HELP: 1967 Mustang Coupe Floor Welding Question - Vintage Mustang Forums
 1Likes
  • 1 Post By Israel
post #1 of 10 (permalink) Old 05-16-2019, 07:54 AM Thread Starter
njp914's Avatar
Hey guys sorry if this is a dumb question but im 17 and just recently traded my nova for a 1967 mustang coupe and am starting to fix her up and get her ready to daily drive, i have to do some weather stripping and stop some leaks that happen from rain water but i need to replace all 4 floor pans, i have the replacement pans already and i have a buddy to weld them in but i am curious about one thing, Mustangs are unibody cars like my nova so i know the subframe has to connect to the floor pans, but how ? Do they weld on or bolt on and when i cut out the floor pans how do i do so without cutting the subframe or damaging it, how do i disconnect it from the floors so i can pull them out after i cut it and put the new ones in? Do i have to weld the subframe to the new floor pans? Thank you in advance for your help! Oh and also the subframe isnt bent down or anything from the car, the frame rails all seem straight just the floors are bad from the leaks in the weatherstrip and the cowl vent (which is common with mustangs as yall know and im about to fix that too)
njp914 is offline
post #2 of 10 (permalink) Old 05-16-2019, 08:26 AM
The floor pans are spot welded to the frame. You just have to find all the spots & drill them out. Body shop suppliers have the tool to do that. Then drill new holes in the new floor pans & weld them back in !
GOT-my*1967 is offline
post #3 of 10 (permalink) Old 05-16-2019, 08:46 AM
Israel's Avatar
Welcome to the board.
We have a Build Section for projects. Start a thread, Iíd like to follow the work.
Huntingky likes this.
Friend,......."Dude, thatís a rusted pile."
Israel is online now
post #4 of 10 (permalink) Old 05-16-2019, 09:31 AM
Hemikiller's Avatar
Here's a start...
http://www.mustangandfords.com/how-t...lace-floorpans
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is online now
post #5 of 10 (permalink) Old 05-16-2019, 09:32 AM
They weld to the rockers and then get welded to the floor supports.
jerrytotin is offline
post #6 of 10 (permalink) Old 05-16-2019, 09:38 AM
Huntingky's Avatar
In the second picture you can see where I ground down the welds that attach to the floor supports.
https://forums.vintage-mustang.com/b...ml#post9995890
If you look at some of the other build pages, you can find some better detailed pictures of some better detailed work than my own.
Coyote build in 65 GT Fastback in body work https://forums.vintage-mustang.com/b...e-powered.html and on Facebook @65gtmustang
F150 SCREW Ecoboost as my daily
66 Emberglow Coupe first car,71 Torino GT, 82 Fastback slooooow 6 banger, 71 Boss 351, 85 GT all long gone
Huntingky is offline
post #7 of 10 (permalink) Old 05-16-2019, 09:42 AM
Israel's Avatar
This board is Great!!
post #8 of 10 (permalink) Old 05-16-2019, 10:05 AM
Caper50's Avatar
First off welcome to the forum. Second spend some time looking through the Build Forum here on this site. You'll get plenty of tips there, I promise. Also do a search of Youtube for Jo Daddy. He's a down to earth and knowledgeable Mustang sheet metal repair guy. He has done several early Mustangs. Also check out another young California guy on Youtube. He's done a series of videos called Four Speed Films. Check out his Mustang, I think you'll like it. Lastly you should update your forum profile to show your location. You never know, another member may be closer than you think. Good luck with your car.
Caper50 is offline
post #9 of 10 (permalink) Old 05-16-2019, 10:13 AM
These are the two floor supports the floor gets welded to. Thereís also the trans tunnel hump bracket (not pictured ) that also get welded to.
post #10 of 10 (permalink) Old 05-16-2019, 01:02 PM Thread Starter
njp914's Avatar
Thank you all so much for your replies and help, I’ll look into all the information you guys sent and will try to document the stang with pics!
njp914 is offline
Similar Threads
1967 Mustang Coupe to Fastback Conversion lowlyslows Build Forum 19 04-17-2019 12:16 PM
1967 1968 Cougar & Mustang T5 / T-5 Conversion Crossmember - Free Shipping NEPM 1964 1/2 through 1966 Mustang Parts For Sale 0 03-07-2019 01:23 PM
Howdy! 1967 Mustang Coupe MsPearl New Member Introductions 3 02-11-2019 07:20 PM
1967 Mustang Coupe - The Dragon Resurrection TurbedAWD Build Forum 7 02-03-2019 05:06 PM
Sale: 1967 - 1973 Cougar & Mustang AOD / Tremec Conversion Crossmember-Free Shipping NEPM 1967 through 1968 Mustang Parts For Sale 0 01-10-2019 10:03 AM
