C5 Heads Rebuild Question - Vintage Mustang Forums
 1Likes
  • 1 Post By Nailbender
post #1 of 7 (permalink) Old 05-14-2019, 03:56 PM Thread Starter
John_in_SC's Avatar
Hey Team VMF
I am selling some C5 heads however I got to thinking. I like the smaller CC on them. I have Performer RPM heads on now: 170CC/60CC with 1.9/1.6 valves.
Is it worth rebuild on them. What is the potential here?
J
John in SC
Formerly Studiopet_2005
1966 Coupe - 302 with some stuff on it
John_in_SC is offline
post #2 of 7 (permalink) Old 05-14-2019, 04:11 PM Thread Starter
John_in_SC's Avatar
Just googled for specs:
C5AE-B Ė 1965, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chamber
Does that chamber size seem right?
Regarding date code: C5AE is plain as day. Found the letter designator "B" on bottom of head near where head bolts go in.
John in SC
post #3 of 7 (permalink) Old 05-14-2019, 07:04 PM
Nailbender's Avatar
On my backup 289 I have a ported set of C5AE heads sporting 1.94 1.60 valves. I wasn't very impressed with them and it would take a ton of money to get yours to the point mine are. Those heads only have potential, if they don't have the EGR bumps to somebody bent on originality or vintage racing. If you want a smaller CC have the Elelbrocks milled.
Turnall likes this.
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, HiPo Manifolds, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is online now
post #4 of 7 (permalink) Old 05-14-2019, 10:14 PM Thread Starter
John_in_SC's Avatar
Thanks. Just the answer I was looking for
post #5 of 7 (permalink) Old 05-14-2019, 10:43 PM
Grimbrand's Avatar
The C5AE heads with proper porting are great for a car that isn't intended to see more than 6k. When someone just hogs them out to make the ports larger, oftentimes despite increased top end, you wind up with lackluster performance throughout the rest of their powerband.
It's possible for someone with a lot more knowledge of port design to get real power out of these; I've heard of guys making 350 horses with C5 and C6 heads.
As usual, it all comes down to the engine combo working together.
You'd have to find someone with a lot of experience to make them right, and frankly, that experience wouldn't come cheap. A set of AFR 165's or TW170s would blow them away, and probably be at about the same pricepoint.
Now, if you happen to "know a guy...", bring a case of beer, hang out in his garage and learn something, then it'd make a lot more sense to put the effort into your early heads. They're noted for having a lot of extra 'meat' and being good for porting. But that presumes that the person doing the porting knows what they're doing. They're worse than E7TE's, right out of the box.
Grimbrand is offline
post #6 of 7 (permalink) Old 05-14-2019, 11:18 PM
LSG
Tongue nonsense
John, the C5AE is a fine cylinderhead. Most of them have about a 54 cc chamber. if you get the bigger valves and do some clean up, 200+ flow @ 28 inches is there without too much trouble. Thats enough for 440 hp at the crank. Is that enough ? Do you need part numbers for valves or seats ? Lots of guys like the 289 heads for the smaller chambers. And they're better than an E7TE, even with nothing done to them. LSG
LSG is offline
post #7 of 7 (permalink) Old 05-17-2019, 01:54 AM
Sik66's Avatar
I ran a set of C5 heads for a while. Bigger valves and a home port job. They ran fairly well
Sik66 is offline
Similar Threads
Gt40 heads on a pre-h.o block: Steam-holes, a guide and walk-through Scarlet-302 Vintage Mustang Forum 14 10-28-2018 05:30 PM
289 rebuild question on pistons makse Vintage Mustang Forum 25 04-08-2018 04:48 PM
64 1/2 power steering rebuild question arbys Vintage Mustang Forum 1 02-26-2018 11:59 AM
GT40 Heads. Is this a good deal? lennyB Vintage Mustang Forum 35 02-06-2018 01:44 PM
Caliper rebuild and storage question Knapper Vintage Mustang Forum 7 01-18-2018 07:39 AM
