversion shifters, it just keeps you from having to drill shifter boot holes and possibly replacing the carpet.
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, HiPo Manifolds, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is offline
post #10 of 14 (permalink) Old 05-13-2019, 09:09 PM
665spd's Avatar
Looks good to me. PIA to get to the bolts, but stock worked good for me. short throw had to be ground to fit the hole( the fixed part of the shifter)
It's just a little rust...
1966 secretary special originally 6cyl 3 spd coupe.
5.0 SEFI complete from 1988 Mustang GT, world class T-5, 9 inch with 3.50 Trac Lok and Shelby style traction bars. Front disk 4 piston calipers and 8cyl manual steering.
Build thread:https://forums.vintage-mustang.com/b...5-0-resto.html
665spd is offline
post #11 of 14 (permalink) Old 05-13-2019, 09:40 PM
awhtx's Avatar
Here is a photo of my T5 next to the original T10 I removed. You can see that the actual shifter handle on the T5 is 3/4" forward of the shifter handle on the T10. That is a Hurst shifter on the T5. Disregard that large, rectangular plate at the bottom of the shifter and concern yourself with the shifter handle.
I did not cut or grind anything on the original shifter hole to install this T5 in my '65.
awhtx is offline
post #12 of 14 (permalink) Old 05-13-2019, 10:15 PM
When I did my conversion, I had to use the offset MDL shifter to center the lever in the factory console. Without the additional complexity that the console adds to the install, I could have easily gone with a straight shifter like you suggest.
rhutt is offline
post #13 of 14 (permalink) Old 05-13-2019, 11:34 PM
To me, it looks like you have miss matched motor mounts (early on one side and later on the other).
James
66 Coupe Project 289
Eitelbj is offline
post #14 of 14 (permalink) Old 05-14-2019, 12:11 AM
That looks about like where mine sat too. The stock T5 shifter worked. I've also tried the MDL to centre it within the console.
Rowdy is offline
Similar Threads
Shifter 2 inches forward on 66 t5 conversion Michael Mehrhof Vintage Mustang Forum 10 05-05-2019 06:51 PM
CSRP Manual Front Disc Conversion Issue Dans68 Vintage Mustang Forum 55 11-06-2018 04:36 PM
Stock Shifter with a 5.0/AOD conversion TheDraytone Vintage Mustang Forum 3 11-04-2018 03:27 AM
Age Old Issue of Disc Brake Conversion Bob's Project Vintage Mustang Forum 27 10-25-2018 01:01 AM
Shifter Knob Issue sleeton Vintage Mustang Forum 11 02-22-2018 09:51 AM
