HEDMAN HEADERS or DOUGS HEADERS? - Vintage Mustang Forums
 4Likes
  • 3 Post By patrickstapler
  • 1 Post By blueovalfan68
post #1 of 13 (permalink) Old 05-19-2019, 08:25 PM Thread Starter
DEHABUR's Avatar
Does anyone know if the steering box and long shaft will need to be removed in order to install headers and then reinstalled? Also has anyone with a 302 Stroker motor in a 64-1/2 Coupe used Dougs headers with success?
64-1/2 MUSTANG RESTOMOD
DEHABUR is offline
post #2 of 13 (permalink) Old 05-19-2019, 08:37 PM
I have long tube hedman headers and there worked just fine with the stock steering in my 66. I later went with borgeson power and it they worked ok with that too.
Bella is offline
post #3 of 13 (permalink) Old 05-19-2019, 09:11 PM
c6fastback's Avatar
Send a message via AIM to c6fastback
I had Hedman long tubes on my 66 Mustang with the only issue being a lowered car and speed bumps .
I much prefer my current Hedman shorties.
68 302-4V w/1.84",1.54" ported , Comp XE268H , 2200 rpm Hughes converter, 3.25 9" w/10x2.5" shoes , MSD box/distrib , RPM intake , 670 Holley , cross flow aluminum radiator , Granada discs......
Michael S.
c6fastback is offline
post #4 of 13 (permalink) Old 05-19-2019, 09:21 PM
patrickstapler is offline
post #5 of 13 (permalink) Old 05-19-2019, 10:31 PM
blueovalfan68's Avatar
Originally Posted by patrickstapler View Post
^^^^I second this recommendation. Awesome fit and finish.
66stangFb likes this.
-Chris
'68 Mustang
347ci that has a lot of neat stuff in it
T5 manual trans, alum driveshaft, 9" w/3.70 gears
Suspension parts from SoT, Global West, Maier Racing, and a few others. Works for me!
TCP manual rack (love it)
EPAS (Love this the most)
VWW V45 wheels (like these too)
SoT 13" brakes (stopping is good)
And I finally got a paint job!
blueovalfan68 is online now
post #6 of 13 (permalink) Old 05-20-2019, 12:19 PM Thread Starter
DEHABUR's Avatar
I appreciate the recommendation guys but my other question is if the steering box and shaft are in the way of installing the headers? Are the FPA headers pricey? Thanks!
DEHABUR is offline
post #7 of 13 (permalink) Old 05-20-2019, 01:44 PM
I'd put a recommendation to FPA or Accufab.
Although i have a set of Dougs on the convertible and didnt have interference issues other than with the spark plugs. I had to dimple it on the #5 to clear the plug if I remember right.
chaser012001 is offline
post #8 of 13 (permalink) Old 05-20-2019, 02:56 PM
I have been able to install long tube headers with the steering box and steering shaft in place. It’s a PITA, but doable.
The FPA recommendation is out there cause their headers fit really well.
-Chris
'68 Mustang
post #9 of 13 (permalink) Old 05-20-2019, 04:01 PM
Yes, the Hedman Headers go in with the box and shaft in place. I believe you will find it easier to fish them up from below, rather than try to stuff them in from above. Ramps on the front wheels should do the trick.
Bella is offline
post #10 of 13 (permalink) Old 05-20-2019, 07:25 PM
$1000...6-8 week lead time. Theyíre that good. Other than valve train, it will probably be my next purchase. My boss has them on his Ď66. They have clearance everywhere...and plenty of it.
post #11 of 13 (permalink) Old 05-20-2019, 08:09 PM
blkfrd's Avatar
No and Yes. Caveat...I used Dougs Tri Ys on a 65 and not a 64.5, but is there a difference as far as this goes?
Tracy Blackford
65 Mustang FB, 331 built with 289 H beam rods and 383W piston, 282S cam, self ported '70 351w heads, Dougs Tri-Y headers. 1.7 shaft rockers and beehives. Hurricane Single Plane and custom 750 HP. T5z and 3.89 9" TL rear. PTP Engineering front suspension and 25540R17s all around
430 HP @ 6500...not too shabby for old school heads!
Daily Driver - 2013 Corvette 427 Convertible Collectors Edition
blkfrd is offline
post #12 of 13 (permalink) Old 05-23-2019, 08:00 AM Thread Starter
DEHABUR's Avatar
Your assessment is spot on. I spoke with Stan from FPA yesterday and he told me the exact same thing. Sounds as if they may be the best in the industry but they are big time back logged. They, like everyone across the country are having a tough time hiring fabricators and/or people that want to work with their hands... Such a shame. The product photos on their website look fantastic. Thanks for all the insight!
DEHABUR is offline
post #13 of 13 (permalink) Old 05-23-2019, 09:51 AM
66stangFb's Avatar
Thumbs Up Itís not that long
I know waiting six to eight weeks seems like forever, but youíll likely have your headers for the life of owning the Mustang. Iíve used several types of headers on my two Ď66 and there was always one side (usually left) that had a super tight fit. Iím using the FPA step header, with no HP loss as proven on a chassis dyno, and the clearance is helpful when plucking and installing the motor. The step header is also a good choice for street use (mine is racing). Iím also using the Total Control rack and pinion so I canít help with your actual question, but I do think the wait is worth it for the FPA.
Darrell George
'66 Fastback
66stangFb is offline
Similar Threads
Hedman Headers, should I be concerned with heat 67CustomStang Vintage Mustang Forum 14 04-25-2019 11:44 AM
JBA Headers - Don't fit as well as I had hoped Phydeauxman Vintage Mustang Forum 9 03-03-2019 07:50 PM
Hedman Shorty Headers fitment - Cable Clutch Phydeauxman Vintage Mustang Forum 9 02-25-2019 03:35 PM
1965 coupe Headers BamBam1 Vintage Mustang Forum 10 11-19-2018 05:00 PM
hedman shorty headers on 66 manual ?? kml1966 Vintage Mustang Forum 2 02-12-2018 09:57 PM
