Vintage Mustang Forums
Vintage Mustang Forums (https://forums.vintage-mustang.com/)
-   Vintage Mustang Forum (https://forums.vintage-mustang.com/vintage-mustang-forum/)
-   -   Torque Box?? (https://forums.vintage-mustang.com/vintage-mustang-forum/1157510-torque-box.html)
66Ccode 05-18-2019 09:19 PM
Torque Box??
So I got a pair of torque boxes with the car and they fit like $h!t. So looping for a good fitting set that are 2 piece any one have a suggestion???
Israel 05-18-2019 09:47 PM
Most have to be massaged.
droptop119 05-18-2019 09:59 PM
I used one piece Dynacorn, drilled out the spot welds and took them apart. Fit was very nice!
2nd 66 05-18-2019 10:31 PM
I got the 1 piece Spectra units drilled them apart cut and refit cut and refit cut and refit ,,,,,,
66Ccode 05-19-2019 07:00 AM
Seems like the left side is the issue on the fitting. It just dont fit the shape of the fire wall at all...
Spectra is what I see Jo daddy used on his builds and I guess he got them from MU.
Huskinhano 05-19-2019 08:25 AM
Same here. They typically need work to fit. Have fun.
Caper50 05-19-2019 08:39 AM
I bought Spectra 1 piece units too and separated them. They did fit better than a Dynacorn set I also had here. My drivers side went in with minimal grinding but the passenger side required some cutting, metal removal and re-welding to fit the passenger side. If you own a welder and a grinder you can make these fit. No need to use a sledge hammer or a jack to force them in place, they can be made to fit. I'll be adding a Spectra set to my friend's 66 this summer.
Gecko 05-19-2019 08:56 AM
I bought the 1 piece units from cjpp, I'm assuming the the lower firewall is cut out and the torque box becomes part of it?
Huskinhano 05-19-2019 09:22 AM
What I realized during my installation is from the factory only the outer portion in the wheel well is added to the firewall. The 1 and 2 piece kits are giving you acsection of the toe board. So basically youre doubling up on the toe board. I thought about just using the outer part but used both as I thought it would make for a more ridged set up. On the toe board part I folded the flange 180* so I wouldnt have to cut through my toe boards since they were in great shape. Along with no welding inside the car either.
Ausfox 05-20-2019 07:00 AM
3 Attachment(s)
Make your own, at least you know they will fit. Used 1/8" plate
Caper50 05-20-2019 08:49 AM
Ausfox, very very nice job.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
